编译时出现错误,求解答
1249|3
 楼主| G21372 发表于 2014-5-30 21:09 | 显示全部楼层 |阅读模式
1.
Description Resource Path Location Type
<a href="file:/D:/ti/ccsv5/tools/compiler/dmed/HTML/10099.html">#10099-D</a> program will not fit into available memory. placement with alignment/blocking fails for section ".cinit" size 0x81 page 0. Available memory ranges: PinWork C/C++ Problem
 楼主| G21372 发表于 2014-5-30 21:10 | 显示全部楼层
2.
unresolved symbol _I2C_enableSlave, first referenced in ./scr/i2c.obj PinWork C/C++ Problem
huangfeng33 发表于 2014-6-3 10:56 | 显示全部楼层
1:、存储器分配有问题
2: _I2C_enableSlave没有定义
拿起书本 发表于 2014-6-4 10:16 | 显示全部楼层
楼主检查下你的输入法有没有什么问题呢?!
