请问这样初始化EPWM模块3,输出的EPWM3A和EPWM3B的波形是怎样的?
1140|3
 楼主| gexingyouxian 发表于 2014-5-30 23:43 | 显示全部楼层 |阅读模式
EPwm3Regs.TBPRD = 1000;                        // 20kHz
        EPwm3Regs.TBPHS.half.TBPHS = 0x0000;               // Phase is 0
        EPwm3Regs.TBCTR = 0x0000;                               // Clear counter
        EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
        EPwm3Regs.TBCTL.bit.PHSEN = TB_DISABLE;         // Disable phase loading
        EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;        // Clock ratio to SYSCLKOUT
        EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1;              // Slow just to observe on the scope
//        EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_PRD;
        EPwm3Regs.CMPA.half.CMPA =1050;//80;                                  // Setup compare
        EPwm3Regs.CMPB = 1000;
                EPwm3Regs.AQCTLA.all = 0x0218; // Force PWM1A to Low
        EPwm3Regs.AQCTLB.all = 0x0018; // counter equal PRD,Force PWM3B output High
求助大家了
huangfeng33 发表于 2014-6-3 10:48 | 显示全部楼层
楼主可以直接用示波器描一下啊?!
拿起书本 发表于 2014-6-4 10:18 | 显示全部楼层
不知道楼主所遇到的问题到底是什么,直接用示波器描一下啊!
