ccs5.5中程序编译后问题
1297|4
 楼主| u880 发表于 2014-5-30 19:52 | 显示全部楼层 |阅读模式
"C:/Users/xiaotusheng/workspace_v5_5/controlSUITE/device_support/f2802x/v210/f2802x_examples/epwm_up_aq/../../F2802x_common/cmd/F2802x_generic_ram.cmd", line 111: error:
   program will not fit into available memory.  placement with
>> Compilation failure
   alignment/blocking fails for section ".text" size 0x7da page 0.  Available
   memory ranges:
   RAMM0        size: 0x3b0        unused: 0x1          max hole: 0x1
   RAML0        size: 0x400        unused: 0x0          max hole: 0x0
   .text            : >> RAMM0 | RAML0,      PAGE = 0
"C:/Users/xiaotusheng/workspace_v5_5/controlSUITE/device_support/f2802x/v210/f2802x_examples/epwm_up_aq/../../F2802x_common/cmd/F2802x_generic_ram.cmd", line 112: error:
   alignment/blocking fails for section ".cinit" size 0x16 page 0.  Available
   memory ranges:
   .cinit           : >  RAMM0 | RAML0,      PAGE = 0
"C:/Users/xiaotusheng/workspace_v5_5/controlSUITE/device_support/f2802x/v210/f2802x_examples/epwm_up_aq/../../F2802x_common/cmd/F2802x_generic_ram.cmd", line 110: error:
   alignment/blocking fails for section "ramfuncs" size 0x4 page 0.  Available
   memory ranges:
   ramfuncs         : >> RAMM0 | RAML0,      PAGE = 0
warning: entry-point symbol other than "_c_int00" specified:  "code_start"
error: errors encountered during linking; "Example_F2802xEPwmUpAQ.out" not
   built
跪求大神帮忙
编译后出现program will not fit into available memory
jxmzzr 发表于 2014-6-3 15:58 | 显示全部楼层
cmd文件配置有问题。你看看MAP文件,在修改CMD
zhangmangui 发表于 2014-6-3 21:32 | 显示全部楼层
cmd加错了吧
拿起书本 发表于 2014-6-4 16:15 | 显示全部楼层
Debug还是已经下载到Flash里了?
