[51单片机] 用C8051F040的IO口模拟IIC传输问题
2671|7
 楼主| wei9098 发表于 2014-2-24 10:56 | 显示全部楼层 |阅读模式
是必须要配置为开漏输出吗?任意IO口都可以吗?
新手求解答,非常感谢!
ayb_ice 发表于 2014-2-24 11:10 | 显示全部楼层
不用开漏输出,
弱上拉就可以了
 楼主| wei9098 发表于 2014-2-24 15:16 | 显示全部楼层
不用开漏输出,
弱上拉就可以了
#include "C8051f040.h"
sbit LCD_SCL=P1^3; //时钟 D0(SCLK)
sbit LCD_SDA=P1^2; //D1(MOSI) 数据
sbit LCD_RST=P1^7; //复位
sbit LCD_DC =P1^6; //数据/命令控制
#define X_WIDTH 128
#define Y_WIDTH 64
void ClockInit( void )
void GPIOInit( void )
    XBR0 = 0x00;
    XBR1 = 0x00;
    XBR2 = 0x40;
        P1MDOUT=0XF3;
void LCD_DLY_ms(unsigned int ms)
unsigned int a;
while(ms)
a=1800;
while(a--);
ms--;
return;
void LCD_WrDat(unsigned char dat)
unsigned char i;
LCD_DC=1;
for(i=0;i<8;i++) //发送一个八位数据
if((dat << i) & 0x80)
{LCD_SDA  = 1;}
else  LCD_SDA  = 0;
LCD_SCL = 0;
LCD_SCL = 1;
void LCD_WrCmd(unsigned char cmd)
unsigned char i;
LCD_DC=0;
if((cmd << i) & 0x80)
{LCD_SDA  = 1;}
else  LCD_SDA  = 0;
LCD_SCL = 0;
LCD_SCL = 1;
/*********************LCD 设置坐标************************************/
void LCD_Set_Pos(unsigned char x, unsigned char y)
LCD_WrCmd(0xb0+y);
LCD_WrCmd(((x&0xf0)>>4)|0x10);
LCD_WrCmd((x&0x0f)|0x01);
void LCD_Fill(unsigned char bmp_dat)
unsigned char y,x;
for(y=0;y<8;y++)
LCD_WrCmd(0xb0+y);
LCD_WrCmd(0x01);
LCD_WrCmd(0x10);
for(x=0;x<X_WIDTH;x++)
LCD_WrDat(bmp_dat);
void LCD_Init(void)
LCD_SCL=1;
LCD_RST=0;
LCD_DLY_ms(50);
LCD_RST=1;       //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕
LCD_WrCmd(0xae);//--turn off oled panel
LCD_WrCmd(0x00);//---set low column address
LCD_WrCmd(0x10);//---set high column address
LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
LCD_WrCmd(0x81);//--set contrast control register
LCD_WrCmd(0xcf); // Set SEG Output Current Brightness
LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
LCD_WrCmd(0xa6);//--set normal display
LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
LCD_WrCmd(0x3f);//--1/64 duty
LCD_WrCmd(0xd3);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
LCD_WrCmd(0x00);//-not offset
LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
LCD_WrCmd(0xd9);//--set pre-charge period
LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
LCD_WrCmd(0xda);//--set com pins hardware configuration
LCD_WrCmd(0x12);
LCD_WrCmd(0xdb);//--set vcomh
LCD_WrCmd(0x40);//Set VCOM Deselect Level
LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
LCD_WrCmd(0x02);//
LCD_WrCmd(0x8d);//--set Charge Pump enable/disable
LCD_WrCmd(0x14);//--set(0x10) disable
LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
LCD_WrCmd(0xaf);//--turn on oled panel
LCD_Fill(0x00);  //初始清屏
LCD_Set_Pos(0,0);
void main(void)
        WDTCN = 0xDE;
    WDTCN = 0xAD;
        ClockInit( );
    GPIOInit( );
        LCD_Init(); //oled 初始化
        while(1)
        LCD_Fill(0xff); //屏全亮
能帮我看一下程序吗?OLED点亮程序在STC上能运行,我想配置一下IO口移植到C8051F上,就是点不亮,谢谢啊!!
ayb_ice 发表于 2014-2-24 16:58 | 显示全部楼层
用配置向导产生初始化代码,一目了然
menfiss 发表于 2014-2-25 08:08 来自手机 | 显示全部楼层
交叉开关使能之前,管脚处于输入状态。
52414133 发表于 2014-2-25 08:27 | 显示全部楼层
 楼主| wei9098 发表于 2014-2-25 10:33 | 显示全部楼层
配置成推挽输出,再把管脚改到P3口就点亮了
cdf1214 发表于 2015-3-28 16:57 | 显示全部楼层
本公司主营TI. NXP. IR. ON. SiLicon        等著名世界品牌产品。
MSP430F一系列TI储存芯片 微控处理器
MSP430F149IPMR MSP430F5438AIPZR MSP430F5438IPZR等。
C8051F 一系列SILICON 单片机 微控处理器
C8051F020 C8051F120 C8051F340 C8051F040等
LPC一系列NXP单片机
LPC2132FBD64 LPC2134FBD64 LPC2214FBD144
LPC2378FBD144 LPC2292FBD144等一系列供应
专营:低压差 基准源 三 五 七端稳压 二三极管 场效应 快恢复 肖特基二极管 可控硅 达林顿 整流桥 TVS管 光藕 MAX AD 集成电路
                   北京长实拓展电子销售:陈冬锋
                                     QQ:2850327057
                      电话:15711002528,13641144498
