[STM32F0] 如何实现2路互补输出,带死区插入,频率可调的PWM波
2046|8
 楼主| 梦来是缘 发表于 2014-4-17 10:10 | 显示全部楼层 |阅读模式
通过改变period可以改变频率   但是输出波形有尖峰,
void int_timer1(void)
        GPIO_InitTypeDef GPIO_InitStruct;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8 ;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP ;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_Level_3;
        GPIO_Init(GPIOA, &GPIO_InitStruct);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
        GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13 ;
        GPIO_Init(GPIOB, &GPIO_InitStruct);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_2);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_2);
void cfg_timer1_PWM(uint32_t period)
        uint32_t TimerPeriod = (SystemCoreClock / period ) - 1;
        uint32_t Channel1Pulse = (uint16_t) (((uint32_t) 5 * (TimerPeriod - 1)) / 10);
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);
        TIM_TimeBaseStructure.TIM_Prescaler = 0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
        //TIM1->ARR =period-1;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_Pulse =Channel1Pulse;
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);
        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
        TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
        TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
        TIM_BDTRInitStructure.TIM_DeadTime = 11;
        TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
        TIM_BDTRConfig(TIM1, &TIM_BDTRInitStructure);
        TIM_Cmd(TIM1, ENABLE);
        TIM_CtrlPWMOutputs(TIM1, ENABLE);
 楼主| 梦来是缘 发表于 2014-4-17 10:27 | 显示全部楼层
希望大家给个建议
huzi2099 发表于 2014-4-17 10:47 | 显示全部楼层
希望大家给个建议
开启预装
 楼主| 梦来是缘 发表于 2014-4-17 10:57 | 显示全部楼层
TIM_ARRPreloadConfig(TIM1, ENABLE); 是这个吗?
开启预装
huzi2099 发表于 2014-4-17 11:16 | 显示全部楼层
不更新没毛病,就是这个
 楼主| 梦来是缘 发表于 2014-4-24 12:19 | 显示全部楼层
恩是这个   我试过了
拿起书本 发表于 2014-4-24 16:59 | 显示全部楼层
试过后结果如何呢?期待楼主的分享哦。
 楼主| 梦来是缘 发表于 2014-7-21 13:33 | 显示全部楼层
