CAN通信问题
1315|4
 楼主| gexingyouxian 发表于 2014-5-30 23:41 | 显示全部楼层 |阅读模式
测试2812片子CAN通信时,用的是从TI网站下的ECAN通信源代码,但无论如何CAN通信都调试不通,查看寄存器的时候是TA无法置1,请教各位老师、前辈能否告诉我原因,谢谢!
 楼主| gexingyouxian 发表于 2014-5-30 23:42 | 显示全部楼层
#include \"DSP28_Device.h\"
#define TXCOUNT  10000  // Transmission will take place (TXCOUNT) times..
long      i;
long           loopcount = 0;
void InitECan(void);
main()
/* Create a shadow register structure for the CAN control registers. This is
needed, since, only 32-bit access is allowed to these registers. 16-bit access
to these registers could potentially corrupt the register contents. This is
especially true while writing to a bit (or group of bits) among bits 16 - 31 */
struct ECAN_REGS ECanaShadow;
/* Initialize the CAN module */
        InitECan();
/* Write to the MSGID field  */
    ECanaMboxes.MBOX5.MSGID.all = 0x9FFFFFFF; // Extended Identifier
/* Configure Mailbox under test as a Transmit mailbox */
        ECanaShadow.CANMD.all = ECanaRegs.CANMD.all;
        ECanaShadow.CANMD.bit.MD5 = 0;
        ECanaRegs.CANMD.all = ECanaShadow.CANMD.all;
/* Enable Mailbox under test */
        ECanaShadow.CANME.all = ECanaRegs.CANME.all;
        ECanaShadow.CANME.bit.ME5 = 1;
        ECanaRegs.CANME.all = ECanaShadow.CANME.all;
/* Write to DLC field in Master Control reg */
        ECanaMboxes.MBOX5.MCF.bit.DLC = 8;
/* Write to the mailbox RAM field */
     ECanaMboxes.MBOX5.MDRL.all = 0x01234567;
         ECanaMboxes.MBOX5.MDRH.all = 0x89ABCDEF;
/* Begin transmitting */
    // while(1)                                                         // Uncomment this line for infinite transmissions
    for(i=0; i < TXCOUNT; i++)                                // Uncomment this line for finite transmissions
     ECanaShadow.CANTRS.all = 0;
     ECanaShadow.CANTRS.bit.TRS5 = 1;     // Set TRS for mailbox under test
     ECanaRegs.CANTRS.all = ECanaShadow.CANTRS.all;
     while(ECanaRegs.CANTA.bit.TA5 == 0 ) {}  // Wait for TA5 bit to be set..
//***问题就出在这里,TA5无法置1所以CAN通信怎么也不通*****************
     ECanaShadow.CANTA.all = 0;
     ECanaShadow.CANTA.bit.TA5 = 1;              // Clear TA5
     ECanaRegs.CANTA.all = ECanaShadow.CANTA.all;
     loopcount ++;
恳请各位指教,多谢了啊!!!!!!!
拿起书本 发表于 2014-6-3 10:32 | 显示全部楼层
总线上要有对应的接收节点才能够发送成功,不能像232那样调试Can。
jxmzzr 发表于 2014-6-3 16:46 | 显示全部楼层
这个必须两个板子连接起来才能调试的啊!
zhangmangui 发表于 2014-6-3 21:32 | 显示全部楼层
can比较麻烦   多找些资料看看吧
