TM4C123G QEI
3088|0
 楼主| xiachu 发表于 2014-3-6 20:22 | 显示全部楼层 |阅读模式
想用QEI调节PWM占空比
signed long j=0;
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/pin_map.h"
#include "driverlib/pwm.h"
#include "driverlib/sysctl.h"
#include "inc/hw_gpio.h"
#include "inc/hw_types.h"
#include "driverlib/qei.h"
//PWM初始化
int
PWMInit (void)
            // PWM不分频
            SysCtlPWMClockSet(SYSCTL_PWMDIV_1);
        //使能M1PWM用到的PF,和RESET对应的PB
            SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
            SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//使能B端口,PB2、PB3分别对应RESET_AB,RESET_CD
            GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_2|GPIO_PIN_3);//配置2,3管脚为输出
            //配置PF0,PF1分别为M1PWM4,M1PWM5
            GPIOPinConfigure(GPIO_PF0_M1PWM4);
            GPIOPinConfigure(GPIO_PF1_M1PWM5);
            // 配置PF0,PF1为PWM的输出管脚
            GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_0|GPIO_PIN_1);
            // Configure the PWM1 to count down without synchronization.
            //配置GEN2递减计数模式不同步模式
            PWMGenConfigure(PWM1_BASE, PWM_GEN_2,
                            PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);
            //设置PWM周期
            PWMGenPeriodSet(PWM1_BASE, PWM_GEN_2,100);
            //设置PWM占空比
            PWMPulseWidthSet(PWM1_BASE, PWM_OUT_4, 1);
            PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5, 1);
            //使能PWM输出状态
            PWMOutputState(PWM1_BASE, PWM_OUT_4_BIT| PWM_OUT_5_BIT, true);
            GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_2, 0x1<<2);//H2管脚置高  对应RESETAB
            GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_3, 0x1<<3);//H3管脚置高 对应RESETCD
            // 使能PWM发生器
            PWMGenEnable(PWM1_BASE, PWM_GEN_2);
            return(0);
//QEI1初始化
int
QEIInit (void)
            GPIOPinTypeQEI(GPIO_PORTC_BASE,GPIO_PIN_5|GPIO_PIN_6);//配置PC5,PC6为PhA1,PhB1
                QEIConfigure(QEI1_BASE,(QEI_CONFIG_CAPTURE_A_B|QEI_CONFIG_NO_RESET|
                                QEI_CONFIG_QUADRATURE|QEI_CONFIG_NO_SWAP),100);//使用A,B通道共共4个边沿计算位置
                QEIEnable(QEI1_BASE);//使能正交编码器QEI1
                return(0);
//GPIOC中断处理函数
int
GPIOCIntHandler(void)
            signed long Direction;
            GPIOIntClear(GPIO_PORTC_BASE,GPIO_INT_PIN_5);//清除中断状态
            GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_2, 0x1<<0);//B2管脚置0  对应RESETAB
            GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_3, 0x1<<0);//B3管脚置0 对应RESETCD
            PWMGenDisable(PWM1_BASE, PWM_GEN_2 );//禁能PWM发生器
             //禁能PWM输出状态
        PWMOutputState(PWM1_BASE, PWM_OUT_4_BIT| PWM_OUT_5_BIT, false);
        j=QEIPositionGet(QEI1_BASE);
       if (QEIDirectionGet(QEI1_BASE))
                j++;
        else
                j--;
        if (j<0)
                j=0;
        else if (0<j<100)
            j=j;
        else
                j=100;
        SysCtlDelay(100);//延时
        PWMPulseWidthSet(PWM1_BASE, PWM_OUT_4, j);
        PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5, j);
        //使能PWM输出状态
        // 使能PWM发生器
        return(0);
//主函数
int main (void)
            SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                               SYSCTL_XTAL_16MHZ); // 设置时钟频率为16MHZ
            SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//使能GPIOB
            SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOC);//使能GPIOC
            SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);//使能GPIOF
            SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1); //使能M1PWM外设
            SysCtlPeripheralEnable(SYSCTL_PERIPH_QEI1);//使能QEI外设
            PWMInit ();
            QEIInit ();
            QEIPositionSet(QEI1_BASE,50);//更新参考点位置为50
            GPIOIntTypeSet(GPIO_PORTC_BASE,GPIO_PIN_5,GPIO_RISING_EDGE);//设置GPIO PC5为上升边沿中断
            GPIOIntEnable(GPIO_PORTC_BASE,GPIO_INT_PIN_5);//设置GPIO PC5所在管脚中断
            IntEnable(INT_GPIOC);//使能GPIOC端口中断
            IntMasterEnable();//使能处理器中断
            while(1)
每次选择正交编码,PWM占空比只加不减
