[i.MX] I.MX6Q 如何调出摄像头
6974|9
 楼主| lqland 发表于 2014-5-19 14:44 | 显示全部楼层 |阅读模式
进入I.MX6Q的开板命令行中
root@freescale ~$
然后,如何调出摄像头的功能?谢谢
FSL_TICS_A 发表于 2014-5-19 15:16 | 显示全部楼层
你好,楼主!
飞思卡尔论坛小组的I.MX工程师,有事请年假啊,周三才会回来,
到时我会向他转告你的问题,如有不便请谅解。
 楼主| lqland 发表于 2014-5-19 15:31 | 显示全部楼层
通过串口软件链接开发板,并且登陆
root@freescale
按文档:
root@freescale ~$ cd /unit_tests/
root@freescale /unit_tests$ ls
akiyo.mp4                               mxc_asrc_test.out
all-suite.txt                           mxc_cec_test.out
ar3k-bt-start.sh                        mxc_epdc_fb_test.out
audio8k16S.wav                          mxc_epdc_x11_fb_test.out
autorun-asrc.sh                         mxc_fb_test.out
autorun-ata.sh                          mxc_hdcp_app.out
autorun-fb.sh                           mxc_i2c_slave_test.out
autorun-firi.sh                         mxc_i2c_test.out
autorun-ipu.sh                          mxc_i2c_test_magna_cam.out
autorun-keypad.sh                       mxc_i2c_test_samsung_cam.out
autorun-mmc-blockrw.sh                  mxc_i2c_test_usb.out
autorun-mmc-fdisk.sh                    mxc_iim_test.out
autorun-mmc-fs.sh                       mxc_ipudev_test.out
autorun-mmc-mkfs.sh                     mxc_irlan_test.sh
autorun-mmc.sh                          mxc_isl29023.out
autorun-mxc_uart.sh                     mxc_keyb_test.sh
autorun-oprofile.sh                     mxc_l2switch_test.out
autorun-owire.sh                        mxc_mlb150_test.out
autorun-pf.sh                           mxc_mlb_test.out
autorun-rtc.sh                          mxc_pf_test.out
autorun-scc.sh                          mxc_sdma_test.out
autorun-scc2.sh                         mxc_spdc_fb_test.out
autorun-sound.sh                        mxc_spi_test1.out
autorun-usb-gadget.sh                   mxc_tuner_test.out
autorun-usb-host.sh                     mxc_tuner_test.sh
autorun-v4l2.sh                         mxc_tve_test.sh
autorun-vpu.sh                          mxc_uart_test.out
autorun-wdog.sh                         mxc_uart_xmit_test.out
autorun.sh                              mxc_v4l2_capture.out
check_2w1r.out                          mxc_v4l2_output.out
check_audio.out                         mxc_v4l2_overlay.out
check_ioctls.out                        mxc_v4l2_still.out
check_minor_open.out                    mxc_v4l2_tvin.out
check_mixer.out                         mxc_vpu_test.out
check_recording.out                     partition_tests.sh
check_synchronization.out               pxp_test.out
check_volume2.out                       rtc_timesetnotification_test.out
config_dec                              rtctest.out
config_enc                              rtcwakeup.out
config_encdec                           scc2_setup.sh
config_net                              scc2_test.out
dryice.sh                               scc_setup.sh
dump-clocks-dot.sh                      scc_test
dump-clocks.sh                          stefan_interlaced_320x240_5frames.yv12
encrypt_decrypt_tests.sh                suspend_quick_auto.sh
etm                                     suspend_random_auto.sh
fail_mode_tests.sh                      test-utils.sh
gpu.sh                                  test_subs.sh
hciattach-ar3k.bin                      wall-1024x768-565.rgb
ipudev_config_file                      wdt_driver_test.out
key_slot_tests.sh                       x11_overlay.out
memtool
root@freescale /unit_tests$ modprobe ipuv3_csi0_chess_camera
modprobe: module ipuv3_csi0_chess_camera not found in modules.dep
 楼主| lqland 发表于 2014-5-19 15:35 | 显示全部楼层
I.MX工程师不在,其他知道的朋友 点拨一下,谢谢
 楼主| lqland 发表于 2014-5-21 11:16 | 显示全部楼层
Rita ,你建议使用gstreamer,这两天查看资料,还是没有理出头绪,然后在安装插件的过程中,似乎又有问题。
 楼主| lqland 发表于 2014-5-23 16:25 | 显示全部楼层
SD卡启动开发板
   然后root进入
   再然后,通过命令:gst-­launch  mfw_v4lsrc ! mfw_v4lsink   要显示摄像头视频
   串口终端提示错误,请问如何解决??
root@freescale ~$
root@freescale ~$ echo 0 > /sys/class/graphics/fb0/blank
root@freescale ~$ modprobe ov5642_camera
camera ov5642 is not found
root@freescale ~$ lsmod
Module                  Size  Used by
ov5642_camera          74102  0
camera_sensor_clock      765  1 ov5642_camera
root@freescale ~$ modprobe mxc_v4l2_capture
Module                  Size  Used by
mxc_v4l2_capture       21621  0
ipu_csi_enc             2937  1 mxc_v4l2_capture
ipu_fg_overlay_sdc      4868  1 mxc_v4l2_capture
ipu_still               1703  1 mxc_v4l2_capture
ipu_bg_overlay_sdc      3925  1 mxc_v4l2_capture
ipu_prp_enc             4685  1 mxc_v4l2_capture
root@freescale ~$ gst?launch  mfw_v4lsrc ! mfw_v4lsink
-sh: gst?launch: not found
root@freescale ~$ gst-launch  mfw_v4lsrc ! mfw_v4lsink
MFW_GST_V4LSRC_PLUGIN 3.0.7 build on Aug 16 2013 20:15:40.
ERROR: v4l2 capture: slave not found!
MFW_GST_V4LSINK_PLUGIN 3.0ERROR: v4l2 capture: slave not found!
.7 build on Aug 16 2013 20:15:34.
Setting pipeline to PAUSED ...
ERROR: Pipeline doesn't want to pause.
Setting pipeline to NULL ...
Total rendered:0
Freeing pipeline ...
[--->FINALIZE v4l_sink
root@freescale ~$
FSL_TICS_Rita 发表于 2014-5-29 16:33 | 显示全部楼层
Rita ,你建议使用gstreamer,这两天查看资料,还是没有理出头绪,然后在安装插件的过程中,似乎又有问题。 ...
现在好了么?
 楼主| lqland 发表于 2014-5-29 18:33 | 显示全部楼层
现在好了么?
没有,结帖是误操作。晚上再重新测试确认,不行再重开帖了。
FSL_TICS_Rita 发表于 2014-5-30 13:01 | 显示全部楼层
你重新创建一个贴好了,要把问题描述清楚哈~~
yy11219809374 发表于 2014-8-6 16:05 | 显示全部楼层
SD卡启动开发板
   然后root进入
   再然后,通过命令:gst-­launch  mfw_v4lsrc ! mfw_v4lsink   要显示 ...
你的问题解决了吗,我也遇到和你一样的问题,求解
