[i.MX] 关于android编译环境的安装
2113|1
 楼主| lqland 发表于 2014-4-3 13:51 | 显示全部楼层 |阅读模式
虚拟机版本信息
ocean@ubuntu:~$ uname -r
3.11.0-19-generic
ocean@ubuntu:~$ sudo lsb_release -a
No LSB modules are available.
Distributor ID:        Ubuntu
Description:        Ubuntu 12.04.4 LTS
Release:        12.04
Codename:        precise
ocean@ubuntu:~$ uname -n
ubuntu
ocean@ubuntu:~$ uname -m
x86_64
安装包:
$ sudo apt-get install git gnupg flex bison gperf build-essential \
  zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev \
  libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 \
  libgl1-mesa-dev g++-multilib mingw32 tofrodos \
  python-markdown libxml2-utils xsltproc zlib1g-dev:i386
提示以下信息,是怎么回事:
ocean@ubuntu:~$ sudo apt-get install git gnupg flex bison gperf build-essential   zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev   libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386   libgl1-mesa-dev g++-multilib mingw32 tofrodos   python-markdown libxml2-utils xsltproc zlib1g-dev:i386
[sudo] password for ocean:
Reading package lists... Done
Building dependency tree
Reading state information... Done
gnupg is already the newest version.
libc6-dev is already the newest version.
libc6-dev set to manually installed.
zip is already the newest version.
zip set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: g++ (>= 4:4.4.3) but it is not installable
                   Depends: dpkg-dev (>= 1.13.5) but it is not going to be installed
g++-multilib:i386 : Depends: cpp:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: gcc-multilib:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++-4.6-multilib:i386 (>= 4.6.3-1~) but it is not going to be installed
git:i386 : Depends: perl-modules:i386 but it is not installable
            Depends: liberror-perl:i386 but it is not installable
            Depends: git-man:i386 (> 1:1.7.9.5) but it is not installable
            Depends: git-man:i386 (< 1:1.7.9.5-.) but it is not installable
            Recommends: less:i386 but it is not going to be installed
libgl1-mesa-dev : Depends: mesa-common-dev (= 8.0.4-0ubuntu0.7) or
                            mesa-common-dev-lts-quantal but it is not going to be installed or
                            mesa-common-dev-lts-raring but it is not going to be installed or
                            mesa-common-dev-lts-saucy but it is not going to be installed or
                            mesa-common-dev-lts-trusty but it is not installable
                   Depends: libxext-dev but it is not going to be installed
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 8.0.4-0ubuntu0.7)
                        Recommends: libgl1-mesa-dri:i386 (>= 7.2)
libx11-dev:i386 : Depends: x11proto-kb-dev:i386 but it is not installable
                   Depends: xtrans-dev:i386 but it is not installable
                   Recommends: libx11-doc:i386
x11proto-core-dev : Depends: xorg-sgml-doctools (>= 1:1.5) but it is not installable
E: Unable to correct problems, you have held broken packages.
FSL_TICS_ZJJ 发表于 2014-4-4 14:50 | 显示全部楼层
楼主,你好,你的问题已经转交I.MX工程师,他会回答你。
请耐心等待。
