GEC2410实验箱
2775|0
 楼主| iconwong 发表于 2008-6-20 15:00 | 显示全部楼层 |阅读模式
<br />(实验箱外观)&nbsp;<br /><br />选配模块&nbsp;<br /><br />1<br />&nbsp;蓝牙模块&nbsp;<br />&nbsp;<br />&nbsp;选配,实现数据图象等文件的传输,&nbsp;1Mbps传输速率&nbsp;,USB&nbsp;1.1总线&nbsp;,&nbsp;支持蓝牙1.1(兼容1.2)&nbsp;版本协议&nbsp;,&nbsp;2.4GHz~2.4835GHz频谱带宽。&nbsp;<br />&nbsp;<br />2&nbsp;<br />&nbsp;SD卡<br />&nbsp;<br />&nbsp;选配,1G&nbsp;<br />3&nbsp;<br />&nbsp;CF卡&nbsp;<br />&nbsp;<br />&nbsp;选配,&nbsp;1G&nbsp;<br />4&nbsp;<br />&nbsp;IC卡&nbsp;<br />&nbsp;<br />&nbsp;选配,非接触射频卡&nbsp;<br />5&nbsp;<br />&nbsp;硬盘&nbsp;<br />&nbsp;<br />&nbsp;选配,西数&nbsp;厂家&nbsp;,60G&nbsp;<br />6&nbsp;<br />&nbsp;CAN通讯单片机模块&nbsp;<br />&nbsp;<br />&nbsp;选配,&nbsp;可以利用ARM处理器CAN&nbsp;总线外扩对CAN&nbsp;模块上的单片机及相关硬件如&nbsp;LED&nbsp;数码管、LED灯、步进电机、蜂鸣器进行控制。提供基于该模块的相关实验代码及指导书说明。<br />&nbsp;<br />7&nbsp;<br />&nbsp;射频模块&nbsp;<br />&nbsp;<br />&nbsp;选配,工作电压&nbsp;:5V&nbsp;DC&nbsp;工作电流&nbsp;:&lt&nbsp;100&nbsp;mA&nbsp;通讯接口&nbsp;:&nbsp;RS232&nbsp;接口适用卡型&nbsp;:&nbsp;MifareLight&nbsp;、&nbsp;MifareOne&nbsp;数据通讯&nbsp;:&nbsp;106&nbsp;K&nbsp;BPS&nbsp;射频频率&nbsp;:&nbsp;13.56&nbsp;MHz操作距离&nbsp;:&nbsp;&lt&nbsp;50&nbsp;mm&nbsp;。<br />&nbsp;<br />8&nbsp;<br />&nbsp;USB无线网卡&nbsp;<br />&nbsp;<br />&nbsp;选配,VIA&nbsp;VT6556芯片&nbsp;<br />9&nbsp;<br />&nbsp;微型打印机&nbsp;<br />&nbsp;<br />&nbsp;选配,&nbsp;支持多种格式汉字,字符设置和强大的图形自定义、国际条形码、字符自定义;<br />打印方法:&nbsp;直接热敏打印速度:约70mm/秒或20行/秒。&nbsp;<br />&nbsp;<br />10&nbsp;<br />&nbsp;ARM仿真器&nbsp;<br />&nbsp;<br />&nbsp;选配,GEC-ICE,ARM9系列仿真器&nbsp;<br />11&nbsp;<br />&nbsp;GPRS模块&nbsp;<br />&nbsp;<br />&nbsp;选配,&nbsp;含进口GPRS模块,&nbsp;1个GSM/GPRS模块,内嵌TCP/IP协议,可以实现拨打、接听电话,收发短信,上网功能。&nbsp;<br />&nbsp;<br />12&nbsp;<br />&nbsp;GPS模块&nbsp;<br />&nbsp;&nbsp;&nbsp;<br />&nbsp;选配,含进口GPS模块,&nbsp;精度为10米支持NWEA3.0协议提供API函数库,方便用户读取经纬度、海拔、时间等数据。&nbsp;<br />&nbsp;<br />13&nbsp;<br />&nbsp;VGA模块&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;选配,软件上不需要单独编写VGA驱动&nbsp;<br />14&nbsp;<br />&nbsp;条码扫描仪&nbsp;<br />&nbsp;<br />&nbsp;选配,PS2接口&nbsp;<br />15<br />&nbsp;USB摄像头&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;中星微301芯片,130万像素&nbsp;<br />16<br />&nbsp;IO模块&nbsp;<br />&nbsp;<br />&nbsp;16位输入,16位输出,8个LED灯,8位拨码开关&nbsp;<br /><br />&nbsp;<br /><br /><br />(实验箱内部外观以及功能介绍)<br /><br />嵌入式实验系统硬件配置:&nbsp;<br /><br />序号&nbsp;&nbsp;名称&nbsp;描述&nbsp;注释&nbsp;<br />1&nbsp;CPU&nbsp;&nbsp;Samsung&nbsp;S3C2410X,203MHz主频&nbsp;&nbsp;&nbsp;&nbsp;<br />2&nbsp;ROM&nbsp;&nbsp;1&nbsp;MB&nbsp;AMD&nbsp;Flash&nbsp;ROM,64MB&nbsp;Samsung&nbsp;Nand&nbsp;Flash&nbsp;&nbsp;&nbsp;<br />3&nbsp;RAM&nbsp;&nbsp;64MB&nbsp;SDRAM,100MHz刷新频率&nbsp;&nbsp;&nbsp;<br />4&nbsp;LAN&nbsp;&nbsp;一个10M&nbsp;Ethernet,RJ-45接口&nbsp;&nbsp;&nbsp;<br />5&nbsp;&nbsp;RS232&nbsp;3个DB9串口(其中一个是全串口)&nbsp;&nbsp;&nbsp;&nbsp;<br />6&nbsp;RS485&nbsp;1个RS485接口&nbsp;&nbsp;&nbsp;&nbsp;<br />7&nbsp;&nbsp;Irda&nbsp;&nbsp;1个红外接口&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />8&nbsp;&nbsp;CAN&nbsp;&nbsp;1个CAN总线接口&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />9&nbsp;&nbsp;Parallel&nbsp;&nbsp;1个标准打印并口&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />10&nbsp;RS485&nbsp;1个RS485接口&nbsp;&nbsp;&nbsp;<br />11&nbsp;USB&nbsp;&nbsp;2个USB&nbsp;Host&nbsp;A型接口(USB&nbsp;1.1协议)&nbsp;&nbsp;&nbsp;<br />1个USB&nbsp;Slave&nbsp;B型接口,(USB1.1协议&nbsp;)&nbsp;&nbsp;<br />12&nbsp;PS2&nbsp;2个PS2接口(鼠标和键盘)&nbsp;&nbsp;&nbsp;<br />13&nbsp;Audio&nbsp;1个音频输出接口(双声道,可直接接耳塞)<br />1个音频输入口,可直接接MIC&nbsp;&nbsp;&nbsp;<br />14&nbsp;IDE&nbsp;2个IDE硬盘接口(2.5英寸硬盘<br />和3.5英寸硬盘(选配))&nbsp;&nbsp;&nbsp;<br />15&nbsp;RTC&nbsp;外接32.768KHz的晶振,带有备份电池,可保持时钟&nbsp;&nbsp;&nbsp;<br />16&nbsp;JTAG&nbsp;一个20针(2.0mm间距)标准的JTAG接口,主要用来下载bootloader&nbsp;&nbsp;&nbsp;<br />17&nbsp;SD&nbsp;Card&nbsp;一个标准SD&nbsp;Card插座&nbsp;&nbsp;&nbsp;<br />CF&nbsp;Card&nbsp;2个CF卡接口(其中一个是选配)&nbsp;<br />18&nbsp;LED&nbsp;4个可编程用户LED(带驱动程序),8个七段数码管&nbsp;&nbsp;&nbsp;<br />19&nbsp;Keypad&nbsp;16个可编程用户按键(带有驱动程序)&nbsp;&nbsp;&nbsp;<br />20&nbsp;Reset&nbsp;一个复位按键&nbsp;&nbsp;&nbsp;<br />21&nbsp;Power&nbsp;220V交流输入&nbsp;&nbsp;&nbsp;<br />22&nbsp;LCD模块&nbsp;配置8英寸TFT宽屏(800X480),带触摸屏&nbsp;&nbsp;&nbsp;<br />23&nbsp;A/D采集转换模块&nbsp;一个A/D实验模块&nbsp;&nbsp;&nbsp;<br />24&nbsp;VGA模块&nbsp;一个标准VGA接口,可直接连接各种VGA接口的CRT显示器或液晶显示器&nbsp;&nbsp;&nbsp;<br />25&nbsp;GPRS模块&nbsp;1个GSM/GPRS模块,内嵌TCP/IP协议,可以实现拨打、接听电话,收发短信,上网功能(选配)&nbsp;&nbsp;&nbsp;<br />26&nbsp;电机控制模块&nbsp;1个步进电机和1个直流电机&nbsp;&nbsp;&nbsp;<br />27&nbsp;扩展接口&nbsp;1个扩展接口,方便进行定制开发&nbsp;&nbsp;&nbsp;<br />28&nbsp;开发箱&nbsp;嵌入式系统硬件放入开发箱中&nbsp;&nbsp;&nbsp;<br /><br />产品优势对照表:&nbsp;<br /><br />比较项目&nbsp;&nbsp;GEC2410BV1.1嵌入式教学实验平台&nbsp;&nbsp;其他厂商&nbsp;&nbsp;<br />实验教材&nbsp;<br />&nbsp;提供500多页的《GEC2410教学实验开发平台实验指导》,其中涉及ARM结构的基础实验以及WinCE编译方法、驱动使用方法及例子、应用程序编程、驱动编写方法&nbsp;<br />基于ARM+LINUX的软硬件培训体系结构。重点讲解:S3C2410及其外围芯片的设计与编程,Linux内核开发,嵌入式Linux的移植,开发驱动程,开发GUI程序。&nbsp;<br />&nbsp;一般为几十页,只是介绍如何编译操作系统&nbsp;<br />&nbsp;<br />Windows&nbsp;CE版本&nbsp;<br />&nbsp;WindowsCE.net&nbsp;5.0。改动非常少就能够移植到刚发布不久的WindowsCE.net&nbsp;6.0.<br />&nbsp;WindowsCE.net&nbsp;4.2,移植到Widnows&nbsp;CE.net&nbsp;6.0时改动非常多,移植很困难&nbsp;<br />&nbsp;<br />Linux版本&nbsp;<br />&nbsp;Linux2.6,总体来说&nbsp;2.6&nbsp;功能更强,增加了不少新功能(例如&nbsp;mem&nbsp;pool&nbsp;)&nbsp;<br />&nbsp;还是Linux2.4,底层调用上和&nbsp;2.4&nbsp;内核差别很大。&nbsp;<br />&nbsp;<br />GPRS<br />&nbsp;提供API函数(开放源码)用于拨打/接听电话、收/发短信、无线上网&nbsp;<br />&nbsp;一般只支持无线上网&nbsp;<br />&nbsp;<br />GPIO、I2C、PWM、ADC等微软或三星不提供的驱动&nbsp;<br />&nbsp;提供GPIO、I2C、PWM、ADC、PS2,鼠标键盘‘IDE硬盘,三个串口(其中一个带MODEM功能)驱动&nbsp;<br />&nbsp;不提供&nbsp;<br />&nbsp;<br />打印机接口&nbsp;<br />&nbsp;连接打印机,支持打印文件,学习并口控制打印机实验&nbsp;<br />&nbsp;不提供&nbsp;<br />&nbsp;<br /><br />开发套件包含的内容<br />GEC2410B实验箱&nbsp;光盘上提供的开发工具和源代码:&nbsp;<br />1)&nbsp;测试源代码,启动引导源代码BIOS和下载烧写工具sjf2410&nbsp;.exe;&nbsp;<br />2)&nbsp;Linux&nbsp;for&nbsp;2410的内核源码包以及内核交叉编译工具,可运行的根文件系统及根文件系统制作工具&nbsp;,linux系统下的驱动源码和测试程序源码&nbsp;;&nbsp;<br />3)&nbsp;qt-embedded-2.3.7和qtopia-free-1.7.0源码,应用程序交叉编译器&nbsp;,基于QT的测试程序源码&nbsp;。&nbsp;<br />4)&nbsp;WINCE&nbsp;5.0&nbsp;.NET板级支持包BSP&nbsp;for&nbsp;2410,及已编译好的WINCE镜像文件&nbsp;,驱动源码和测试程序源码&nbsp;;&nbsp;<br />5)uCOS系统测试程序源码及目标文件;&nbsp;<br />6)GEC2410B实验箱芯片的资料;&nbsp;<br />7)&nbsp;GEC2410B实验箱底板和核心板电路原理图(pdf格式);&nbsp;<br />8)&nbsp;GEC2410B实验箱户手册(pdf&nbsp;格式),GEC2410B教学实验平台-基础实验教程,linux实验教程,Wince实验教程和uCOS实验教程。<br />9)&nbsp;实用工具,如&nbsp;DNW&nbsp;,USB驱动等。&nbsp;<br />套件包括:&nbsp;<br />1)&nbsp;1个&nbsp;已测试好的GEC2410B实验箱&nbsp;(包括核心板与底板);&nbsp;<br />2)&nbsp;1张&nbsp;GEC2410B&nbsp;用户光盘&nbsp;,1张WinCE5.0试用版安装盘;&nbsp;<br />3)1张保修卡;&nbsp;<br />4)1&nbsp;条交叉串口线(两边都是母头)&nbsp;;&nbsp;<br />5)1&nbsp;条网线(交叉网线)&nbsp;;&nbsp;<br />6)&nbsp;1&nbsp;条USB&nbsp;线&nbsp;;&nbsp;<br />7)&nbsp;1&nbsp;支触摸笔&nbsp;;&nbsp;<br />8)&nbsp;1条220V交流&nbsp;电源&nbsp;线;&nbsp;<br />9)&nbsp;用户另购的选配件。&nbsp;<br />操作系统支持的驱动&nbsp;<br />GEC2410B实验箱&nbsp;支持&nbsp;WINCE&nbsp;、Linux&nbsp;、uc/OS-II&nbsp;嵌入操作系统。&nbsp;<br />嵌入&nbsp;Linux&nbsp;操作系统说明:<br /><br />名称&nbsp;<br />&nbsp;功能特性&nbsp;<br />&nbsp;说明&nbsp;<br />&nbsp;<br />内核及根文件&nbsp;<br />系统&nbsp;<br />&nbsp;Linux&nbsp;kernel&nbsp;2.6.11&nbsp;<br />&nbsp;使用&nbsp;2.6&nbsp;稳定内核&nbsp;<br />&nbsp;<br />ROM/CRAM/EXT2/FAT32/NFS?&nbsp;<br />&nbsp;支持&nbsp;ROM/CRAM/EXT2/FAT32/NFS/YAFFS&nbsp;等文件系统&nbsp;<br />&nbsp;<br />YAFFS&nbsp;<br />&nbsp;YAFFS&nbsp;文件系统&nbsp;<br />&nbsp;<br />驱动支持&nbsp;<br />&nbsp;System&nbsp;Interrupt&nbsp;&&nbsp;Timer&nbsp;Driver&nbsp;<br />&nbsp;系统中断和系统时钟驱动&nbsp;<br />&nbsp;<br />Serial&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;3个串口驱动&nbsp;<br />&nbsp;<br />Block&nbsp;memory&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;块设备驱动&nbsp;<br />&nbsp;<br />Flash&nbsp;memory&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;Nand&nbsp;Flash&nbsp;驱动&nbsp;<br />&nbsp;<br />10Base-T&nbsp;external&nbsp;Ethernet&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;外接&nbsp;10M&nbsp;以太网卡驱动&nbsp;<br />&nbsp;<br />RTC&nbsp;(Real&nbsp;Time&nbsp;Clock)&nbsp;Driver&nbsp;<br />&nbsp;实时时钟驱动&nbsp;<br />&nbsp;<br />USB&nbsp;Host&nbsp;driver&nbsp;<br />&nbsp;USB&nbsp;Host&nbsp;驱动&nbsp;<br />&nbsp;<br />USB&nbsp;Slave&nbsp;<br />&nbsp;USB&nbsp;Slave&nbsp;驱动&nbsp;<br />&nbsp;<br />Many&nbsp;Country&nbsp;Language&nbsp;Support&nbsp;<br />&nbsp;国际化支持&nbsp;<br />&nbsp;<br />LCD&nbsp;<br />&nbsp;液晶&nbsp;(LCD)&nbsp;驱动&nbsp;<br />&nbsp;<br />Frame&nbsp;Buffer&nbsp;<br />&nbsp;Frame&nbsp;Buffer&nbsp;<br />&nbsp;<br />网络协议及网络应用程序&nbsp;<br />&nbsp;TCP/IP&nbsp;<br />&nbsp;完整的&nbsp;TCP/IP&nbsp;协议&nbsp;<br />&nbsp;<br />NFS&nbsp;<br />&nbsp;支持&nbsp;NFS&nbsp;Client&nbsp;<br />&nbsp;<br />Telnet&nbsp;Server&nbsp;<br />&nbsp;Telnet&nbsp;服务器&nbsp;<br />&nbsp;<br />File&nbsp;transfer&nbsp;(FTP&nbsp;client&nbsp;/&nbsp;server)&nbsp;<br />&nbsp;FTP&nbsp;传输服务&nbsp;(&nbsp;包括登录和服务器&nbsp;)&nbsp;<br />&nbsp;<br />Remote&nbsp;login&nbsp;(telnet)&nbsp;<br />&nbsp;Telnet&nbsp;远程登录&nbsp;<br />&nbsp;<br />Web&nbsp;server&nbsp;(HTTP&nbsp;v1.1,&nbsp;boa)&nbsp;<br />&nbsp;Web&nbsp;服务器&nbsp;(boa)&nbsp;<br />&nbsp;<br />Web&nbsp;base&nbsp;management&nbsp;suite&nbsp;(Sample&nbsp;only)&nbsp;<br />&nbsp;通过网页管理目标板&nbsp;<br />&nbsp;<br />系统升级&nbsp;<br />&nbsp;Console&nbsp;&&nbsp;FTP&nbsp;<br />&nbsp;在控制台下使用&nbsp;FTP&nbsp;升级系统&nbsp;<br />&nbsp;<br />NFS&nbsp;<br />&nbsp;通过网络文件系统&nbsp;<br />&nbsp;<br />Mobile&nbsp;Storge&nbsp;<br />&nbsp;通过移动存储升级&nbsp;<br />&nbsp;<br />配置系统和服务&nbsp;<br />&nbsp;Local&nbsp;console&nbsp;through&nbsp;RS232&nbsp;and&nbsp;remote&nbsp;telnet&nbsp;configuration&nbsp;and&nbsp;management(Sample&nbsp;Only)&nbsp;<br />&nbsp;通过串口控制台或&nbsp;telnet&nbsp;远程登录配置系统&nbsp;<br />&nbsp;<br />WEB&nbsp;configuration&nbsp;and&nbsp;management(Sample&nbsp;Only)&nbsp;<br />&nbsp;通过浏览器进行简单配置&nbsp;<br />&nbsp;<br />Network&nbsp;ping&nbsp;<br />&nbsp;使用&nbsp;ping&nbsp;检查系统&nbsp;<br />&nbsp;<br />Ifconfig,&nbsp;route,&nbsp;ine&nbsp;<br />&nbsp;提供&nbsp;ifocnfig,&nbsp;route,inetd&nbsp;等网络配置和服务程序&nbsp;<br />&nbsp;<br />login,&nbsp;sh,&nbsp;echo&nbsp;<br />&nbsp;登录和其他程序&nbsp;<br />&nbsp;<br />基本工具&nbsp;<br />&nbsp;cat,&nbsp;chmod,cp,&nbsp;echo,&nbsp;free,&nbsp;hostname,&nbsp;init,&nbsp;kill,&nbsp;ls,&nbsp;mkdir,&nbsp;mount,&nbsp;ps,&nbsp;rm,&nbsp;yes,insmod,&nbsp;lsmod,&nbsp;rmmod,&nbsp;pwd,&nbsp;cat,&nbsp;more,&nbsp;less&nbsp;等&nbsp;<br />&nbsp;Linux&nbsp;常用命令&nbsp;(&nbsp;用&nbsp;busybox&nbsp;构建&nbsp;)&nbsp;<br />&nbsp;<br />控制台应用程序&nbsp;<br />&nbsp;mp3play&nbsp;<br />&nbsp;控制台下的&nbsp;mp3&nbsp;播放器&nbsp;<br />&nbsp;<br />leds&nbsp;<br />&nbsp;控制用户&nbsp;LED&nbsp;<br />&nbsp;<br />buttons&nbsp;<br />&nbsp;键盘使用程序&nbsp;<br />&nbsp;<br />vidcat&nbsp;<br />&nbsp;USB&nbsp;摄像头抓图程序&nbsp;<br />&nbsp;<br />armsql&nbsp;<br />&nbsp;嵌入式数据库&nbsp;<br />&nbsp;<br />第三方&nbsp;USB&nbsp;设备驱动&nbsp;<br />&nbsp;USB&nbsp;键盘,鼠标&nbsp;<br />&nbsp;支持大部分&nbsp;USB&nbsp;鼠标&nbsp;,&nbsp;键盘&nbsp;<br />&nbsp;<br />优盘&nbsp;<br />&nbsp;支持各种优盘直接插拔使用&nbsp;<br />&nbsp;<br />移动硬盘&nbsp;<br />&nbsp;支持各种移动硬盘插拔使用&nbsp;<br />&nbsp;<br />USB&nbsp;Hub&nbsp;<br />&nbsp;支持各种&nbsp;USB&nbsp;Hub&nbsp;<br />&nbsp;<br />USB&nbsp;?摄像头&nbsp;<br />&nbsp;支持使用&nbsp;ov511&nbsp;芯片和中芯微301芯片的&nbsp;USB&nbsp;摄像头&nbsp;<br />&nbsp;<br />嵌入式图形界面&nbsp;<br />&nbsp;Qt/Embedded&nbsp;<br />&nbsp;?QT&nbsp;<br />&nbsp;<br /><br /><br />WinCE&nbsp;操作系统说明:&nbsp;<br />名称&nbsp;<br />&nbsp;功能特性&nbsp;<br />&nbsp;说明&nbsp;<br />&nbsp;<br />内核文件系统&nbsp;<br />&nbsp;WINCE&nbsp;5.0&nbsp;程序包&nbsp;<br />&nbsp;使用WINCCE&nbsp;5.0内核&nbsp;<br />&nbsp;<br />驱动支持&nbsp;<br />&nbsp;Serial&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;三个串口驱动(其中一个为独立串口,由W83977扩展)&nbsp;<br />&nbsp;<br />Flash&nbsp;memory&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;Nand&nbsp;Flash驱动&nbsp;<br />&nbsp;<br />10Base-T&nbsp;external&nbsp;Ethernet&nbsp;device&nbsp;driver&nbsp;<br />&nbsp;外接10M以太网卡驱动&nbsp;<br />&nbsp;<br />RTC&nbsp;(Real&nbsp;Time&nbsp;Clock)&nbsp;Driver&nbsp;<br />&nbsp;实时时钟驱动&nbsp;<br />&nbsp;<br />USB&nbsp;Host&nbsp;driver<br />&nbsp;USB&nbsp;Host驱动&nbsp;<br />&nbsp;<br />USB&nbsp;Slave&nbsp;<br />&nbsp;USB&nbsp;Slave驱动&nbsp;<br />&nbsp;<br />LCD<br />&nbsp;液晶(LCD)驱动&nbsp;<br />&nbsp;<br />Can&nbsp;bus<br />&nbsp;Sja1000的驱动&nbsp;<br />&nbsp;<br />I2C<br />&nbsp;&nbsp;<br />&nbsp;<br />Led<br />&nbsp;&nbsp;<br />&nbsp;<br />独立按键&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />SD卡&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />硬盘&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />CF卡&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />PS/2键盘鼠标&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />触摸屏&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />ADC<br />&nbsp;10位&nbsp;<br />&nbsp;<br />音频&nbsp;<br />&nbsp;UDA1341芯片&nbsp;<br />&nbsp;<br />网络协议及网络应用程序&nbsp;<br />&nbsp;TCP/IP<br />&nbsp;完整的TCP/IP协议&nbsp;<br />&nbsp;<br />NFS<br />&nbsp;支持NFS&nbsp;Client&nbsp;<br />&nbsp;<br />Telnet&nbsp;Server&nbsp;<br />&nbsp;Telnet服务器&nbsp;<br />&nbsp;<br />File&nbsp;transfer&nbsp;(FTP&nbsp;client&nbsp;/&nbsp;server)&nbsp;<br />&nbsp;FTP传输服务(包括登录和服务器)<br />&nbsp;<br />Web&nbsp;server&nbsp;(HTTP&nbsp;v1.1,&nbsp;boa)&nbsp;<br />&nbsp;Web服务器(boa)<br />&nbsp;<br />Web&nbsp;base&nbsp;management&nbsp;suite&nbsp;(Sample&nbsp;only)&nbsp;<br />&nbsp;通过网页管理目标板&nbsp;<br />&nbsp;<br />基本工具&nbsp;<br />&nbsp;Platform&nbsp;builder<br />&nbsp;Wince5.0&nbsp;编译工具&nbsp;<br />&nbsp;<br />应用程序&nbsp;<br />&nbsp;2410与PC机串口通信&nbsp;<br />&nbsp;2410与PC机串口通信实验&nbsp;<br />2410&nbsp;RS485通信实验&nbsp;<br />&nbsp;<br />ADC定时采样&nbsp;<br />&nbsp;ADC定时采样显示实验&nbsp;<br />&nbsp;<br />SDMMC卡读写&nbsp;<br />&nbsp;SDMMC卡读写实验&nbsp;<br />&nbsp;<br />Can&nbsp;bus<br />&nbsp;CanBus通信实验&nbsp;<br />&nbsp;<br />IIC&nbsp;BUS<br />&nbsp;E2PROM读写实验&nbsp;<br />&nbsp;<br />Gpio<br />&nbsp;步进电机控制实验&nbsp;<br />&nbsp;<br />第三方USB设备驱动&nbsp;<br />&nbsp;USB键盘,鼠标&nbsp;<br />&nbsp;支持大部分USB鼠标,键盘&nbsp;<br />&nbsp;<br />优盘&nbsp;<br />&nbsp;支持各种优盘直接插拔使用&nbsp;<br />&nbsp;<br />移动硬盘&nbsp;<br />&nbsp;支持各种移动硬盘插拔使用(尚无)&nbsp;<br />&nbsp;<br />USB&nbsp;Hub&nbsp;<br />&nbsp;支持各种USB&nbsp;Hub&nbsp;<br />&nbsp;<br />USB&nbsp;摄像头&nbsp;<br />&nbsp;支持使用ov511芯片和中星微301芯片的USB摄像头&nbsp;<br />&nbsp;<br />USB无线网卡&nbsp;<br />&nbsp;支持VT6656芯片的无线网卡&nbsp;<br />&nbsp;<br />USB蓝牙模块&nbsp;<br />&nbsp;支持BCM2045芯片的蓝牙模块&nbsp;<br />&nbsp;<br /><br />uc/OS-II&nbsp;嵌入操作系统:&nbsp;名称&nbsp;<br />&nbsp;功能特性&nbsp;<br />&nbsp;说明&nbsp;<br />&nbsp;<br />应用程序&nbsp;<br />&nbsp;ADC定时采样测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />步进电机控制测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />GPS测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />GPRS测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />音频输入输出测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />蜂鸣器/数码管测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />2X2键盘阵列测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />RS485测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />CAN总线测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />I/O模块测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />RFID模块测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />多线程测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br />以太网测试程序&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;<br /><br /><br />&nbsp;<br /><br />开设实验内容&nbsp;<br />基础实验&nbsp;<br />第一章&nbsp;嵌入式系统&nbsp;<br />1.1&nbsp;嵌入式系统概率&nbsp;<br />1.2&nbsp;嵌入式处理器&nbsp;<br />1.3&nbsp;嵌入式操作系统&nbsp;<br />1.4&nbsp;GEC2410B实验平台介绍&nbsp;<br />1.4.1&nbsp;硬件资源&nbsp;<br />1.4.2&nbsp;软件资源&nbsp;<br />1.4.3&nbsp;教学平台的使用&nbsp;<br />第二章&nbsp;ADS集成开发环境的使用&nbsp;<br />2.1&nbsp;ADS&nbsp;1.2&nbsp;集成开发环境介绍&nbsp;<br />2.2&nbsp;AXD调试&nbsp;<br />第三章&nbsp;ARM基础实验&nbsp;<br />3.1&nbsp;ARM&nbsp;汇编指令实验&nbsp;<br />3.2&nbsp;C和汇编语言的混合编程实验<br />3.3&nbsp;外部中断实验&nbsp;<br />3.4&nbsp;看门狗应用实验&nbsp;<br />3.5&nbsp;PWM&nbsp;timer&nbsp;实验&nbsp;<br />3.6&nbsp;启动代码实验&nbsp;<br />3.7&nbsp;串口实验&nbsp;<br />3.8&nbsp;并口实验&nbsp;<br />3.9&nbsp;矩阵键盘扫描实验&nbsp;<br />3.10&nbsp;实时时钟设计&nbsp;<br />3.11&nbsp;IIC&nbsp;总线应用实验&nbsp;<br />3.12&nbsp;Nor&nbsp;flash&nbsp;应用实验&nbsp;<br />3.13&nbsp;Nand&nbsp;flash&nbsp;应用实验&nbsp;<br />3.14&nbsp;LCD&nbsp;显示实验&nbsp;<br />3.15&nbsp;VGA&nbsp;显示实验&nbsp;<br />3.16&nbsp;触摸屏实验&nbsp;<br />3.17&nbsp;ADC&nbsp;实验&nbsp;<br />3.18&nbsp;TFTP&nbsp;以太网通讯实验&nbsp;<br />3.19&nbsp;音频接口实验..&nbsp;<br />3.20&nbsp;CAN&nbsp;总线通讯实验&nbsp;<br />3.21&nbsp;USB&nbsp;Device&nbsp;实验&nbsp;<br />3.22&nbsp;CF&nbsp;卡/IDE硬盘读写实验<br />3.23&nbsp;SD&nbsp;卡接口实验&nbsp;<br />3.24&nbsp;RS485&nbsp;通讯实验&nbsp;<br />3.25&nbsp;GPS&nbsp;全球定位实验&nbsp;<br />3.26&nbsp;GPRS/GSM&nbsp;通讯实验&nbsp;<br />第四章&nbsp;实时操作系统Nucleus实验&nbsp;<br />4.1&nbsp;Nucleus&nbsp;的介绍与应用&nbsp;<br />4.2&nbsp;Nucleus&nbsp;PLUS&nbsp;在S3C2410A&nbsp;上的移植&nbsp;<br />4.3&nbsp;Nucleus&nbsp;PLUS&nbsp;基于S3C2410A&nbsp;的实验&nbsp;<br />第五章&nbsp;嵌入式Linux系统实验&nbsp;<br />5.1&nbsp;linux系统的安装&nbsp;<br />5.2&nbsp;嵌入式Linux&nbsp;开发与调试&nbsp;<br />1嵌入式Linux&nbsp;系统与PC机间的文件传输&nbsp;<br />2嵌入式Linux应用程序的开发与调试&nbsp;<br />5.3&nbsp;嵌入式Linux内核定制与编译&nbsp;<br />5.4&nbsp;嵌入式Linux根文件系统的制作&nbsp;<br />5.5&nbsp;嵌入式Linux的led驱动程序设计&nbsp;<br />5.6&nbsp;嵌入式GUI开发&nbsp;<br />1&nbsp;Qt/Embedded&nbsp;开发环境的安装&nbsp;<br />2&nbsp;Qt/Embedded应用开发实例&nbsp;<br />第六章&nbsp;嵌入式Windows&nbsp;CE系统实验<br />6.1&nbsp;windows&nbsp;CE&nbsp;的安装&nbsp;<br />6.2&nbsp;定制嵌入式windows&nbsp;CE平台&nbsp;<br />6.3&nbsp;在windows&nbsp;CE和桌面系统之间建立通讯连接<br />Linux实验&nbsp;<br />第一章&nbsp;嵌入式系统&nbsp;<br />1.1&nbsp;嵌入式系统概率&nbsp;<br />1.2&nbsp;嵌入式处理器&nbsp;<br />1.3&nbsp;嵌入式操作系统&nbsp;<br />1.4&nbsp;GEC2410B实验平台介绍&nbsp;<br />1.4.1&nbsp;硬件资源&nbsp;<br />1.4.2&nbsp;软件资源&nbsp;<br />1.4.3&nbsp;教学平台的使用&nbsp;<br />第二章&nbsp;嵌入式Linux开发基础知识&nbsp;<br />2.1嵌入式Linux简介&nbsp;<br />2.2嵌入式Linux开发平台简介<br />2.3嵌入式Linux开发流程&nbsp;<br />第三章linux设备驱动程序概述<br />3.1设备驱动程序基础知识&nbsp;<br />3.2字符设备驱动程序&nbsp;<br />3.3块设备驱动程序&nbsp;<br />3.4网络设备驱动程序&nbsp;<br />第四章&nbsp;嵌入式Linux驱动实验&nbsp;<br />4.1&nbsp;嵌入式Linux的交叉工具链的安装与使用<br />4.2&nbsp;嵌入式Linux挂载远程共享文件夹实验&nbsp;<br />4.3&nbsp;嵌入式Linux应用程序的开发&nbsp;<br />4.4&nbsp;嵌入式Linux交叉调试器的安装与使用&nbsp;<br />4.5&nbsp;嵌入式bootloader的移植&nbsp;<br />4.6&nbsp;嵌入式Linux的交叉工具链的制作&nbsp;<br />4.7&nbsp;嵌入式Linux内核移植&nbsp;<br />4.8&nbsp;嵌入式Linux根文件系统的制作&nbsp;<br />4.9&nbsp;嵌入式Linux内核驱动模块设计及实验&nbsp;<br />4.10&nbsp;嵌入式Linux的led驱动程序设计及实验&nbsp;<br />4.11&nbsp;嵌入式Linux的小键盘驱动程序设计及实验<br />4.12&nbsp;嵌入式linux的CAN总线驱动程序设计及实验<br />4.13&nbsp;嵌入式linux的IIC总线驱动程序设计及实验&nbsp;<br />4.14&nbsp;嵌入式linux的音频驱动程序设计及实验&nbsp;<br />4.15嵌入式linux的PS2键盘鼠标驱动程序设计及实验&nbsp;<br />4.16嵌入式linux的串口驱动程序设计及实验(W83977)<br />4.17&nbsp;嵌入式linux的LCD驱动程序设计及实验&nbsp;<br />4.18&nbsp;嵌入式linux的触摸屏驱动程序设计及实验&nbsp;<br />4.19&nbsp;嵌入式linux的USB&nbsp;Host驱动程序设计及实验&nbsp;<br />4.20&nbsp;嵌入式linux的CF卡驱动程序设计及实验&nbsp;<br />4.21&nbsp;嵌入式linux的IDE硬盘驱动程序设计及实验&nbsp;<br />4.22&nbsp;嵌入式linux的SD卡驱动程序设计及实验<br />4.23嵌入式linux的网卡驱动程序设计及实验&nbsp;<br />第四章&nbsp;嵌入式Linux应用程序实验&nbsp;<br />4.1&nbsp;嵌入式基本应用程序开发&nbsp;<br />4.2&nbsp;Linux的WEB服务器建立和动态WEB技术实验<br />4.3&nbsp;Linux&nbsp;多线程应用程序开发&nbsp;<br />4.4&nbsp;Linux的以太网socket通讯实验&nbsp;<br />第五章&nbsp;嵌入式Linux图形用户接口实验&nbsp;<br />5.1嵌入式系统中的GUI简介<br />5.2基于MiniGUI的应用开发&nbsp;<br />5.2.1&nbsp;MiniGUI&nbsp;开发环境的安装&nbsp;<br />5.2.2&nbsp;MiniGUI&nbsp;应用开发实例&nbsp;<br />5.2.3&nbsp;MiniGUI&nbsp;应用移植&nbsp;<br />5.3基于&nbsp;Qt/Embedded&nbsp;应用开发&nbsp;<br />5.3.1&nbsp;Qt/Embedded&nbsp;开发环境的安装&nbsp;<br />5.3.2&nbsp;Qt/Embedded应用开发实例<br />5.3.3&nbsp;Qt/Embedded应用移植&nbsp;<br />5.3.4提供LINUX&nbsp;系统下,基于QT的摄象头、GPRP、无线上网、蓝牙应用程序、源码驱动及实验。<br />μC/OS&nbsp;-&nbsp;II实验&nbsp;<br />第一章&nbsp;嵌入式系统&nbsp;<br />1&nbsp;嵌入式系统概率&nbsp;<br />2&nbsp;嵌入式处理器&nbsp;<br />3&nbsp;嵌入式操作系统&nbsp;<br />4&nbsp;GEC2410B实验平台介绍&nbsp;<br />1.4.1&nbsp;硬件资源&nbsp;<br />1.4.2&nbsp;软件资源&nbsp;<br />1.4.3&nbsp;教学平台的使用&nbsp;<br />第二章&nbsp;嵌入式系统硬件驱动基础开发案例<br />1&nbsp;ARM的串行口实验&nbsp;<br />2&nbsp;ARM的A/D接口实验&nbsp;<br />3&nbsp;ARM的D/A接口实验&nbsp;<br />4&nbsp;电机转动控制实验&nbsp;<br />5&nbsp;触摸屏驱动实验&nbsp;<br />6&nbsp;LCD的驱动控制实验&nbsp;<br />7&nbsp;蜂鸣器驱动实验&nbsp;<br />8&nbsp;提供蜂鸣器、GPRS、GPS、TCP/IP协议栈和TFTP文件传输源代码和实验<br />第三章&nbsp;嵌入式系统扩展板开发案例<br />扩展实验一&nbsp;GPRS&nbsp;扩展板通信实验<br />扩展实验二&nbsp;GPS&nbsp;扩展板通信实验&nbsp;<br />WINCE实验&nbsp;<br />第一章&nbsp;嵌入式系统&nbsp;<br />1.1&nbsp;嵌入式系统概率<br />1.2&nbsp;嵌入式处理器&nbsp;<br />1.3&nbsp;嵌入式操作系统&nbsp;<br />1.4&nbsp;GEC2410B实验平台介绍&nbsp;<br />1.4.1&nbsp;硬件资源&nbsp;<br />1.4.2&nbsp;软件资源&nbsp;<br />1.4.3&nbsp;教学平台的使用<br />第二&nbsp;章&nbsp;WINCE系统开发&nbsp;1&nbsp;WINCE系统建立实验&nbsp;<br />2&nbsp;WINCE模拟器实验&nbsp;<br />3&nbsp;WINCE&nbsp;Bootloader实验&nbsp;<br />第三&nbsp;章&nbsp;WINCE系统驱动开发<br />1&nbsp;WINCE简单驱动开发实例&nbsp;<br />2&nbsp;WINCE下ADC流驱动程序设计&nbsp;<br />3&nbsp;IIC总线驱动实验&nbsp;<br />4&nbsp;WINCE系统用户接口实验-鼠标和小键盘驱动&nbsp;<br />5&nbsp;WINCE下PS2键盘驱动程序设计&nbsp;<br />6&nbsp;WINCE系统触摸屏实验&nbsp;<br />7&nbsp;wince下直流电机、步进电机完成控制实验<br />8&nbsp;wince&nbsp;下CF卡&nbsp;驱动&nbsp;实验&nbsp;<br />第四章&nbsp;WinCE应用软件开发<br />1&nbsp;EVC软件环境建立实验&nbsp;<br />2&nbsp;简单MFC应用程序开发实验&nbsp;<br />3&nbsp;基于WINCE&nbsp;Directshow&nbsp;的多媒体播放机实验&nbsp;<br />第五章&nbsp;WINCE综合实验&nbsp;<br />1&nbsp;通讯软件实验&nbsp;<br />2&nbsp;GPRS实验&nbsp;<br />3&nbsp;GPS实验&nbsp;<br />4&nbsp;红外实验&nbsp;<br /><br />成功案例<br />北京航空航天大学<br />北京理工大学<br />华南理工大学<br />中山大学<br />华南师范大学<br />桂林工学院<br />河北工程学院<br />大连东软信息职业技术学院<br />岭南学院<br />上海应用技术学院<br />广州大学<br />中国矿业大学<br />私立华联大学<br />南海东软信息技术职业学院<br />大连理工大学<br />沈阳农业大学<br />华东理工大学<br />中国地质大学<br />广东工业大学<br />广州大学松田学院<br />五邑大学<br />茂名学院<br />嘉应学院<br />广东培正学院<br />佛山科学技术学院<br />长沙学院<br />桂林电子工程学院<br />桂林航天工业高等专科学院&nbsp;<br /><br /><br /> 相关链接:<a href='http://www.gd-emb.com'>http://www.gd-emb.com</a>
