ATMEL 9260开发板、核心板优惠价
2464|2
 楼主| rwdx 发表于 2008-4-15 22:20 | 显示全部楼层 |阅读模式
<br />https://bbs.21ic.com/upfiles/img/20075/2007531221726116.jpg<br />AT91SAM9260介绍:<br />&gt&gt&nbsp;带Java扩展的ARM926EJ-S内核,&nbsp;2&nbsp;x&nbsp;8KB快取,&nbsp;MMU<br />&gt&gt&nbsp;2x4k&nbsp;Bytes&nbsp;SRAM,&nbsp;32kBytes&nbsp;Boot&nbsp;ROM<br />&gt&gt&nbsp;210MHz,&nbsp;230MIPs<br />&gt&gt&nbsp;EBI&nbsp;–可支持SDRAM,&nbsp;NAND&nbsp;Flash&nbsp;(带ECC)和Compact&nbsp;Flash<br />&gt&gt&nbsp;USB控制器和USB器件口,&nbsp;V2.0全速<br />&gt&gt&nbsp;Ethernet&nbsp;MAC&nbsp;-&nbsp;10/100<br />&gt&gt&nbsp;图像传感器界面&nbsp;(CMOS传感器界面)<br />&gt&gt&nbsp;1&nbsp;SSC可支持I2S和TDM<br />&gt&gt&nbsp;2&nbsp;SPI,&nbsp;MCI&nbsp;(SDCard和MMC兼容),&nbsp;TWI<br />&gt&gt&nbsp;6&nbsp;USARTs,&nbsp;支持IrDA,&nbsp;ISO7816&nbsp;T=0/T=1,&nbsp;RS485<br />&gt&gt&nbsp;1调试UART<br />&gt&gt&nbsp;4-通道&nbsp;10位ADC<br />&gt&gt&nbsp;带实时定时器的后备电池供电模式<br />&gt&gt&nbsp;2&nbsp;OSCs,&nbsp;2&nbsp;PLLs和RTC<br />&gt&gt&nbsp;3.0到3.6&nbsp;Volt&nbsp;IO,1.65到1.95&nbsp;V内核电源,&nbsp;3.0到3.6V或1.95到3.0V&nbsp;Memory&nbsp;I/O<br />&gt&gt&nbsp;JTAG和边际扫描<br />&gt&gt&nbsp;PQFP208和LFBGA217<br /><br />核心板硬件介绍<br />&gt&gt&nbsp;CPU:AT91SAM9260<br />&gt&gt&nbsp;SDRAM:32M×2,两片HY57V561620构成32bit<br />&gt&gt&nbsp;NAND&nbsp;FLASH:128MB,一片K9F1G08<br />&gt&gt&nbsp;NOR&nbsp;FLASH:16MB,一片JS28F128<br />&gt&gt&nbsp;DATA&nbsp;FLASH(预留):2/4MB,一片AT45DB161D/AT45DB321D<br />&gt&gt&nbsp;RTC:PCF8563T<br />&gt&gt&nbsp;JTAG:JTAG调试接口,标准20PIN<br />&gt&gt&nbsp;电源:3.3V电源输入和3V&nbsp;RTC后备电源输入<br />&gt&gt&nbsp;扩展接口:数据、地址总线接口和剩余GPIO口通过2个80PIN双排插阵引出<br /><br />底板硬件介绍:<br />&gt&gt&nbsp;电源支持USB取电和DC&nbsp;5-18V输入<br />&gt&gt&nbsp;10/100M网络接口,带网络变压器和状态指示灯<br />&gt&gt&nbsp;USB&nbsp;2.0&nbsp;F-S&nbsp;Host端口,全兼容OHCI&nbsp;USB&nbsp;2.0&nbsp;F-S规格<br />&gt&gt&nbsp;USB&nbsp;2.0&nbsp;F-S&nbsp;Device端口,完全兼容OHCI&nbsp;USB&nbsp;2.0&nbsp;F-S规格<br />&gt&gt&nbsp;调试串口(TTL电平),可设置为普通串口<br />&gt&gt&nbsp;SD卡接口,无容量限制<br />&gt&gt&nbsp;3个LED状态指示灯<br />&gt&gt&nbsp;4路光耦隔离开关信号输入<br />&gt&gt&nbsp;2路继电器输出<br />&gt&gt&nbsp;一个JN5139&nbsp;Zigbee模块(选配)<br /><br />配件清单<br />CA9260开发板一块<br />Wiggler调试板一块<br />USB转串口板一块<br />USB连接线两条<br />配套DVD光盘一张<br /><br /><br />开发板优惠价:700<br />核心板优惠价:400<br />&nbsp;<br />联系:<br />淘宝:<a href="http://shop35609549.taobao.com/" target=_blank>http://shop35609549.taobao.com/</a><br />QQ:2505557<br />Email:<a href="mailto:rwdx@21cn.com">rwdx@21cn.com</a>
 楼主| rwdx 发表于 2008-4-17 20:28 | 显示全部楼层
 楼主| rwdx 发表于 2008-4-20 12:40 | 显示全部楼层
sdfsg
sgddgs
