请各位网友看看如何读写这个eeprom
6597|44
 楼主| xbyu520 发表于 2014-3-11 13:04 | 显示全部楼层 |阅读模式
这是我的程序,总是写不进去。各位大师帮忙看看/谢谢各位了!
#include<reg52.h>
#include <soft_delay.h>
sbit scl=P2^0;                                                //¶ÔÓ¦c8051f340¿ª·¢°åscl
sbit sda=P2^1;                                                //¶ÔÓ¦c8051f340¿ª·¢°åsda
sbit led=P2^4;                                                //¹¤×÷ָʾµÆ
void start()                        //¿ªÊ¼ÐźÅ
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()                        //½áÊøÐźÅ
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()                        //Ó¦´ðÐźÅ
        uchar i;
        scl=1;
        delay();
        while((sda==1)&&(i<250))
                i++;
        scl=0;
        delay();
void init()
        sda=1;
        delay();
        scl=1;
        delay();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay();
                sda=CY;
                delay();
                scl=1;
                delay();
                scl=0;
                delay();
                sda=1;
          delay();
uchar read_byte()
                uchar i,k;
                scl=0;
                delay();
                sda=1;
                delay();
                for(i=0;i<8;i++)
                        scl=1;
                        delay();
                        k=(k<<1)|sda;
                        scl=0;
                        delay();
                        return k;
/*Ö¸¶¨µØÖ·¶ÁÒ»¸ö×Ô¼ºµÄº¯Êý*/
uchar read_add(uchar address)
          uchar date;
                start();
                write_byte(0xa0);
                respons();
                write_byte(address);
                respons();
                start();
                write_byte(0xa1);
                respons();
                date=read_byte();
                stop();
                return date;
/*Ö¸¶¨µØÖ·Ð´Ò»¸ö×ֽڵĺ¯Êý*/
void write_add(uchar address,uchar date)
                start();
                write_byte(0xa0);
                respons();
                respons();
                write_byte(date);
                respons();
                stop();
uchar p;
void main()
                init();
                write_add(0x00,0x99);
                p=read_add(0x00);
                if(p==0x99)
                        led=~led;
                        delay();
                        delay();
                else
                        led=0;
 楼主| xbyu520 发表于 2014-3-11 13:10 | 显示全部楼层
#include<reg52.h>
sbit scl=P2^0;
sbit sda=P2^1;
sbit led=P2^4;
void start()                        //总线开始信号
        sda=1;
        delay();
        scl=1;
        delay();
        sda=0;
        delay();
void stop()                        //总线结束信号
        sda=0;
        delay();
        scl=1;
        delay();
        sda=1;
        delay();
void respons()                        //总线应答信号
        uchar i;
        scl=1;
        delay();
                i++;
        scl=0;
        delay();
void init()                        //总线初始化
        sda=1;
        delay();
        scl=1;
        delay();
void write_byte(uchar date)           //写字节函数
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay();
                sda=CY;
                delay();
                scl=1;
                delay();
                scl=0;
                delay();
                sda=1;
          delay();
uchar read_byte()                    //读字节函数
                uchar i,k;
                scl=0;
                delay();
                sda=1;
                delay();
                for(i=0;i<8;i++)
                        scl=1;
                        delay();
                        k=(k<<1)|sda;
                        scl=0;
                        delay();
                        return k;
/*指定地址读一个字节的函数*/
          uchar date;
                start();
                write_byte(0xa0);
                respons();
                respons();
                start();
                write_byte(0xa1);
                respons();
                date=read_byte();
                stop();
                return date;
/*指定地址写一个字节的函数*/
                start();
                write_byte(0xa0);
                respons();
                respons();
                write_byte(date);
                respons();
                stop();
uchar p;
void main()                   //主函数
                init();
                p=read_add(0x00);           //写进去后再读出来。看看写的对不对。
                if(p==0x99)                     //写的对不对,用这个灯指示一下了
                        led=~led;
                        delay();
                        delay();
                else
                        led=0;
 楼主| xbyu520 发表于 2014-3-11 13:11 | 显示全部楼层
#define uchar unsigned char
void delay()
        uchar j1,j2;
        for(j1=0;j1<50;j1++)
//        for(t=0;t<255;t++)
        for(j2=0;j2<100;j2++);
 楼主| xbyu520 发表于 2014-3-11 13:12 | 显示全部楼层
void delay()
        uchar j1,j2;
 楼主| xbyu520 发表于 2014-3-11 13:13 | 显示全部楼层
延时函数长一点应该没什么问题吧。
是eeprom  24c02  单片机STC89c54Rd+
 楼主| xbyu520 发表于 2014-3-11 13:14 | 显示全部楼层
11.0592Mhz的晶振
 楼主| xbyu520 发表于 2014-3-11 13:38 | 显示全部楼层
为什么写不进去呢????各位来看看啊
 楼主| xbyu520 发表于 2014-3-11 13:55 | 显示全部楼层
自己顶
晓妖不成精a 发表于 2014-3-11 14:01 | 显示全部楼层
http://www.****ducst/datasheet/ ... +_GUIDE-CHINESE.pdf      不知道这个系列的资料能不能帮到你,第九章EEPROM的应用
 楼主| xbyu520 发表于 2014-3-11 15:04 | 显示全部楼层
晓妖不成精a 发表于 2014-3-11 16:07 | 显示全部楼层
坐等大师
liudanwei 发表于 2014-3-11 16:28 | 显示全部楼层
你确定是写不进去。
 楼主| xbyu520 发表于 2014-3-11 16:32 | 显示全部楼层
根据led指示灯,判断没写进去或者没读出来。
 楼主| xbyu520 发表于 2014-3-11 16:34 | 显示全部楼层
你确定是写不进去。
根据led指示灯,判断没写进去或者没读出来。反正就是感觉读写不正常
 楼主| xbyu520 发表于 2014-3-11 16:35 | 显示全部楼层
坐等大师
 楼主| xbyu520 发表于 2014-3-11 16:39 | 显示全部楼层
WP连接“地”。SDA 和SCL连接IO口。程序就是上面的程序。晶振11.0592MHz.单片机是传统单片机STC89C54RD+
liudanwei 发表于 2014-3-11 16:49 | 显示全部楼层
那就先判断是否写进去了,
ningling_21 发表于 2014-3-11 17:17 | 显示全部楼层
WP连接“地”。SDA 和SCL连接IO口。程序就是上面的程序。晶振11.0592MHz.单片机是传统单片机STC89C54RD+ ...
总线没有上拉电阻吗?
highend 发表于 2014-3-11 20:10 | 显示全部楼层
嗯,电阻,很重要。 可以示波器一下
个人签名:工作不养闲人,团队不养懒人。赚不到钱赚知识,赚不到知识赚经历,赚不到经历赚阅历,让人迷茫的原因只有一
43
