和之前我自己编译的可以运行的程序比较了一下:
mxc_vpu_test.out: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, not stripped
mxc_vpu_test.out: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.26, not stripped
发现其他都一样,Linux版本不同,难道有关系?
