ccs4.2编译错误
3633|6
 楼主| 漠漠 发表于 2014-3-28 22:50 | 显示全部楼层 |阅读模式
:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/cmd/28335_RAM_lnk.cmd', needed by `Example_2833xGpioToggle.out'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_headers/cmd/DSP2833x_Headers_nonBIOS.cmd', needed by `Example_2833xGpioToggle.out'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_ADC_cal.asm', needed by `DSP2833x_ADC_cal.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_CodeStartBranch.asm', needed by `DSP2833x_CodeStartBranch.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_DefaultIsr.c', needed by `DSP2833x_DefaultIsr.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_headers/source/DSP2833x_GlobalVariableDefs.c', needed by `DSP2833x_GlobalVariableDefs.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_PieCtrl.c', needed by `DSP2833x_PieCtrl.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_PieVect.c', needed by `DSP2833x_PieVect.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_SysCtrl.c', needed by `DSP2833x_SysCtrl.obj'.
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** No rule to make target `D:/dsp/DSP2833x_common/source/DSP2833x_usDelay.asm', needed by `DSP2833x_usDelay.obj'.
'C:\Users\M' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
系统找不到指定的路径。
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: *** [Example_2833xGpioToggle.obj] Error 1
D:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake: Target `all' not remade because of errors.
Build complete for project Example_2833xGpioToggle
这是什么问题?求高手解决
zhangmangui 发表于 2014-3-28 23:15 | 显示全部楼层
具体说不好  是什么原因
也可能是缺少一个文件引起的
 楼主| 漠漠 发表于 2014-3-28 23:33 | 显示全部楼层
具体说不好  是什么原因
也可能是缺少一个文件引起的
或批处理文件。
系统找不到指定的路径。
这一句话好像说的哪里没设置好   我之前装过一次没出现这样的问题 今天装不知道为什么会出现这个
zhangmangui 发表于 2014-3-28 23:43 | 显示全部楼层
或批处理文件。
系统找不到指定的路径。
不太清楚啦   没遇到过的
 楼主| 漠漠 发表于 2014-3-29 13:40 | 显示全部楼层
不太清楚啦   没遇到过的
解决了 分享一下~我的计算机名字中有&字符 算是非法字符 再给计算机起个名 用另一个账户登录就没问题了
WYT440 发表于 2014-3-29 14:35 | 显示全部楼层
解决了 分享一下~我的计算机名字中有&字符 算是非法字符 再给计算机起个名 用另一个账户登录就没问题了 ...
楼主厉害,这种原因都找的到!!感谢楼主无私分享解决方案
zhangmangui 发表于 2014-3-29 15:23 | 显示全部楼层
好吧   楼主确实厉害  这种问题找到解决了
