编译时总是出现如下错误
1375|6
 楼主| guoyt 发表于 2014-3-20 20:05 | 显示全部楼层 |阅读模式
ADD: sdb.M0059: error: Error in component: cy_boot. The cy_boot_v1_10 component (cy_boot) is an Obsolete component. It is no longer recommended for use and should be replaced with a production version of the component (or an alternative implementation).
Error: cdf.M0005: CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. (App=cydsfit)
hanwe 发表于 2014-3-20 20:06 | 显示全部楼层
芯片选择对了么
yufe 发表于 2014-3-20 21:29 | 显示全部楼层
是否用高版本去编译低版本的例程
llia 发表于 2014-3-20 21:32 | 显示全部楼层
程序升级是否完整,我有过升级一半我嫌慢就取消掉了,后来就再也不能用只能重新装一遍的情况了
wangzsa 发表于 2014-3-20 21:34 | 显示全部楼层
你的文件是在“我的文档下面吗”,
langgq 发表于 2014-3-20 21:35 | 显示全部楼层
Currently, PSoC Creator does not support building a project from a network share drive. Typically, “My Documents” or equivalent folder is seen as a shared network folder by Windows running on Parallels Desktop. Please save the project in a local folder (say C:\Documents and Settings\User\...) and rebuild the example project.
 楼主| guoyt 发表于 2014-3-20 21:38 | 显示全部楼层
哦,我看看
