[STM8] STM8L LCD频率问题 固件库注释错误?
1875|2
 楼主| FAQ 发表于 2014-3-26 12:24 | 显示全部楼层 |阅读模式
MCU:stm8L152驱动LCD。
下面是固件库里面的例子代码。
怀疑注释(红色部分的计算结果228Hz和57Hz)是错误的。
我认为应该是下面这样的。
LCD frequency =455Hz
Frame frequency = 455/4=113Hz。
做过的朋友你们有没有注意到这个问题。
  * @brief  Configures the LCD GLASS relative GPIO port IOs and LCD peripheral.
  * @param  None
  * @retval None
void LCD_GLASS_Init(void)
    The LCD is configured as follow:
     - clock source = LSE (32.768 KHz)
     - Voltage source = Internal
     - Prescaler = 2
     - Divider = 18 (16 + 2)
     - Mode = 1/4 Duty, 1/3 Bias
     - LCD frequency = (clock source * Duty) / (Prescaler * Divider)
                     = 228 Hz ==> Frame frequency = 57 Hz
  /* Enable LCD clock */
  CLK_PeripheralClockConfig(CLK_Peripheral_LCD, ENABLE);
  CLK_RTCClockConfig(CLK_RTCCLKSource_LSE, CLK_RTCCLKDiv_1);
  /* Initialize the LCD */
  LCD_Init(LCD_Prescaler_2, LCD_Divider_18, LCD_Duty_1_4,
           LCD_Bias_1_3, LCD_VoltageSource_Internal);
  /* Mask register*/
  LCD_PortMaskConfig(LCD_PortMaskRegister_0, 0xFF);
  LCD_PortMaskConfig(LCD_PortMaskRegister_1, 0xFF);
  LCD_PortMaskConfig(LCD_PortMaskRegister_2, 0xFF);
  LCD_PortMaskConfig(LCD_PortMaskRegister_3, 0xFF);
  LCD_ContrastConfig(LCD_Contrast_3V3);
  LCD_DeadTimeConfig(LCD_DeadTime_0);
  LCD_PulseOnDurationConfig(LCD_PulseOnDuration_1);
  LCD_Cmd(ENABLE); /*!< Enable LCD peripheral */
baishuiyang 发表于 2014-4-20 21:49 | 显示全部楼层
没碰到过哎
vergoo 发表于 2015-1-29 15:29 | 显示全部楼层
啥意思啊?
FAQ
233
