[STM8] STM8L PWM输出问题
1416|1
 楼主| tiantangwuzhe 发表于 2014-4-30 23:33 | 显示全部楼层 |阅读模式
/*使用定时器1的通道1输出PWM*/
void TIM1_PWM_Initial(void)
  TIM1_DeInit();
  TIM1_TimeBaseInit(0x0000, TIM1_CounterMode_Up, 500, 0x01);
  TIM1_OC1Init(TIM1_OCMode_PWM1,
               TIM1_OutputState_Enable,
               TIM1_OutputNState_Disable,
               200,//占空比
               TIM1_OCPolarity_High,
               TIM1_OCNPolarity_High,
               TIM1_OCIdleState_Set,
               TIM1_OCNIdleState_Set);
  TIM1_OC1PreloadConfig(ENABLE);
  TIM1_Cmd(ENABLE);
    TIM1->BKR |=0x80;//主使能
void main(void)
  CLK_HSICmd(ENABLE);
  TIM1_PWM_Initial();
  /* Executive loop, runs continually after initialization */
  while (1)
gufeng1 发表于 2014-5-1 12:08 | 显示全部楼层
重复发帖
