帮我看下程序为什么会死在这。
5339|7
伊泽瑞拉|  楼主 | 2014-5-20 09:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
rc, se, ui, ST, PLL
static void SetSysClockTo72(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  /*!< SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /*!< Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /*!< Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0) && (StartUpCounter != HSEStartUp_TimeOut));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /*!< Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /*!< Flash 2 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /*!< HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /*!< PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /*!< PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
    /*!< PLLCLK = 8MHz * 9 = 72 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL9);
    /*!< Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /*!< Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /*!< Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /*!< Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /*!< If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
    /*!< Go to infinite loop */
    while (1)
#endif
程序卡在最后一个while里面了    这是因为什么原因
伊泽瑞拉|  楼主 | 2014-5-20 14:25 | 只看该作者
虽然不是这个原因  但还是谢谢你
伊泽瑞拉|  楼主 | 2014-5-20 14:28 | 只看该作者
我想问一下 你知道MPU6050 读出来的加速度    怎么转换成和重力加速度对应的数据吗?
伊泽瑞拉|  楼主 | 2014-5-21 09:12 | 只看该作者
yyy71cj 发表于 2014-5-20 17:08
这个MPU6050的资料里应该有吧,应该不是什么难事
int main(void)
  I2C_Config();
  InitMPU6050();
   while(1)
    data_x=getdate(ACCEL_XOUT_H)/16384.0;
    data_y=((getdate(ACCEL_YOUT_H)/16384.0)*9.8);
    data_z=getdate(ACCEL_ZOUT_H)/16384.0;
                data_xl=getdate(GYRO_XOUT_H);
    data_yl=getdate(GYRO_YOUT_H);
    data_zl=getdate(GYRO_ZOUT_H);
                JK_FLAG++;
加粗的这两个值   变化幅度太大     是什么情况
伊泽瑞拉|  楼主 | 2014-5-21 16:06 | 只看该作者
yyy71cj 发表于 2014-5-21 11:49
这两个值来历不明,从软件上看是不是读出的原始值?如果是,则有可能是灵敏度很高,加速度变化在这两个方 ...
程序就这个
读出来的值不正常    不知道哪出问题了
I2C.rar
863.18 KB
LOVE_ELEC| | 2014-9-28 11:40 | 只看该作者
请问你这个卡死在最后一条语句是由什么引起的?
2342341234| | 2016-11-4 15:44 | 只看该作者
我也卡在哪里了,唉!有时候好,有时候坏。。。
