MINI2440(S3C2440、ARM9)开发板+3.5寸触摸屏=620
2174|1
 楼主| cmnet 发表于 2008-10-23 10:41 | 显示全部楼层 |阅读模式
<br /><br />最新版mini2440现已到货,需要的尽快联系!<br /><br />本店友善VIP代理,质量保证!<br /><br />凡在本店购物,可享受厂家直接的技术支持!让每位客户买的物有所值!<br /><br /><br /><br /><br /><br />硬件配置:&nbsp;<br />项目(Item)&nbsp;中文&nbsp;English&nbsp;<br />处理器(CPU)&nbsp;三星S3C2440(ARM920T&nbsp;core&nbsp;with&nbsp;MMC,&nbsp;最高主频可达532MHz)&nbsp;Samsung&nbsp;S3C2440(ARM920T&nbsp;core&nbsp;with&nbsp;MMC,&nbsp;Up&nbsp;to&nbsp;532MHz)&nbsp;<br />内存(SDRAM)&nbsp;64Mbyte&nbsp;64Mbyte&nbsp;<br />Flash&nbsp;64Mbyte&nbsp;Nand&nbsp;Flash&nbsp;+&nbsp;2M&nbsp;Nor&nbsp;Flash(已经安装了BIOS)&nbsp;64Mbyte&nbsp;Nand&nbsp;Flash&nbsp;+&nbsp;2M&nbsp;Nor&nbsp;Flash(BIOS&nbsp;installed)&nbsp;<br />液晶屏支持(LCD&nbsp;Support)&nbsp;●板上集成4线电阻式触摸屏接口,可以直接连接四线电阻触摸屏<br />●&nbsp;支持黑白、4级灰度、16级灰度、256色、4096色STN液晶屏,尺寸&nbsp;从3.5寸到12.1寸,屏幕分辨率可以达到1024x768象素;<br />●&nbsp;支持黑白、4级灰度、16级灰度、256色、64K色、真彩色TFT液晶屏,尺寸从3.5寸到12.1寸,屏幕分辨率可以达到1024x768象素;<br />●&nbsp;标准配置为NEC&nbsp;256K色240x320/3.5英寸TFT真彩液晶屏,带触摸屏;<br />●&nbsp;板上引出一个12V电源接口,可以为大尺寸TFT液晶的12V&nbsp;CCFL背光模块(Inverting)供电。&nbsp;STN&nbsp;LCD&nbsp;Displays:<br />●Supports&nbsp;3&nbsp;types&nbsp;of&nbsp;LCD&nbsp;panels:&nbsp;4-bit&nbsp;dual&nbsp;scan,&nbsp;4-bit&nbsp;single&nbsp;scan,&nbsp;and&nbsp;8-bit&nbsp;single&nbsp;scan&nbsp;display&nbsp;type<br />●&nbsp;Supports&nbsp;the&nbsp;monochrome,&nbsp;4&nbsp;gray&nbsp;levels,&nbsp;and&nbsp;16&nbsp;gray&nbsp;levels<br />●Supports&nbsp;256&nbsp;colors&nbsp;and&nbsp;4096&nbsp;colors&nbsp;for&nbsp;color&nbsp;STN&nbsp;LCD&nbsp;panel<br />●Supports&nbsp;multiple&nbsp;screen&nbsp;size<br />Typical&nbsp;actual&nbsp;screen&nbsp;size:640&nbsp;x&nbsp;480,&nbsp;320&nbsp;x&nbsp;240,&nbsp;160&nbsp;x&nbsp;160,&nbsp;and&nbsp;others<br />TFT&nbsp;LCD&nbsp;Displays:<br />●&nbsp;Supports&nbsp;1,&nbsp;2,&nbsp;4&nbsp;or&nbsp;8-bpp&nbsp;(bit&nbsp;per&nbsp;pixel)&nbsp;palletized&nbsp;color&nbsp;displays&nbsp;for&nbsp;TFT<br />●&nbsp;Supports&nbsp;16,&nbsp;24-bpp&nbsp;non-palletized&nbsp;true-color&nbsp;displays&nbsp;for&nbsp;color&nbsp;TFT<br />●Supports&nbsp;maximum&nbsp;16M&nbsp;color&nbsp;TFT&nbsp;at&nbsp;24bit&nbsp;per&nbsp;pixel&nbsp;mode<br />●&nbsp;Supports&nbsp;multiple&nbsp;screen&nbsp;size<br />Typical&nbsp;actual&nbsp;screen&nbsp;size:&nbsp;1024x768&nbsp;640&nbsp;x&nbsp;480,&nbsp;320&nbsp;x&nbsp;240,&nbsp;160&nbsp;x&nbsp;160,&nbsp;and&nbsp;others&nbsp;<br />USB端口(USB&nbsp;Port)&nbsp;1个主USB接口,1个从USB接口&nbsp;1&nbsp;USB&nbsp;host&nbsp;and&nbsp;1&nbsp;USB&nbsp;device&nbsp;<br />音频(Audio)&nbsp;1路立体声音频输出接口(标准3.5mm接口),1路麦克风接口&nbsp;Audio&nbsp;Input/Output&nbsp;<br />网络(LAN)&nbsp;1个100M以太网RJ-45口(采用DM9000网卡)&nbsp;1&nbsp;10M&nbsp;Ethernet&nbsp;interface&nbsp;(RJ-45&nbsp;interface)&nbsp;<br />SD/MMC卡&nbsp;1个SD/MMC卡存储接口&nbsp;SD&nbsp;card&nbsp;interface&nbsp;and&nbsp;holder&nbsp;<br />摄像头(Cemera)&nbsp;引出CPU内部全部摄像头信号引脚&nbsp;All&nbsp;CEMERA&nbsp;signal&nbsp;pin&nbsp;out&nbsp;<br />串口(UART)&nbsp;3个串行口,&nbsp;COM0为RS232&nbsp;DB9接口(亦引出TTL接口),COM2和COM3为2.0mm间距&nbsp;1&nbsp;RS232&nbsp;serial&nbsp;port,&nbsp;3&nbsp;serial&nbsp;ports&nbsp;available&nbsp;through&nbsp;14pin&nbsp;(2.0mm&nbsp;space)&nbsp;interface&nbsp;<br />Jtag&nbsp;标转JTAG接口(2.0mm间距)&nbsp;standard&nbsp;JTAG&nbsp;interface)&nbsp;<br />按键(buttons)&nbsp;6个用户按键&nbsp;6&nbsp;Test&nbsp;buttons&nbsp;<br />LEDs&nbsp;4个用户指示灯&nbsp;4&nbsp;Status&nbsp;LEDs&nbsp;<br />I2C器件(I2C&nbsp;bus)&nbsp;AT24C08&nbsp;AT24C08&nbsp;<br />AD输入(AD&nbsp;input)&nbsp;可调电阻AD输入实验&nbsp;AD&nbsp;input&nbsp;test&nbsp;<br />PWM&nbsp;控制蜂鸣器&nbsp;PWM&nbsp;控制蜂鸣器&nbsp;PWM&nbsp;controlling&nbsp;speaker&nbsp;<br />实时时钟(RTC)&nbsp;板载实时时钟,带有备份锂电池&nbsp;RTC&nbsp;(battery&nbsp;backed)&nbsp;<br />扩展接口(Expansion)&nbsp;●1个34pin&nbsp;2.0mmGPIO接口<br />●1个40pin&nbsp;2.0mm系统总线接口&nbsp;●34pin&nbsp;GPIO&nbsp;expansion&nbsp;connector<br />●40&nbsp;pin&nbsp;System&nbsp;bus&nbsp;expansion&nbsp;connector&nbsp;<br />电源输入(Power&nbsp;Suuply)&nbsp;5V电源输入&nbsp;+5V&nbsp;<br />尺寸(Dimensions)&nbsp;100x100&nbsp;mm&nbsp;100x100&nbsp;mm&nbsp;<br /><br />&nbsp;&nbsp;<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;<br /><br /><br />&nbsp;<br /><br />&nbsp;<br />说明书下载地址:<br /><br />&nbsp;<br /><br />http://www.arm9.net/mini2440-um-20080915.rar<br /><br />1.1&nbsp;MINI2440&nbsp;开发板简介<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;mini2440&nbsp;是一款低价实用的ARM9&nbsp;开发板,是目前国内性价比最高的一款学习板;<br />它采用Samsung&nbsp;S3C2440&nbsp;为微处理器,并采用专业稳定的CPU&nbsp;内核电源芯片和复位芯片来保<br />证系统运行时的稳定性。mini2440&nbsp;的PCB&nbsp;采用沉金工艺的四层板设计,专业等长布线,保证<br />关键信号线的信号完整性,生产采用机器贴片,批量生产;出厂时都经过严格的质量控制,<br />配合这本十分详细的手册,可以迅速帮你掌握嵌入式Linux&nbsp;和WinCE&nbsp;开发的流程,只要有C<br />语言基础的人一般2&nbsp;周即可入门。<br />&nbsp;<br /><br />1.1.2&nbsp;MINI2440&nbsp;开发板硬件资源特性<br />z&nbsp;CPU&nbsp;处理器<br />-&nbsp;Samsung&nbsp;S3C2440A,主频400MHz,最高533Mhz<br />z&nbsp;SDRAM&nbsp;内存<br />-&nbsp;在板64M&nbsp;SDRAM<br />-&nbsp;32bit&nbsp;数据总线<br />-&nbsp;SDRAM&nbsp;时钟频率高达100MHz<br />z&nbsp;FLASH&nbsp;存储<br />-&nbsp;在板64M&nbsp;Nand&nbsp;Flash,&nbsp;掉电非易失<br />-&nbsp;在板2M&nbsp;Nor&nbsp;Flash,掉电非易失,已经安装BIOS<br />z&nbsp;LCD&nbsp;显示<br />-&nbsp;板上集成4&nbsp;线电阻式触摸屏接口,可以直接连接四线电阻触摸屏<br />-&nbsp;支持黑白、4&nbsp;级灰度、16&nbsp;级灰度、256&nbsp;色、4096&nbsp;色STN&nbsp;液晶屏,尺寸从3.5&nbsp;寸到12.1<br />寸,屏幕分辨率可以达到1024x768&nbsp;象素;<br />-&nbsp;支持黑白、4&nbsp;级灰度、16&nbsp;级灰度、256&nbsp;色、64K&nbsp;色、真彩色TFT&nbsp;液晶屏,尺寸从3.5&nbsp;寸<br />到12.1&nbsp;寸,屏幕分辨率可以达到1024x768&nbsp;象素;<br />-&nbsp;标准配置为NEC&nbsp;256K&nbsp;色240x320/3.5&nbsp;英寸TFT&nbsp;真彩液晶屏,带触摸屏;<br />-&nbsp;板上引出一个12V&nbsp;电源接口,可以为大尺寸TFT&nbsp;液晶的12V&nbsp;CCFL&nbsp;背光模块(Inverting)<br />供电。<br />z&nbsp;接口和资源<br />-&nbsp;1&nbsp;个100M&nbsp;以太网RJ-45&nbsp;接口(采用DM9000&nbsp;网络芯片)<br />-&nbsp;3&nbsp;个串行口<br />-&nbsp;1&nbsp;个USB&nbsp;Host<br />-&nbsp;1&nbsp;个USB&nbsp;Slave&nbsp;B&nbsp;型接口<br />-&nbsp;1&nbsp;个SD&nbsp;卡存储接口<br />-&nbsp;1&nbsp;路立体声音频输出接口,一路麦克风接口;<br />-&nbsp;1&nbsp;个2.0mm&nbsp;间距10&nbsp;针JTAG&nbsp;接口<br />-&nbsp;4&nbsp;USER&nbsp;Leds<br />-&nbsp;6&nbsp;USER&nbsp;buttons(带引出座)<br />-&nbsp;1&nbsp;个PWM&nbsp;控制蜂鸣器<br />-&nbsp;1&nbsp;个可调电阻,用于AD&nbsp;模数转换测试<br />-&nbsp;1&nbsp;个I2C&nbsp;总线AT24C08&nbsp;芯片,用于I2C&nbsp;总线测试<br />-&nbsp;1&nbsp;个2.0&nbsp;mm&nbsp;间距20pin&nbsp;摄像头接口<br />-&nbsp;板载实时时钟电池<br />-&nbsp;电源接口(5V),带电源开关和指示灯<br />z&nbsp;系统时钟源<br />-&nbsp;12M&nbsp;无源晶振<br />z&nbsp;实时时钟<br />-&nbsp;内部实时时钟(带后备锂电池)<br /><br />z&nbsp;扩展接口<br />-&nbsp;1&nbsp;个34&nbsp;pin&nbsp;2.0mmGPIO&nbsp;接口<br />-&nbsp;1&nbsp;个40&nbsp;pin&nbsp;2.0mm&nbsp;系统总线接口<br />z&nbsp;规格尺寸<br />-&nbsp;100&nbsp;x&nbsp;100(mm)<br />z&nbsp;操作系统支持<br />-&nbsp;Linux2.6.13<br />-&nbsp;WindowsCE.NET&nbsp;5.0<br />1.1.3&nbsp;用户光盘资源说明<br />(1)ADS1.2&nbsp;安装程序<br />(2)H-JTAG&nbsp;烧写调试软件<br />(3)Windows&nbsp;下烧写Flash&nbsp;的软件SJF2440<br />(4)Linux&nbsp;下烧写Nand&nbsp;Flash&nbsp;的软件Jflash-2440(含源代码)<br />(5)串口工具CRT,&nbsp;dnw<br />(6)图片转C&nbsp;语言数组工具<br />(7)USB&nbsp;驱动(WindowXP/2000&nbsp;下安装使用)<br />(8)vivi&nbsp;源代码,用于linux&nbsp;的bootloaer<br />(9)最简单的测试程序(包含ADS1.20&nbsp;的项目文件),用于点亮板上的LED&nbsp;灯。<br />(10)2440test&nbsp;测试程序(包含ADS1.20&nbsp;的项目文件,全部源代码),测试项目包括:中断方式按<br />键测试,RTC&nbsp;实时时钟测试,ADC&nbsp;数模转换测试,IIS&nbsp;音频播放wav&nbsp;测试,IIS&nbsp;音频录音测试,<br />触摸屏测试,I2C&nbsp;总线读写AT24C08&nbsp;测试,三星3.5”LCD、640x480&nbsp;真彩液晶测试等<br />(11)WindowsCE&nbsp;BSP&nbsp;和示例项目文件<br />(12)linux&nbsp;开发工具和内核源代码包:<br />-&nbsp;arm-linux-gcc-3.3.2&nbsp;编译Qtopia&nbsp;使用<br />-&nbsp;arm-linux-gcc-3.4.1&nbsp;编译内核使用<br />-&nbsp;arm-linux-gcc-2.95.3&nbsp;编译vivi&nbsp;用<br />-&nbsp;yaffs&nbsp;文件系统映象制作工具mkyaffsimage<br />-&nbsp;linux-2.6.13&nbsp;for&nbsp;MINI2440&nbsp;内核源代码(包含DM9000&nbsp;驱动、各种真彩液晶驱动、声卡驱动、<br />触摸屏驱动、YAFFS&nbsp;源代码、SD&nbsp;卡驱动、RTC&nbsp;驱动、扩展串口驱动、各种USB&nbsp;摄像头驱动、<br />USB&nbsp;鼠标和键盘、优盘驱动等)<br />(13)嵌入式图形界面Qtopia&nbsp;源代码包,嵌入式浏览器源代码包<br />(14)开发板原理图(Protel99SE&nbsp;格式/PDF&nbsp;格式)<br />(15)用户手册(pdf&nbsp;格式)<br /><br />&nbsp;<br /><br />1.3&nbsp;linux&nbsp;特性<br />z&nbsp;版本<br />-&nbsp;Linux2.6.13<br /><br />z&nbsp;支持的文件系统<br />-&nbsp;yaffs(可读写的文件系统,推荐使用)<br />-&nbsp;cramfs(压缩的只读文件系统,不在线更新数据时推荐使用)<br />-&nbsp;Ext2<br />-&nbsp;Fat32<br />-&nbsp;NFS(网络文件系统,开发驱动程序及应用程序时方便使用)<br />z&nbsp;基本驱动程序(以下驱动均以源代码方式提供)<br />-&nbsp;3&nbsp;串口标准驱动<br />-&nbsp;DM9000&nbsp;驱动程序<br />-&nbsp;声音驱动<br />-&nbsp;RTC&nbsp;驱动(可掉电保存时间)<br />-&nbsp;用户LED&nbsp;灯驱动<br />-&nbsp;USB&nbsp;Host&nbsp;驱动<br />-&nbsp;常见液晶驱动<br />-&nbsp;触摸屏驱动<br />-&nbsp;USB&nbsp;摄像头,支持网眼、中芯微芯片的摄像头<br />-&nbsp;USB&nbsp;鼠标、USB&nbsp;键盘驱动、优盘、移动硬盘<br />-&nbsp;SD&nbsp;卡驱动,最大可支持2G<br />z&nbsp;Linux&nbsp;应用及服务程序<br />-&nbsp;busybox1.2.0(Linux&nbsp;工具集,包含常用Linux&nbsp;命令等)<br />-&nbsp;Telnet、Ftp、inetd(网络远程登录工具及服务)<br />-&nbsp;boa(web&nbsp;server)<br />-&nbsp;madplay(基于控制台的mp3&nbsp;播放器)<br />-&nbsp;snapshot(基于控制台的抓图软件)<br />-&nbsp;ishow(基于控制台的图片浏览软件)<br />-&nbsp;ifconfig、ping、route&nbsp;等(常用网络工具命令)<br />z&nbsp;嵌入式图形系统(以源代码方式提供)<br />-&nbsp;Qt/Embedded<br /><br /><br />1.4&nbsp;WindowsCE&nbsp;特性<br />z&nbsp;版本<br />-&nbsp;WindowsCE.net&nbsp;5.0<br />z&nbsp;特性<br />-&nbsp;DM9000&nbsp;网卡驱动源代码<br />-&nbsp;USB&nbsp;键盘、USB&nbsp;鼠标驱动、优盘、移动硬盘等<br />-&nbsp;三个串口驱动<br />-&nbsp;USB&nbsp;ActiveSync<br />-&nbsp;声音驱动<br />-&nbsp;SD&nbsp;卡驱动<br /><br />-&nbsp;注册表保存<br />-&nbsp;Flash&nbsp;剩余空间掉电保存数据<br />-&nbsp;屏幕可旋转<br />z&nbsp;缺省系统特性(简体中文系统)<br />-&nbsp;XP&nbsp;界面风格<br />-&nbsp;Windows&nbsp;Media&nbsp;Player&nbsp;9.0(支持mp3,&nbsp;mpeg2,&nbsp;mpeg4,&nbsp;wmv,&nbsp;wav&nbsp;等)<br />-&nbsp;超级播放器(类似windows&nbsp;下的暴风影音)<br />-&nbsp;图片浏览器、写字板<br />-&nbsp;IE6&nbsp;浏览器<br />-&nbsp;ftp、telnet、httpd&nbsp;服务器<br />-&nbsp;串口助手<br /><br /><br />本套餐邮寄清单:<br />?&nbsp;一片&nbsp;mini2440开发板<br />?&nbsp;一张&nbsp;DVD数据光盘(内置丰富开发资料)<br />?&nbsp;一条&nbsp;Jtag烧写线&nbsp;+&nbsp;Jtag下载小板<br />?&nbsp;一条&nbsp;USB&nbsp;电缆<br />?&nbsp;一条&nbsp;DB9&nbsp;直连串口线<br />?&nbsp;一条&nbsp;交叉网线<br />?&nbsp;一只&nbsp;5V&nbsp;稳压电源<br />?&nbsp;一款&nbsp;NEC3.5寸触摸屏(赠触摸笔一只)<br />
