[STM32F4] stm32f4 pc5 adc1没有读数
2251|2
 楼主| sirbai 发表于 2014-2-20 17:07 | 显示全部楼层 |阅读模式
stm32f4 pc5 adc1没有读数    adc3 pc2无问题
#include "stm32f4_discovery.h"
#include <stdio.h>
#include "usart.h"
#define ADC1_DR_ADDRESS     ((uint32_t)0x4001224C)
uint32_t i;
   to the debugger watch window */
__IO uint16_t ADC1ConvertedValue = 0;
__IO uint32_t ADC1ConvertedVoltage = 0;
void ADC3_CH12_DMA_Config(void);
int main(void)
  ADC3_CH12_DMA_Config();
  /* Start ADC3 Software Conversion */
  ADC_SoftwareStartConv(ADC1);
          USART3_Config();
  while (1)
  /* convert the ADC value (from 0 to 0xFFF) to a voltage value (from 0V to 3.3V)*/
    ADC1ConvertedVoltage = ADC1ConvertedValue *3300/0xFFF;
                                printf("%d\n",ADC1ConvertedVoltage);
                                while(i<10000000)i++;i=0;
  ADC_InitTypeDef       ADC_InitStructure;
  ADC_CommonInitTypeDef ADC_CommonInitStructure;
  DMA_InitTypeDef       DMA_InitStructure;
  GPIO_InitTypeDef      GPIO_InitStructure;
  /* Enable ADC3, DMA2 and GPIO clocks ****************************************/
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
  /* DMA2 Stream0 channel0 configuration **************************************/
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  /* Configure ADC3 Channel12 pin as analog input ******************************/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN ;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  /* ADC Common Init **********************************************************/
  ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
  ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
  ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
  ADC_CommonInit(&ADC_CommonInitStructure);
  /* ADC3 Init ****************************************************************/
  ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfConversion = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC3 regular channel12 configuration *************************************/
  ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 1, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
  ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
  /* Enable ADC3 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC3 */
  ADC_Cmd(ADC1, ENABLE);
 楼主| sirbai 发表于 2014-2-20 18:04 | 显示全部楼层
地址错了,呵呵,adc1 1204c
 楼主| sirbai 发表于 2014-2-20 18:08 | 显示全部楼层
ADC3_DR_ADDRESS ((uint32_t)0x4001224C)
ADC1_DR_ADDRESS ((uint32_t)0x4001204C)
那adc2呢
