[i.MX] Marsboard iMX6D 使用串口1 作为console终端的问题!
2914|9
 楼主| uwyyk28 发表于 2014-4-26 22:48 | 显示全部楼层 |阅读模式
默认Marsboard的console终端用的是串口2,想试着用串口1作为console终端来显示启动信息(注:串口1已测试过,工作正常),但在Uboot的Starting Kernel ...这里卡住了,信息如下:
Bytes transferred = 3235860 (316014 hex)
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.15_geeb0c0e
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3235796 Bytes =  3.1 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uboot使用的是英佩特官方提供的,print信息如下:
baudrate=115200
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
ethaddr=00:01:02:03:04:05
uboot=u-boot.bin
kernel=uImage
bootargs_nfs=setenv bootargs ${bootargs} root=/dev/nfs ip=dhcp nfsroot=${serverip}{nfsroot},v3,tcp enable_wait_mode=off
bootcmd_net=dhcp; run bootargs_nfs;bootm
bootargs_mmc1=setenv bootargs ${bootargs} root=/dev/mmcblk1p1 rootwait rw
bootcmd_mmc0=run bootargs_mmc0;mmc dev 1;mmc read ${loadaddr} 0x800 0x2000;bootm
bootcmd_mmc1=run bootargs_mmc1;mmc dev 1;mmc read ${loadaddr} 0x800 0x2000;bootm
bootcmd=if mmc dev 0; then run bootcmd_mmc1; else run bootcmd_mmc0; fi
clearenv=sf probe 0 && sf erase 0xc0000 0x2000 && echo restored environment to factory default
upgradeu=for disk in 0 1 ; do mmc dev ${disk} ;for fs in fat ext2 ; do ${fs}load mmc ${disk}:1 10008000 /6q_upgrade && source 10008000 ; done ; done
bootfile=_BOOT_FILE_PATH_IN_TFTP_
nfsroot=_ROOTFS_PATH_IN_NFS_
ethact=FEC0
bootdelay=1
ipaddr=192.168.0.168
serverip=192.168.0.6
gatewayip=192.168.0.1
stdin=serial
stdout=serial
stderr=serial
bootargs=console=ttymxc0,115200 video=mxcfb0:dev=lcd,4.3inch_LCD,if=RGB24
bootargs_mmc0=setenv bootargs console=ttymxc0,115200 video=mxcfb0:dev=lcd,4.3inch_LCD,if=RGB24 root=/dev/mmcblk0p1 rootwait rw
我已经修改了内核board-mx6q_marsboard.c文件里的mx6_marsboard_timer_init函数中的
early_console_setup(UART2_BASE_ADDR, uart_clk);
修改为
early_console_setup(UART1_BASE_ADDR, uart_clk);
请问大家,如何可以使用Uart1作为console终端,谢谢!
 楼主| uwyyk28 发表于 2014-4-27 23:43 | 显示全部楼层
自己搞定了,修改uboot的串口2为串口1即可完成。
FSL_TICS_ZJJ 发表于 2014-4-28 09:37 | 显示全部楼层
楼主如果问题解决了,还请帮我们结贴啊!
 楼主| uwyyk28 发表于 2014-4-28 10:20 | 显示全部楼层
结贴给分出现:分数未分配完,或分数分配存在错误!
 楼主| uwyyk28 发表于 2014-4-28 10:21 | 显示全部楼层
昨天就想结贴了,结不了!
FSL_TICS_ZJJ 发表于 2014-4-28 10:29 | 显示全部楼层
昨天就想结贴了,结不了!
那可能时间还没有到,一般要过几天才可以结贴。
再等两天吧,月底前帮我结贴就行了。谢谢啊!
FSL_TICS_Rita 发表于 2014-4-28 10:46 | 显示全部楼层
楼主你好,保证你的10分都分掉的话才可以结贴,也就是在分数处将你的分给掉。建议你再试一下。你可以参考帖子:本论坛中结贴方式
FSL_TICS_Rita 发表于 2014-4-28 10:47 | 显示全部楼层
如有问题再联系我们:)~~
 楼主| uwyyk28 发表于 2014-4-28 13:02 | 显示全部楼层
好的,过几天能结了,我就结贴
FSL_TICS_ZJJ 发表于 2014-4-28 13:43 | 显示全部楼层
好的,过几天能结了,我就结贴
好的,感谢你的配合!
