[FPGA] 提问 仿真时outs和hex没有信号
1565|7
 楼主| 关耳008 发表于 2014-3-13 07:42 | 显示全部楼层 |阅读模式
module dj (clk_27m,rst_n,fangxiang,sudu,outf,outs,count_gd,HEX1,HEX2,HEX3,HEX4);
     input clk_27m;
     input rst_n;
     input fangxiang;
     input sudu;
     input count_gd;
     output outf,outs;
     output [6:0]HEX1,HEX2,HEX3,HEX4;
     reg outf;
     wire outs;
     reg en;
  always @ ( negedge rst_n or posedge clk_27m)
if (!rst_n)
     outf<=0;
   else outf<=(fangxiang?1:0);
  reg delay;
always @ (sudu)
case (sudu)
4'b0001:delay<=9'd100;
4'b0011:delay<=9'd200;
4'b0111:delay<=9'd300;
4'b1111:delay<=9'd400;
endcase
speed_control u1(.clk(clk_27m),.rst(rst_n),.yanchi(delay),.shuchu(outs));
reg count;
always @ (posedge clk_27m )
if (!rst_n) count<=0;
else if (count==27000000)
begin en<=1;count<=0;end
else
begin en<=0;count<=count+1;end
    reg [3:0]    cs_ge;
    reg [3:0]    cs_shi;
    reg [3:0]    cs_bai;
    reg [3:0]    cs_qian;
always @ (negedge count_gd)
if (!rst_n)
     begin
     cs_ge <= 4'd0;
                    cs_shi <= 4'd0;
                    cs_bai <= 4'd0;
                    cs_qian <= 4'd0;
     end
else if (en)
    begin
                    cs_ge <= 4'd0;
                    cs_shi <= 4'd0;
                    cs_bai <= 4'd0;
                    cs_qian <= 4'd0;
    end
else
        begin
            if(cs_ge==4'd9 && cs_shi<4'd10 && cs_bai<4'd10 && cs_qian<4'd10)
                begin
                    cs_ge <= 4'd0;
                    cs_shi <= cs_shi + 4'd1;
                    if(cs_shi == 4'd9 && cs_bai<4'd10 && cs_qian<4'd10)
                        begin
                            cs_shi <= 4'd0;
                            cs_bai <= cs_bai + 4'd1;
                        end
                    if(cs_bai == 4'd9 && cs_qian<4'd10)
                        begin
                            cs_bai <= 4'd0;
                            cs_qian <= cs_qian + 4'd1;
                        end
                end
            else if(cs_qian==4'd10 && cs_bai==4'd9 && cs_shi==4'd9 && cs_ge==4'd9)
                begin
                    cs_ge <= 4'd0;
                    cs_shi <= 4'd0;
                    cs_bai <= 4'd0;
                    cs_qian <= 4'd0;
                end
            else
                begin
                    cs_ge <= cs_ge + 4'd1;
                end
        end
reg [6:0]HEX01,HEX02,HEX03,HEX04;
always @ (cs_qian)
  case (cs_qian)
4'd0:HEX01=7'd192;
4'd1:HEX01=7'd249;
4'd2:HEX01=7'd164;
4'd3:HEX01=7'd176;
4'd4:HEX01=7'd153;
4'd5:HEX01=7'd146;
4'd6:HEX01=7'd130;
4'd7:HEX01=7'd1248;
4'd8:HEX01=7'd128;
4'd9:HEX01=7'd144;
endcase
always @ (cs_bai)
  case (cs_bai)
4'd0:HEX02=7'd192;
4'd1:HEX02=7'd249;
4'd2:HEX02=7'd164;
4'd3:HEX02=7'd176;
4'd4:HEX02=7'd153;
4'd5:HEX02=7'd146;
4'd6:HEX02=7'd130;
4'd7:HEX02=7'd1248;
4'd8:HEX02=7'd128;
4'd9:HEX02=7'd144;
endcase
always @ (cs_shi)
  case (cs_shi)
4'd0:HEX03=7'd192;
4'd1:HEX03=7'd249;
4'd2:HEX03=7'd164;
4'd3:HEX03=7'd176;
4'd4:HEX03=7'd153;
4'd5:HEX03=7'd146;
4'd6:HEX03=7'd130;
4'd7:HEX03=7'd1248;
4'd8:HEX03=7'd128;
4'd9:HEX03=7'd144;
endcase
always @ (cs_ge)
  case (cs_ge)
4'd0:HEX04=7'd192;
4'd1:HEX04=7'd249;
4'd2:HEX04=7'd164;
4'd3:HEX04=7'd176;
4'd4:HEX04=7'd153;
4'd5:HEX04=7'd146;
4'd6:HEX04=7'd130;
4'd7:HEX04=7'd1248;
4'd8:HEX04=7'd128;
4'd9:HEX04=7'd144;
endcase
assign HEX1=HEX01;
assign HEX2=HEX02;
assign HEX3=HEX03;
assign HEX4=HEX04;
endmodule
module speed_control (clk,rst,yanchi,shuchu);
input clk;
input rst;
input  yanchi;
output shuchu;
wire shuchu;
reg shuch;
reg wahaha;
always@(posedge clk)
if (!rst)
  shuch<=0;
  else if(wahaha==yanchi)
  begin shuch<=1;wahaha=0;end
  else begin shuch<=0;wahaha<=wahaha+1;end
assign shuchu=shuch;
endmodule
这是测试的脚本
initial
begin
rst_n=0;
#10 rst_n=1;
fangxiang=1;
clk_27m=0;
count_gd=0;
sudu=4'b0001;
end
always
begin
#10 clk_27m=~clk_27m;
#10 count_gd=~count_gd;
end
谢谢了
zhaojingzb 发表于 2014-3-13 08:54 | 显示全部楼层
 楼主| 关耳008 发表于 2014-3-13 12:04 | 显示全部楼层
贴图
后面都没变化  麻烦了
liudanwei 发表于 2014-3-13 16:32 | 显示全部楼层
这个问题貌似我也遇到过。
 楼主| 关耳008 发表于 2014-3-13 18:16 | 显示全部楼层
这个问题貌似我也遇到过。
我要疯掉了=。-你最后是怎么解决的啊
 楼主| 关耳008 发表于 2014-3-13 20:30 | 显示全部楼层
:(:(:(:(苦恼啊~~~
liudanwei 发表于 2014-3-14 08:06 | 显示全部楼层
我要疯掉了=。-你最后是怎么解决的啊
我用的是VHDL当时也是有几个信号没波形,是因为testbech中信号没有初始化。后来给初始化就解决了。
 楼主| 关耳008 发表于 2014-3-14 19:24 | 显示全部楼层
我用的是VHDL当时也是有几个信号没波形,是因为testbech中信号没有初始化。后来给初始化就解决了。 ...
直接rst重置了的话  应该是没有这个问题了吧
