关于直流无刷电机测速问题
3569|9
 楼主| G21372 发表于 2014-3-30 17:13 | 显示全部楼层 |阅读模式
现在想用dsp2808的ecap口对直流无刷电机的霍尔信号进行测速。我设置CEVT4时间后触发cap1中断(其中CAP1POL1与CAP1POL3为上升沿触发,CAP1POL2与CAP1POL4为下降沿触发)。问题是现在我给cap口一个pwm信号(2.5kHz)进行频率测试的时候,发现捕获寄存器cap1~cap4的值都是相等的,请问我是哪里出问题了呢?
 楼主| G21372 发表于 2014-3-30 17:14 | 显示全部楼层
具体设置如下:
void InitECapture()
   ECap1Regs.ECCTL2.bit.CAP_APWM=0;//工作于捕获模式
   ECap1Regs.CAP1=0x00000000;
   ECap1Regs.CAP2=0x00000000;
   ECap1Regs.CAP3=0x00000000;
   ECap1Regs.CAP4=0x00000000;
   ECap1Regs.ECEINT.all=0x0000;//屏蔽eCAP1所有中断
//  ECap1Regs.ECCTL1.all=0xFFFF;
   ECap1Regs.ECCLR.all=0xFFFF;//清除所有中断标志位
   ECap1Regs.ECCTL1.bit.CAPLDEN=0;//Disable CAP1~CAP4 register loads
   ECap1Regs.ECCTL2.bit.TSCTRSTOP = 0; // Make sure the counter is stopped
//configure peripheral registers
   ECap1Regs.ECCTL2.bit.CONT_ONESHT=0;//工作于连续捕获模式
   ECap1Regs.ECCTL2.bit.STOP_WRAP=3;  //Stop at 4 events
   ECap1Regs.ECCTL1.bit.CAP1POL=0;  //CEVT1:上升沿捕获
   ECap1Regs.ECCTL1.bit.CAP2POL=1;
   ECap1Regs.ECCTL1.bit.CAP3POL=0;
   ECap1Regs.ECCTL1.bit.CAP4POL=1;
   ECap1Regs.ECCTL1.bit.CTRRST1=1;// Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST2=1;// Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST3=1;// Difference operation
   ECap1Regs.ECCTL1.bit.CTRRST4=1;// Difference operation
   ECap1Regs.ECCTL2.bit.SYNCI_EN=0;// Enable sync in
   ECap1Regs.ECCTL2.bit.SYNCO_SEL=2;// Pass through
   ECap1Regs.ECCTL1.bit.PRESCALE=60;
   ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1; // Start Counter
   ECap1Regs.ECCTL1.bit.CAPLDEN=1;//使能捕获事件发生时间装载到捕获寄存器CAP1~Cap4
   ECap1Regs.ECEINT.bit.CEVT4 = 1;
中断执行函数如下
interrupt void  cap_isr(void)
// ECap1Regs.ECCTL1.bit.CAPLDEN=1;
// ECap2Regs.ECCTL1.bit.CAPLDEN=1;
// ECap1Regs.EC标志寄存器.bit.CEVT1=0;
// ECap1Regs.EC标志寄存器.bit.CEVT2=0;
// ECap1Regs.EC标志寄存器.bit.CEVT3=0;
// ECap1Regs.EC标志寄存器.bit.CEVT4=0;
    ECap1Regs.ECCLR.bit.CEVT4 = 1;
    ECap1Regs.ECCLR.bit.INT = 1;
ECap1Regs.ECCTL2.bit.REARM = 1;//持续捕捉外部信号
//    ECap1Regs.ECCLR.all=0xFFFF;
PieCtrlRegs.PIEACK.all = PIEACK_GROUP4;   // Acknowledge interrupt to PIE
// PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
TSt1_Up1=ECap1Regs.CAP1;
    TSt1_Down1=ECap1Regs.CAP2;
    TSt1_Up2=ECap1Regs.CAP3;
TSt1_Down2=ECap1Regs.CAP4;
return;
zhangmangui 发表于 2014-3-30 20:38 | 显示全部楼层
这个问题在哪儿看到过
taihezhibanh 发表于 2014-3-30 22:38 | 显示全部楼层
友情帮顶 不是特别懂所以不敢乱说
拿起书本 发表于 2014-3-31 15:11 | 显示全部楼层
楼主定时器的时钟是如何配置的呢?如果捕获同一个定时器的值
上升沿和下降沿捕获的值不应该是相等的。
木旗 发表于 2014-6-23 20:15 | 显示全部楼层
请问楼主这个问题怎么解决的?为什么4个cap值都是一样的呢?
comeon201208 发表于 2014-6-23 21:51 | 显示全部楼层
这个不是很理解的,,先了解下的
vivilzb1985 发表于 2014-6-27 22:16 | 显示全部楼层
直流电机测速,,需要一定的外围测试工具的才可以的吧。
STARshc01 发表于 2014-7-2 16:49 | 显示全部楼层
可以考虑通过检测霍尔信号来计算出转速,我是这么做的,精度还不错
pp1231 发表于 2014-11-18 20:53 | 显示全部楼层
你好,你做好的用霍尔信号测无刷电机的转速实验程序和相关资料能不能发给我,我的邮箱[email]1271214347@qq.com谢谢了啊
