CRC校验的程序分享
1897|16
 楼主| yangguangaisha 发表于 2014-4-29 22:47 | 显示全部楼层 |阅读模式
const unsigned short crcLookupTable[256] = {
        0x00000,0x01189,0x02312,0x0329B,0x04624,0x057AD,0x06536,0x074BF,
        0x08C48,0x09DC1,0x0AF5A,0x0BED3,0x0CA6C,0x0DBE5,0x0E97E,0x0F8F7,
        0x01081,0x00108,0x03393,0x0221A,0x056A5,0x0472C,0x075B7,0x0643E,
        0x09CC9,0x08D40,0x0BFDB,0x0AE52,0x0DAED,0x0CB64,0x0F9FF,0x0E876,
        0x02102,0x0308B,0x00210,0x01399,0x06726,0x076AF,0x04434,0x055BD,
        0x0AD4A,0x0BCC3,0x08E58,0x09FD1,0x0EB6E,0x0FAE7,0x0C87C,0x0D9F5,
        0x03183,0x0200A,0x01291,0x00318,0x077A7,0x0662E,0x054B5,0x0453C,
        0x0BDCB,0x0AC42,0x09ED9,0x08F50,0x0FBEF,0x0EA66,0x0D8FD,0x0C974,
        0x04204,0x0538D,0x06116,0x0709F,0x00420,0x015A9,0x02732,0x036BB,
        0x0CE4C,0x0DFC5,0x0ED5E,0x0FCD7,0x08868,0x099E1,0x0AB7A,0x0BAF3,
        0x05285,0x0430C,0x07197,0x0601E,0x014A1,0x00528,0x037B3,0x0263A,
        0x0DECD,0x0CF44,0x0FDDF,0x0EC56,0x098E9,0x08960,0x0BBFB,0x0AA72,
        0x06306,0x0728F,0x04014,0x0519D,0x02522,0x034AB,0x00630,0x017B9,
        0x0EF4E,0x0FEC7,0x0CC5C,0x0DDD5,0x0A96A,0x0B8E3,0x08A78,0x09BF1,
        0x07387,0x0620E,0x05095,0x0411C,0x035A3,0x0242A,0x016B1,0x00738,
        0x0FFCF,0x0EE46,0x0DCDD,0x0CD54,0x0B9EB,0x0A862,0x09AF9,0x08B70,
        0x08408,0x09581,0x0A71A,0x0B693,0x0C22C,0x0D3A5,0x0E13E,0x0F0B7,
        0x00840,0x019C9,0x02B52,0x03ADB,0x04E64,0x05FED,0x06D76,0x07CFF,
        0x09489,0x08500,0x0B79B,0x0A612,0x0D2AD,0x0C324,0x0F1BF,0x0E036,
        0x018C1,0x00948,0x03BD3,0x02A5A,0x05EE5,0x04F6C,0x07DF7,0x06C7E,
        0x0A50A,0x0B483,0x08618,0x09791,0x0E32E,0x0F2A7,0x0C03C,0x0D1B5,
        0x02942,0x038CB,0x00A50,0x01BD9,0x06F66,0x07EEF,0x04C74,0x05DFD,
        0x0B58B,0x0A402,0x09699,0x08710,0x0F3AF,0x0E226,0x0D0BD,0x0C134,
        0x039C3,0x0284A,0x01AD1,0x00B58,0x07FE7,0x06E6E,0x05CF5,0x04D7C,
        0x0C60C,0x0D785,0x0E51E,0x0F497,0x08028,0x091A1,0x0A33A,0x0B2B3,
        0x04A44,0x05BCD,0x06956,0x078DF,0x00C60,0x01DE9,0x02F72,0x03EFB,
        0x0D68D,0x0C704,0x0F59F,0x0E416,0x090A9,0x08120,0x0B3BB,0x0A232,
        0x05AC5,0x04B4C,0x079D7,0x0685E,0x01CE1,0x00D68,0x03FF3,0x02E7A,
        0x0E70E,0x0F687,0x0C41C,0x0D595,0x0A12A,0x0B0A3,0x08238,0x093B1,
        0x06B46,0x07ACF,0x04854,0x059DD,0x02D62,0x03CEB,0x00E70,0x01FF9,
        0x0F78F,0x0E606,0x0D49D,0x0C514,0x0B1AB,0x0A022,0x092B9,0x08330,
        0x07BC7,0x06A4E,0x058D5,0x0495C,0x03DE3,0x02C6A,0x01EF1,0x00F78
unsigned short Get_CRC(unsigned char *bufptr, int len){
        unsigned short crc = 0xffff;
        while(len-- > 0){
                crc = (crc >> 8) ^ crcLookupTable[(crc ^ *bufptr++) & 0xff];
        return (~crc);
 楼主| yangguangaisha 发表于 2014-4-29 22:48 | 显示全部楼层
前段时间使用CY8C27443时用到了CRC校验,感觉不错,挺有用的。把代码发上来,跟大家分享一下,呵呵。
specialfrin 发表于 2014-4-30 13:24 | 显示全部楼层
= = 能不能给点文字说明
someontime 发表于 2014-4-30 13:33 | 显示全部楼层
谢谢分享 只是还得再慢慢研究一下
haidixibahe 发表于 2014-4-30 13:35 | 显示全部楼层
楼主能不能解释一下呢?
chao11yue 发表于 2014-4-30 21:29 | 显示全部楼层
下次试试楼主的代码
engtafanzhuan 发表于 2014-4-30 21:33 | 显示全部楼层
谢谢分享 可以做一下参考
xichengmadia 发表于 2014-4-30 21:39 | 显示全部楼层
CY8C27443怎么样?
beiwaroad 发表于 2014-4-30 21:49 | 显示全部楼层
顶一下 楼主写的很认真
taihezhibanh 发表于 2014-4-30 21:57 | 显示全部楼层
CRC校验确实不错
heibaiyinjiag 发表于 2014-4-30 22:00 | 显示全部楼层
楼主有些问题不是特别懂 可以指教一下吗
sishangcine 发表于 2014-4-30 22:08 | 显示全部楼层
没有文字说明怎么用啊
zgsxhzac 发表于 2014-4-30 22:11 | 显示全部楼层
回去尝试一下吧 还没接触过这里
shibalihuandao 发表于 2014-4-30 22:19 | 显示全部楼层
学习了 虽然还不知道怎么用 谢谢分享
meishizhaoshi 发表于 2014-4-30 22:59 | 显示全部楼层
顶一下 这个代码还是第一次见
hotpower 发表于 2015-9-27 13:20 来自手机 | 显示全部楼层
http://www.21ic.com/tools/HotWC3_V1.11.html
把权值改为1189即可自动生成表格和源程序
