欢迎加入:2015年及以后毕业实习生招聘开始啦!
4134|35
 楼主| 21ic小管家 发表于 2014-3-10 13:53 | 显示全部楼层 |阅读模式
TE, TI, IO, ST, AN
2015年及以后毕业实习生岗位:
1. Bench Validation Engineer (TI Beijing R&D Center)
BASIC / KEY Qualifications:
  • · Require a BSEE degree or above with related experience at IC test field
    · Strong skills of handling electronics measurement instruments
    · Hardware development experience is a plus
    · Lab automation experience is a plus (LabVIEW)
Responsibilities:
· Work out product bench validation plan at early phase of new product development
· Evaluate test solution and review with core team
· Develop test HW (considering test methodology and automation capability)
· Develop test software (Lab automation)
· First silicon 24Hrs wake-up test and 30 days full validation
· Support ATE/Application correlation test
· Collect characterization data over different test conditions
Requirements:
· Good understanding of the IC test methodology.
· Be familiar with some basic lab equipment (digital multi-meter, oscilloscope, source meter, power supply)
· Good written and verbal English (CET-4 at least)
· Good communication skills with cross functions and team work
· Good planning and documentation sense.
· Be flexible to support some work from other functions.
· Be flexible to travel (domestic and international)
2. Digital IC Design Intern (TI Beijing R&D Center)
http://my.yingjiesheng.com/job_363626.html
Requirements
1. Candidate must possess or be pursuing a Master’s degree in EE.
2. Graduation date of Fall 2014 or later
3. Understand VLSI design
3. Skilled at Hardware Description Language, Verilog/SystemVerilog/VHDL
4. Familiar with modern digital design flow
4. Self-motivated and good communication skills
5. Good written and verbal English
Responsibility
1. Verification
--Develop verification test bench with System Verilog/Verilog to improve test coverage
--Modify and reuse existing IP
--Improve existing verification/simulation environment
2. RTL design
--Fix and modify existing design using Verilog
3. Technical writing
--Update design spec
--Generate reports of test results
4. Communication
--Effective communication with team in China and US
了解详情请点击→http://www.deyisupport.com/blog/b/tihire/archive/2014/03/10/51635.aspx
hxfxt 发表于 2014-3-10 14:15 | 显示全部楼层
支持一下....就是有点远呢.........
z00 发表于 2014-3-10 15:13 | 显示全部楼层
支持一下
cxz_00 发表于 2014-3-10 18:55 | 显示全部楼层
支持一下!!
胡斯哲 发表于 2014-3-11 00:04 | 显示全部楼层
瞄一瞄
陌路绝途 发表于 2014-3-11 08:40 | 显示全部楼层
支持一下!!
youluo235 发表于 2014-3-11 12:57 | 显示全部楼层
一直很向往TI来的,就是英语是硬伤。
xuan309170083 发表于 2014-3-11 15:01 | 显示全部楼层
很可惜以前没看到啊
强仔00001 发表于 2014-3-11 16:23 | 显示全部楼层
支持一下
支持一下
visionary 发表于 2014-3-12 12:05 | 显示全部楼层
北京有点远啊
fjjjnk1234 发表于 2014-3-17 20:06 | 显示全部楼层
支持一下:lol
yhsy1002 发表于 2014-3-17 22:45 | 显示全部楼层
顶,给力  必须支持
Imakey 发表于 2014-3-19 09:45 来自手机 | 显示全部楼层
一直很向往ti啊!~
kk5290122 发表于 2014-3-29 21:49 | 显示全部楼层
这个英文的应该和那个中文的一样的吧??
waitingf 发表于 2014-3-30 22:22 | 显示全部楼层
怀念刚毕业的时光
someonewho 发表于 2014-3-30 22:43 | 显示全部楼层
不可错过呦
heibaiyinjiag 发表于 2014-3-30 22:50 | 显示全部楼层
为什么一样的帖子要发两个语言的呢
justbybing 发表于 2014-3-30 23:03 | 显示全部楼层
看来去TI工作的前提是英语要好呀
sishangcine 发表于 2014-3-30 23:05 | 显示全部楼层
很向往去ti工作
2931
