AD转换的程序
1113|7
 楼主| chuxh 发表于 2014-5-5 19:09 | 显示全部楼层 |阅读模式
哪位大神能给个430 AD转换的程序啊?
pengf 发表于 2014-5-5 19:09 | 显示全部楼层
什么要求啊
 楼主| chuxh 发表于 2014-5-5 19:12 | 显示全部楼层
系统是由TimerA控制的,每个脉冲到来的时候就进行一次AD转换,然后把转换的数据存起来。
AD转换是单通道的。
栩栩如生 发表于 2014-5-5 19:13 | 显示全部楼层
TI官网上有例程的,你去下载过来呗~
houcs 发表于 2014-5-5 19:14 | 显示全部楼层
//  MSP430F21x2 Demo - ADC10, Sample A0, 1.5V Ref, Set P1.0 if A0 > 0.2V
//  Description: A single sample is made on A0 with reference to internal
//  1.5V Vref. Software sets ADC10SC to start sample and conversion - ADC10SC
//  automatically cleared at EOC. ADC10 internal oscillator times sample (16x)
//  and conversion. In Mainloop MSP430 waits in LPM0 to save power until ADC10
//  conversion complete, ADC10_ISR will force exit from LPM0 in Mainloop on
//  reti. If A0 > 0.2V, P1.0 set, else reset.
//                MSP430F21x2
//         /|\|              XIN|-
//          --|RST          XOUT|-
//        >---|P2.0/A0      P1.0|-->LED
//  A. Dannenberg
//  Texas Instruments Inc.
//  December 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x21x2.h"
void main(void)
   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
   ADC10CTL0 = SREF_1 + ADC10SHT_2 + REFON + ADC10ON + ADC10IE;
   TACCR0 = 30;                              // Delay to allow Ref to settle
   TACCTL0 |= CCIE;                          // Compare-mode interrupt.
   TACTL = TASSEL_2 + MC_1;                  // TACLK = SMCLK, Up mode.
   __bis_SR_register(CPUOFF + GIE);          // LPM0, TA0_ISR will force exit
   TACCTL0 &= ~CCIE;                         // Disable timer Interrupt
   ADC10AE0 |= 0x01;                         // P2.0 ADC option select
   P1DIR |= 0x01;                            // Set P1.0 to output direction
  for (;;)
     ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
     __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
     if (ADC10MEM < 0x88)                    // ADC10MEM = A0 > 0.2V?
       P1OUT &= ~0x01;                       // Clear P1.0 LED off
     else
       P1OUT |= 0x01;                        // Set P1.0 LED on
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
   __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
#pragma vector=TIMERA0_VECTOR
__interrupt void TA0_ISR(void)
   TACTL = 0;
   LPM0_EXIT;                                // Exit LPM0 on return
 楼主| chuxh 发表于 2014-5-5 19:15 | 显示全部楼层
嗯,我知道了
多谢大神啊
