[i.MX] 关于android编译环境的安装
3233|17
 楼主| lqland 发表于 2014-4-3 13:55 | 显示全部楼层 |阅读模式
我刚发的帖子“关于android编译环境的安装”
为何提示被删除了?
ocean@ubuntu:~$ sudo apt-get install git gnupg flex bison gperf build-essential \
>   zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev \
>   libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 \
>   libgl1-mesa-dev g++-multilib mingw32 tofrodos \
>   python-markdown libxml2-utils xsltproc zlib1g-dev:i386
[sudo] password for ocean:
Reading package lists... Done
Building dependency tree
Reading state information... Done
gnupg is already the newest version.
libc6-dev is already the newest version.
libc6-dev set to manually installed.
zip is already the newest version.
zip set to manually installed.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
build-essential : Depends: g++ (>= 4:4.4.3) but it is not installable
                   Depends: dpkg-dev (>= 1.13.5) but it is not going to be installed
g++-multilib:i386 : Depends: cpp:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: gcc-multilib:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++:i386 (>= 4:4.6.3-1ubuntu5) but it is not going to be installed
                     Depends: g++-4.6-multilib:i386 (>= 4.6.3-1~) but it is not going to be installed
git:i386 : Depends: perl-modules:i386 but it is not installable
            Depends: liberror-perl:i386 but it is not installable
            Depends: git-man:i386 (> 1:1.7.9.5) but it is not installable
            Depends: git-man:i386 (< 1:1.7.9.5-.) but it is not installable
            Recommends: less:i386 but it is not going to be installed
libgl1-mesa-dev : Depends: mesa-common-dev (= 8.0.4-0ubuntu0.7) or
                            mesa-common-dev-lts-quantal but it is not going to be installed or
                            mesa-common-dev-lts-raring but it is not going to be installed or
                            mesa-common-dev-lts-saucy but it is not going to be installed or
                            mesa-common-dev-lts-trusty but it is not installable
                   Depends: libxext-dev but it is not going to be installed
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 8.0.4-0ubuntu0.7)
                        Recommends: libgl1-mesa-dri:i386 (>= 7.2)
libx11-dev:i386 : Depends: x11proto-kb-dev:i386 but it is not installable
                   Depends: xtrans-dev:i386 but it is not installable
                   Recommends: libx11-doc:i386
x11proto-core-dev : Depends: xorg-sgml-doctools (>= 1:1.5) but it is not installable
E: Unable to correct problems, you have held broken packages.
我想安装android 的编译环境,上述提示是怎么回事?
是什么原因删除?
FSL_TICS_Rita 发表于 2014-4-3 14:19 | 显示全部楼层
是什么原因删除?
楼主你好,没有看到你新发的帖子呢,我们不可能删大家的帖子的。是不是你放在别的版块中了?
FSL_TICS_ZJJ 发表于 2014-4-3 14:21 | 显示全部楼层
可能是你自己不小心给删了,我也看到你之前的帖子,但是刷新之后,发现你的帖子不见了。
所以,你重新发一遍吧。
FSL_TICS_ZJJ 发表于 2014-4-3 14:33 | 显示全部楼层
你再发试试,如果重复被删除,你就找21ic小跑堂:https://bbs.21ic.com/space-username-21小跑堂.html
 楼主| lqland 发表于 2014-4-3 14:33 | 显示全部楼层
我的帖子,显示在“回收站”并被划一横线,请帮忙恢复,谢谢。
FSL_TICS_ZJJ 发表于 2014-4-3 14:34 | 显示全部楼层
我们权限不够,你需要找21ic小跑堂,5楼我给你链接了,你可以给他留言。
 楼主| lqland 发表于 2014-4-3 14:46 | 显示全部楼层
算了,重发一贴。
 楼主| lqland 发表于 2014-4-3 14:50 | 显示全部楼层
乖乖,又被删除了?
怎么回事?
哪里出问题了?
FSL_TICS_ZJJ 发表于 2014-4-3 14:52 | 显示全部楼层
乖乖,又被删除了?
怎么回事?
哪里出问题了?
会不会是你等级太低了,只能发几贴啊。
你赶紧找21ic小跑堂问问,给他留言。
要不然,你就直接在这个帖子问吧,
我会告诉I.MX工程师的。
 楼主| lqland 发表于 2014-4-3 14:53 | 显示全部楼层
我的帖子被删除之后,才发了这个咨询贴呢?怎么没有被删除?
FSL_TICS_ZJJ 发表于 2014-4-3 14:54 | 显示全部楼层
就在这里贴出你的问题,我转交I.MX工程师。
 楼主| lqland 发表于 2014-4-3 14:55 | 显示全部楼层
那被删除的原因,要说明一下吧,不然,我编辑好的帖子,被删除了,都不知道什么原因,下次又可能被删除。
FSL_TICS_ZJJ 发表于 2014-4-3 14:56 | 显示全部楼层
那被删除的原因,要说明一下吧,不然,我编辑好的帖子,被删除了,都不知道什么原因,下次又可能被删除。 ...
这个你真的要问小跑堂,我们还没有遇到被删情况,你要问问是不是你等级太低,是否有限制还什么的。
这个是21ic网站的原因,我们只能帮你解决飞思产品技术的问题。
 楼主| lqland 发表于 2014-4-3 14:58 | 显示全部楼层
小跑堂,离线中呢?
FSL_TICS_ZJJ 发表于 2014-4-3 15:00 | 显示全部楼层
小跑堂,离线中呢?
所以,你留言啊,他会回复你的。
问题你赶紧就在这里问了吧。
 楼主| lqland 发表于 2014-4-3 15:02 | 显示全部楼层
真不容易。。。。。。。
FSL_TICS_Rita 发表于 2014-4-4 15:16 | 显示全部楼层
真不容易。。。。。。。
ocean@ubuntu:~$ sudo apt-get install git gnupg flex bison gperf build-essenti ...
你好,在另外的帖中回你了:)。
