用DAC0832输出正弦波遇到的问题,求大神,,在线等
1768|3
 楼主| 青上流云 发表于 2014-5-15 23:41 | 显示全部楼层 |阅读模式
做设计遇到一个问题,,请大家帮忙看看,,如图的电路安装经典的DAC0832双极性输出搭建的,按道理可以使0-255的数字量,但是我现在用这个数组输出得到的正弦波只有正半周期,不知怎么回事呀
uchar code sinewave2[]={
        128, 130, 132, 135, 137, 139, 141, 144, 146, 148,150, 152, 155,  //正弦函数点数组
    157, 159, 161, 163, 165, 168, 170,172, 174,176, 178, 180, 182,
        184, 186, 188, 190,192, 194, 196, 198, 200, 201, 203, 205, 207, 209,
    210, 212, 214, 215, 217, 219, 220, 222, 223, 225, 226,
    227, 229, 230, 232, 233, 234, 235, 237, 238,
    239, 240, 241, 242, 243, 244, 245, 246, 247, 247 ,
    248, 249, 250, 250, 251, 252, 252, 253, 253, 254,
    254, 254, 255, 255, 255, 255, 255, 255, 255, 255,
    255, 255, 255, 255, 255, 255, 255, 255, 255, 254,
    254, 254, 253, 253, 252, 252, 251, 250, 250, 249,
    248, 247, 247, 246, 245, 244, 243, 242, 241, 240,
    239, 238, 237, 235, 234, 233, 232, 230, 229, 227,
    226, 225, 223, 222, 220, 219, 217, 215, 214, 212 ,
    210, 209, 207, 205, 203, 201, 200, 198, 196, 194,
   192, 190, 188, 186, 184, 182, 180, 178, 176, 174,
    172, 170, 168, 165, 163, 161, 159, 157, 155, 152  ,
    150, 148, 146, 144, 141, 139, 137, 135, 132, 130 ,
    128, 126, 124, 121, 119, 117, 115, 112, 110, 108,
    106, 104, 101, 99, 97, 95, 93, 91, 88, 86,
    84, 82, 80, 78, 76, 74, 72, 70, 68, 66  ,
    64, 62, 60, 58, 56, 55, 53, 51, 49, 47 ,
    46, 44, 42, 41, 39, 37, 36, 34, 33, 31,
    30, 29, 27, 26, 24, 23, 22, 21, 19, 18,
    17, 16, 15, 14, 13, 12, 11, 10, 9, 9,
    8, 7, 6, 6, 5, 4, 4, 3, 3, 2,
    2, 2, 1, 1, 1, 0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0, 1, 1, 1, 2,
    2, 2, 3, 3, 4, 4, 5, 6, 6, 7,
   8, 9, 9, 10, 11, 12, 13, 14, 15, 16,
     17, 18, 19, 21, 22, 23, 24, 26, 27, 29,
    30, 31, 33, 34, 36, 37, 39, 41, 42, 44,
     46, 47, 49, 51, 53, 55, 56, 58, 60, 62,
    64, 66, 68, 70, 72, 74, 76, 78, 80, 82,
     84, 86, 88, 91, 93, 95, 97, 99, 101, 104,
     106, 108, 110, 112, 115, 117, 119, 121, 124, 126,
     128
kakaoracle 发表于 2014-11-12 23:33 | 显示全部楼层
airwill 发表于 2014-11-13 18:52 | 显示全部楼层
这个波形很漂亮, 信号输出也很稳定. 说明是电路(系统)设计问题.
从图上看, 不是 "正弦波只有正半周期", 而是再负半周的最底下一小部分出现了畸变.
我估计 DAC 的问题的可能性小, 这个可以直接测量一下 DAC 输出脚的波形来确认, 很可能是后面的运放的问题(前级的增益过大,导致后级超出共模范围)的可能性很大
 楼主| 青上流云 发表于 2016-2-21 15:07 | 显示全部楼层
汗颜,当年毕设遇到的问题,现在1年半后才回来看到......
