[嵌入式linux] Leaving directory `/usr/local/arm/tslib/src' 找不到
1413|0
 楼主| leifukes 发表于 2014-3-27 20:53 | 显示全部楼层 |阅读模式
[root@localhost tslib]# make 2>&1 | tee make_log
make  all-recursive
make[1]: Entering directory `/usr/local/arm/tslib'
Making all in etc
make[2]: Entering directory `/usr/local/arm/tslib/etc'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/usr/local/arm/tslib/etc'
Making all in src
make[2]: Entering directory `/usr/local/arm/tslib/src'
/bin/sh ../libtool --tag=CC   --mode=compile /usr/local/arm/4.4.1/bin/arm-linux-gcc -DHAVE_CONFIG_H -I. -I..    -DPLUGIN_DIR=\"/usr/local/lib/ts/\" -DTS_CONF=\"/usr/local/etc/ts.conf\"  -DTSLIB_INTERNAL -fvisibility=hidden -DGCC_HASCLASSVISIBILITY -O2 -Wall -W -MT ts_attach.lo -MD -MP -MF .deps/ts_attach.Tpo -c -o ts_attach.lo ts_attach.c
../libtool: line 829: X--tag=CC: command not found
../libtool: line 862: libtool: ignoring unknown tag : command not found
../libtool: line 829: X--mode=compile: command not found
../libtool: line 996: *** Warning: inferring the mode of operation is deprecated.: command not found
../libtool: line 997: *** Future versions of Libtool will require --mode=MODE be specified.: command not found
../libtool: line 1140: X/usr/local/arm/4.4.1/bin/arm-linux-gcc: No such file or directory
../libtool: line 1140: X-DHAVE_CONFIG_H: command not found
../libtool: line 1140: X-I.: command not found
../libtool: line 1140: X-I..: command not found
../libtool: line 1140: X-DPLUGIN_DIR="/usr/local/lib/ts/": No such file or directory
../libtool: line 1140: X-DTS_CONF="/usr/local/etc/ts.conf": No such file or directory
../libtool: line 1140: X-DTSLIB_INTERNAL: command not found
../libtool: line 1140: X-fvisibility=hidden: command not found
../libtool: line 1140: X-DGCC_HASCLASSVISIBILITY: command not found
../libtool: line 1140: X-O2: command not found
../libtool: line 1140: X-Wall: command not found
../libtool: line 1140: X-W: command not found
../libtool: line 1140: X-MT: command not found
../libtool: line 1140: Xts_attach.lo: command not found
../libtool: line 1140: X-MD: command not found
../libtool: line 1140: X-MP: command not found
../libtool: line 1140: X-MF: command not found
../libtool: line 1140: X.deps/ts_attach.Tpo: No such file or directory
../libtool: line 1140: X-c: command not found
../libtool: line 1193: Xts_attach.lo: command not found
../libtool: line 1198: libtool: compile: cannot determine name of library object from `': command not found
make[2]: *** [ts_attach.lo] 错误 1
make[2]: Leaving directory `/usr/local/arm/tslib/src'
make[1]: *** [all-recursive] 错误 1
make[1]: Leaving directory `/usr/local/arm/tslib'
make: *** [all] 错误 2
郁闷死了,不知道怎么回事,在此求助
