[FPGA] [求助]关于nios2
1552|3
 楼主| nm2012 发表于 2014-5-28 16:31 | 显示全部楼层 |阅读模式
综合出来怎么才用了323个逻辑单元,fast型,然后后面试验全是错的,同学综合出来都是几千的单元,可我每一步也是按书上做的啊,有没有人碰过这种问题啊,求问求指点,谢谢了
 楼主| nm2012 发表于 2014-5-28 16:34 | 显示全部楼层
300多个waring,正常吗,请问
 楼主| nm2012 发表于 2014-5-28 16:35 | 显示全部楼层
Warning (15400): WYSIWYG primitive "mycpu:inst|CPU:the_CPU|CPU_nios2_oci:the_CPU_nios2_oci|CPU_nios2_oci_im:the_CPU_nios2_oci_im|CPU_traceram_lpm_dram_bdp_component_module:CPU_traceram_lpm_dram_bdp_component|altsyncram:the_altsyncram|altsyncram_e502:auto_generated|ram_block1a30" has a port clk0 that is stuck at GND
就是这个warning
 楼主| nm2012 发表于 2014-5-28 16:42 | 显示全部楼层
Warning (15400): WYSIWYG primitive "mycpu:inst|JTAG_UART:the_JTAG_UART|JTAG_UART_scfifo_w:the_JTAG_UART_scfifo_w|scfifo:wfifo|scfifo_1n21:auto_generated|a_dpfifo_8t21:dpfifo|dpram_5h21:FIFOram|altsyncram_9tl1:altsyncram2|ram_block3a2" has a port clk0 that is stuck at GND
