时钟的代码为什么跑不起来?
1143|1
 楼主| u880 发表于 2014-3-19 21:51 | 显示全部楼层 |阅读模式
#include<msp430x16x.h>
#define uint unsigned int
#define uchar unsigned char
#define pkey (P1IN&0X0F)
uchar sec=0,min=0,hor=0;
/*延时子程序*/
void delay(uint z)
  while(z--);
/*write LCD command code*/
void LCDcommand(uchar wdata)
  P6OUT&=~0X08;//clear RS
  P6OUT&=~0X10;//clear RW
  P6OUT&=~0X20;//clear E
  delay(100);
  P6OUT|=0X20;//SET UP E
  P2OUT=wdata;//sent command or data
  delay(100);
/*write data*/
void  LCDdata(uint wdata)
  P6OUT|=0X08;//SET RS
  delay(100);
  delay(100);//delay instead of check busy
/*init LCD*/
void LCD_init(void)
  LCDcommand(0x38);//all secrean
  delay(200);
  LCDcommand(0x01);//clear display
  LCDcommand(0x0c);
  LCDcommand(0x06);
////////////////////////设置光标显示,x行号y列号
void display_xy(uchar x,uchar y)
  if(y)
    x+=0x80+0x40;
  else
    x+=0x80;
  LCDcommand(x);
////////////////////////在光标位置显示字符串
void display_1(uchar m,uchar n,uchar data)
  display_xy(m,n);
    LCDdata(data);
////////////////////////clock program
void clock(void)
  sec++;
  if(sec==60)
    sec=0;
    min++;
  if(min==60)
    min=0;
    hor++;
  if(hor==24)
    hor=0;
////////////////////////display
void display(void)
  uchar sec0,sec1,min0,min1,hor0,hor1;
  sec1=sec/10;
  sec0=sec-sec1*10;
  min1=min/10;
  min0=min-min1*10;
  hor1=hor/10;
  hor0=hor-hor1*10;
  sec1+=48;
  sec0+=48;
  min1+=48;
  min0+=48;
  hor1+=48;
  hor0+=48;
  display_1(11,1,sec0);
  display_1(10,1,sec1);
  display_1(9,1,':');
  display_1(8,1,min0);
  display_1(7,1,min1);
  display_1(6,1,':');
  display_1(5,1,hor0);
  display_1(4,1,hor1);
///////////////////////////keyscan
void keyscan(void)
  uchar temp;
  if(pkey!=0X0F)
    delay(200);
    if(pkey!=0x0f)
      temp=pkey;
      switch(temp)
      case 0x0e: sec++;break;
      case 0x0d: min++;break;
      case 0x0b: hor++;break;
//      case 0x07: hor++;break;
      default:break;
///////////////////////////main program
int main(void)
  WDTCTL=WDTPW+WDTHOLD;//CLOSE DOG
  P2DIR=0XFF;
  P6DIR=0XFF;
  LCD_init();
  CCR0=32768-1;
  TACTL=TASSEL_1+MC_1;
  CCTL0|=CCIE;
  _EINT();
  while(1)
    LPM3;
    display();
    keyscan();
#pragma vector = TIMERA0_VECTOR
__interrupt void Timer_A (void)
  clock();
  LPM3_EXIT;
 楼主| u880 发表于 2014-3-19 21:52 | 显示全部楼层
求各位大神帮忙看一看吧
