unresolved symbol Tx_FIFO_IndexW, first referenced i...
2528|1
 楼主| scutdianxin 发表于 2014-5-17 20:08 | 显示全部楼层 |阅读模式
Description        Resource        Path        Location        Type
unresolved symbol Tx_FIFO_IndexW, first referenced in ./targetConfigs/UART_FIFO.obj        Copy of Copy of y                         C/C++ Problem
unresolved symbol Tx_FIFO_IndexR, first referenced in ./targetConfigs/UART_FIFO.obj        Copy of Copy of y                         C/C++ Problem
#10234-D unresolved symbols remain        Copy of Copy of y                         C/C++ Problem
#10010 errors encountered during linking; "Copy of Copy of y.out" not built        Copy of Copy of y                         C/C++ Problem
这是怎么回事   ???
另外?在grace里面调用库函数也会出现类似的情况   求大神解答      急救   在单片机上投入太多时间了
zhangmangui 发表于 2014-6-2 23:38 | 显示全部楼层
没有遇到过 的错误  帮忙顶
