请教下USB鼠标x,y数据格式。
2139|1
 楼主| lhchen922 发表于 2014-5-27 14:35 | 显示全部楼层 |阅读模式
通常的USB鼠标数据格式如下,
第一BYTE表示鼠标左键,右键,中键的单击,第4BYTE 表示滑轮滚动,中间2BYTE代表x,y的值,
但是发现有些USB鼠标却是:第一BYTE表示鼠标左键,右键,中键的单击,第5 BYTE 表示滑轮滚动
中间有3BYTE数据,我的问题是这3byte数据是怎么来表示X,y的,还有报告描述符要怎么写,谢谢。
如下是后者的数据
Bus Hound 6.01 capture on Windows Vista Service Pack 1 (x64). Complements of www.perisoft.net
dell
  Device - Device ID (followed by the endpoint for USB devices)
            (18) USB 输入设备
            (21) HID-compliant mouse
  Phase  - Phase Type
            IN    Data in transfer
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Phase  Data                                                Description       Cmd.Phase.Ofs(rep)
  18.1  IN     00 fb 0f 00  00 00                                  ......                   1.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                 2.1.0
  18.1  IN     00 f4 ef ff  00 00                                  ......                   3.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                 4.1.0
  18.1  IN     00 ed ff ff  00 00                                  ......                   5.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                 6.1.0(2)
  18.1  IN     00 e7 0f 00  00 00                                  ......                   7.1.0(2)
  21    IN     03 00 00 00  00 00 00 00                            ........                10.1.0
  18.1  IN     00 e7 1f 00  00 00                                  ......                  11.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                12.1.0
  18.1  IN     00 e9 2f 00  00 00                                  ../...                  13.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                14.1.0
  18.1  IN     00 eb 1f 00  00 00                                  ......                  15.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                16.1.0
  18.1  IN     00 ee 2f 00  00 00                                  ../...                  17.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                18.1.0
  18.1  IN     00 f2 2f 00  00 00                                  ../...                  19.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                20.1.0
  18.1  IN     00 f5 3f 00  00 00                                  ..?...                  21.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                22.1.0
  18.1  IN     00 06 e0 ff  00 00                                  ......                  23.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                24.1.0
  18.1  IN     00 15 60 ff  00 00                                  ..`...                  25.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                26.1.0
  18.1  IN     00 28 80 ff  00 00                                  .(....                  27.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                28.1.0
  18.1  IN     00 33 d0 ff  00 00                                  .3....                  29.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                30.1.0
  18.1  IN     00 35 50 00  00 00                                  .5P...                  31.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                32.1.0
  18.1  IN     00 2b a0 00  00 00                                  .+....                  33.1.0
  21    IN     03 00 00 00  00 00 00 00                            ........                34.1.0
匿名  发表于 2014-6-8 22:43
meiyou
个人签名:<a href="=http://ip.WoTuLa.com" target="_blank"><img src="http://id.WoTuLa.com/1/?name=心有所向&style=2&font=6" /></a>
18
