[嵌入式linux] 求助U-boot移植时候make时出现的错误
1210|4
 楼主| cyp0921 发表于 2014-5-25 16:56 | 显示全部楼层 |阅读模式
dirname: 参数太少
请尝试执行‘dirname --help’来获取更多信息。
Generating include/autoconf.mk
/bin/sh: line 1: arm-linux-gcc: command not found
Generating include/autoconf.mk.dep
make: *** [include/autoconf.mk.dep] Error 127
 楼主| cyp0921 发表于 2014-5-25 16:57 | 显示全部楼层
求大神帮我解决下。
 楼主| cyp0921 发表于 2014-5-25 18:22 | 显示全部楼层
[root@localhost root]# ls
anaconda-ks.cfg  install.log.syslog  u-boot-2013.01
evolution        minicom.log         u-boot-2013.01.tar.bz2
install.log      pax_global_header   vmware-tools-distrib
[root@localhost root]# cd u-boot-2013.01
[root@localhost u-boot-2013.01]# ls
api         config.mk  drivers    include      mkconfig  rules.mk
arch        COPYING    dts        lib          nand_spl  snapshot.commit
board       CREDITS    examples   MAINTAINERS  net       spl
boards.cfg  disk       fs         MAKEALL      post      test
common      doc        helper.mk  Makefile     README    tools
[root@localhost u-boot-2013.01]# make smdk2410_config
Configuring for smdk2410 board...
make: arm-linux-gcc: Command not found
nerated/cc_options.mk; echo "-malignment-traps"; fi/bin/sh: line 1: arm-linux-gcc: command not found
dirname: 参数太少
