KeyStone 的DDR3设计要求
1231|4
 楼主| elecintop 发表于 2014-5-30 14:24 | 显示全部楼层 |阅读模式
KeyStone 的DDR3设计要求
This document provides implementationinstructions for the DDR3 interface incorporated in the Texas Instruments (TI)Keystone series of DSP devices. It supports 1333 MT/s and higher memory speedsin a variety of topologies (see to the Data Manual for supported speeds). Thisdocument assumes the user has a familiarization with DRAM implementationconcepts and constraints. When searching for a particular configuration see theappendix, which will alleviate the need for searching the entire document whichcontains all possible variations.
zhangmangui 发表于 2014-5-30 14:55 | 显示全部楼层
欢迎分享
muzi820305 发表于 2014-10-23 14:13 | 显示全部楼层
谢谢分享
long009 发表于 2014-11-30 13:43 | 显示全部楼层
:handshake
