c6722 读写flash
1224|2
 楼主| zxw_download 发表于 2014-4-30 14:36 | 显示全部楼层 |阅读模式
请问哪位有tms320c6722读写flash(sst29le010)的例程没?我现在调试flash读写时自能读不能写不知道怎么回事??
jxmzzr 发表于 2014-6-3 16:55 | 显示全部楼层
是不是使用什么命令擦除整个flash了呢?
zhangmangui 发表于 2014-6-3 21:26 | 显示全部楼层
//初始化高位地址线
void init_gpio(void)
                /* set McAsp0 as GPIO*/
                //A12  -  AMUTE0
        *(int *)PFU_MCASP0 |= 0x02000000;
        *(int *)DIR_MCASP0 |= 0x02000000;
        *(int *)OUT_MCASP0 &= ~0x02000000;
                /* set McAsp1 as GPIO*/
                             // A13-AMUTE1 | A14-AHCLKX1 | A15-ACLKX1 | A16-ACLKR1
        *(int *)PFU_MCASP1 |= 0x4e000000;
        *(int *)DIR_MCASP1 |= 0x4e000000;
        *(int *)OUT_MCASP1 &= ~0x4e000000;
//设置高位地址
void setGPIOHiAddr(int addr)
//A12-AMUTE0
//A13-AMUTE1
//A14-AHCLKX1
//A15-ACLKX1
//A16-ACLKR1
        int out1 = *(int *)OUT_MCASP0;
        int out2 = *(int *)OUT_MCASP1;
        out1 &= ~0x02000000;
        out1 |= (addr << 13) & 0x02000000;
         *(int *)OUT_MCASP0 = out1;
        out2 &= ~0x4e000000;
        out2 |= (addr << 13) & 0x20000000;
        out2 |= (addr << 13) & 0x08000000;
        out2 |= (addr << 11) & 0x04000000;
        out2 |= (addr << 12) & 0x02000000;
         *(int *)OUT_MCASP1 = out2;
//擦除flash
void eeprom_erase(void)
                setGPIOHiAddr((int)FLASH_5555);
                *(unsigned volatile char *)(FLASH_5555) = 0xaa;
                setGPIOHiAddr((int)FLASH_2AAA);
                *(unsigned volatile char *)(FLASH_2AAA) = 0x55;
                *(unsigned volatile char *)(FLASH_5555) = 0x80;
                *(unsigned volatile char *)(FLASH_5555) = 0x10;
