[AVR单片机] AVR,用12864乱码,是什么原因,找了好久。
1738|3
 楼主| shi910229 发表于 2014-5-1 15:16 | 显示全部楼层 |阅读模式
主函数:
#include "iom16a.h"
#include "init_mcu.h"
#include "LCD12864-S.h"
#include "keyboard&menu.h"
#include "data_processing.h"
#define set_bit(x,y)  (x|=(1<<y))
#define clr_bit(x,y)  (x&=~(1<<y))
extern char LCD12864_table1[17];
extern unsigned long int frequency_r_fix,frequency_c_fix,frequency_l_fix;
extern unsigned char key1num;
void main( void )
  init_mcu();
  LCD12864_init();
  LCD12864_display();
  set_bit(GICR,6);clr_bit(GICR,7);clr_bit(GICR,5);
  while(1)
    keyscan();
    switch(key1num)
      case 0:r_processing();break;
      case 1:c_processing();break;
      case 2:l_processing();break;
      default :break;
    LCD12864_display();
12864串口通信:
#include "iom16a.h"
#define LCD12864_SID_1 set_bit(PORTC,6)
#define LCD12864_SID_0 clr_bit(PORTC,6)
#define LCD12864_SCLK_1 set_bit(PORTC,7)
#define LCD12864_SCLK_0 clr_bit(PORTC,7)
char LCD12864_table1[17]={"   RLC测量仪-R  "};
char LCD12864_table2[17]={"换档:自动      "};
char LCD12864_table3[17]={"量程:          "};
char LCD12864_table4[17]={"请稍等...       "};
void LCD12864_delay1us(unsigned char LCD12864_us)        //延时1us,16M/4T
        unsigned int LCD12864_delay;
        for(LCD12864_delay=0;LCD12864_delay<LCD12864_us;LCD12864_delay++)
          unsigned char a,b;
          for(b=1;b>0;b--)
              for(a=1;a>0;a--);
void LCD12864_write_byte(unsigned char LCD12864_byte)
        unsigned char LCD12864_i;
        for(LCD12864_i=0;LCD12864_i<8;LCD12864_i++)
                if(LCD12864_byte&0x80)LCD12864_SID_1;
                else LCD12864_SID_0;
                LCD12864_delay1us(20);
                LCD12864_SCLK_1;
                LCD12864_SCLK_0;
                LCD12864_byte<<=1;
void LCD12864_write_comm(unsigned char LCD12864_comm)
        unsigned char Scomm,Hcomm,Lcomm;
        Scomm=0xf8;                                        //写指令
        Hcomm=LCD12864_comm&0xf0;
        Lcomm=(LCD12864_comm<<4)&0xf0;
        LCD12864_write_byte(Scomm);
        LCD12864_write_byte(Hcomm);
        LCD12864_write_byte(Lcomm);
void LCD12864_write_data(unsigned char LCD12864_data)
        unsigned char Sdata,Hdata,Ldata;
        Sdata=0xfa;                                        //写数据
        Hdata=LCD12864_data&0xf0;
        Ldata=(LCD12864_data<<4)&0xf0;
        LCD12864_write_byte(Sdata);
        LCD12864_write_byte(Hdata);
        LCD12864_write_byte(Ldata);
void LCD12864_init()
        LCD12864_write_comm(0x30);                //基本指令集
        LCD12864_write_comm(0x02);                //地址归位
        LCD12864_write_comm(0x0c);                //整体显示打开,游标关闭
        LCD12864_write_comm(0x01);                //清除显示
        LCD12864_write_comm(0x06);                //光标从右向左加一位移动
void LCD12864_display()
        LCD12864_write_comm(0x80);
        for(LCD12864_i=0;LCD12864_i<16;LCD12864_i++)
                LCD12864_write_data(LCD12864_table1[LCD12864_i]);
        LCD12864_write_comm(0x90);
                LCD12864_write_data(LCD12864_table2[LCD12864_i]);
        LCD12864_write_comm(0x88);
                LCD12864_write_data(LCD12864_table3[LCD12864_i]);
        LCD12864_write_comm(0x98);
                LCD12864_write_data(LCD12864_table4[LCD12864_i]);
void LCD12864_display_line1()
void LCD12864_display_line2()
void LCD12864_display_line3()
void LCD12864_display_line4()
ningling_21 发表于 2014-5-2 15:56 | 显示全部楼层
用示波器看波形,对时序...
jiangshaoxing 发表于 2014-5-22 15:12 来自手机 | 显示全部楼层
半角全角
半角全角
