[51单片机] 小弟单片机新手,想弱弱的问几个关于DS18B20的几个问题
2852|7
 楼主| ygdmx 发表于 2014-6-2 11:58 | 显示全部楼层 |阅读模式
先附上我买的学习板子配过来的DS18B20的程序
/*************************此部分为18B20的驱动程序*************************************/
#include <reg52.H>
#include <intrins.h>
sbit    D18B20=P3^7;
#define  NOP()   _nop_()   /* 定义空指令 */
#define  _Nop()  _nop_()   /*定义空指令*/
void TempDelay (unsigned char idata us);
void Init18b20 (void);
void WriteByte (unsigned char idata wr);  //单字节写入
void read_bytes (unsigned char idata j);
unsigned char CRC (unsigned char j);
void GemTemp (void);
void Config18b20 (void);
void ReadID (void);
void TemperatuerResult(void);
bit  flag;
unsigned int  idata Temperature;
unsigned char idata temp_buff[9]; //存储读取的字节,read scratchpad为9字节,read rom ID为8字节
unsigned char idata id_buff[8];
unsigned char idata *p,TIM;
unsigned char idata crc_data;
unsigned char code CrcTable [256]={
0,  94, 188,  226,  97,  63,  221,  131,  194,  156,  126,  32,  163,  253,  31,  65,
157,  195,  33,  127,  252,  162,  64,  30,  95,  1,  227,  189,  62,  96,  130,  220,
35,  125,  159,  193,  66,  28,  254,  160,  225,  191,  93,  3,  128,  222,  60,  98,
190,  224,  2,  92,  223,  129,  99,  61,  124,  34,  192,  158,  29,  67,  161,  255,
70,  24,  250,  164,  39,  121,  155,  197,  132,  218,  56,  102,  229,  187,  89,  7,
219,  133, 103,  57,  186,  228,  6,  88,  25,  71,  165,  251,  120,  38,  196,  154,
101,  59, 217,  135,  4,  90,  184,  230,  167,  249,  27,  69,  198,  152,  122,  36,
248,  166, 68,  26,  153,  199,  37,  123,  58,  100,  134,  216,  91,  5,  231,  185,
140,  210, 48,  110,  237,  179,  81,  15,  78,  16,  242,  172,  47,  113,  147,  205,
17,  79,  173,  243,  112,  46,  204,  146,  211,  141,  111,  49,  178,  236,  14,  80,
175,  241, 19,  77,  206,  144,  114,  44,  109,  51,  209,  143,  12,  82,  176,  238,
50,  108,  142,  208,  83,  13,  239,  177,  240,  174,  76,  18,  145,  207,  45,  115,
202,  148, 118,  40,  171,  245,  23,  73,  8,  86,  180,  234,  105,  55,  213, 139,
87,  9,  235,  181,  54,  104,  138,  212,  149,  203,  41,  119,  244,  170,  72,  22,
233,  183,  85,  11,  136,  214,  52,  106,  43,  117,  151,  201,  74,  20,  246,  168,
116,  42,  200,  150,  21,  75,  169,  247,  182,  232,  10,  84,  215,  137,  107,  53};
*Function:延时处理
*parameter:
*Return:
*Modify:
        while(us--);
*Function:18B20初始化
*parameter:
*Return:
*Modify:
        D18B20=1;
        _nop_();
        D18B20=0;
        TempDelay(80);   //delay 530 uS//80
        _nop_();
        D18B20=1;
        TempDelay(14);   //delay 100 uS//14
        _nop_();
        _nop_();
        _nop_();
        if(D18B20==0)
                flag = 1;   //detect 1820 success!
        else
                flag = 0;    //detect 1820 fail!
        TempDelay(20);       //20
        _nop_();
        _nop_();
        D18B20 = 1;
*Function:向18B20写入一个字节
*parameter:
*Return:
*Modify:
void WriteByte (unsigned char idata wr)  //单字节写入
        unsigned char idata i;
        for (i=0;i<8;i++)
                D18B20 = 0;
                _nop_();
                D18B20=wr&0x01;
                TempDelay(3);   //delay 45 uS //5
                _nop_();
                _nop_();
                D18B20=1;
                wr >>= 1;
*Function:读18B20的一个字节
*parameter:
*Return:
*Modify:
unsigned char ReadByte (void)     //读取单字节
        unsigned char idata i,u=0;
        for(i=0;i<8;i++)
                D18B20 = 0;
                u >>= 1;
                D18B20 = 1;
                if(D18B20==1)
                u |= 0x80;
                TempDelay (2);
                _nop_();
        return(u);
*Function:读18B20
*parameter:
*Return:
*Modify:
         for(i=0;i<j;i++)
                  *p = ReadByte();
                  p++;
*Function:CRC校验
*parameter:
*Return:
*Modify:
           unsigned char idata i,crc_data=0;
          for(i=0;i<j;i++)  //查表校验
            crc_data = CrcTable[crc_data^temp_buff]; 这里的temp_buff[]在程序里没看到有把通信的数据赋值给它,temp_buff[]不是应该是空的吗??
    return (crc_data);
*Function:读取温度
*parameter:
*Return:
*Modify:
void GemTemp (void)
   read_bytes (9);
   if (CRC(9)==0) //校验正确
            Temperature = temp_buff[1]*0x100 + temp_buff[0];
//            Temperature *= 0.625;
                Temperature /= 16;
                TempDelay(1);
*Function:内部配置
*parameter:
*Return:
*Modify:
void Config18b20 (void)  //重新配置报警限定值和分辨率
     Init18b20();
     WriteByte(0xcc);  //skip rom
     WriteByte(0x4e);  //write scratchpad
     WriteByte(0x19);  //上限
     WriteByte(0x1a);  //下限
     WriteByte(0x7f);     //set 11 bit (0.125)
     Init18b20();  在DS18B20资料里说,每次对18D20进行读写操作都要对18B20初始化,这里不是做了很多次写的操作了吗,为什么只初始化了3次??
     WriteByte(0x48);  //保存设定值
     Init18b20();
     WriteByte(0xb8);  //回调设定值
*Function:读18B20ID
*parameter:
*Return:
*Modify:
void ReadID (void)//读取器件 id
        Init18b20();
        WriteByte(0x33);  //read rom
        read_bytes(8);
*Function:18B20ID全处理
*parameter:
*Return:
*Modify:
p = id_buff 这里P=id_buff和下面的p=temp_buff; 我的理解是把id_buff  temp_buff的地址赋值给指针变量P,但是把地址赋值给P是干嘛用的??
          ReadID();
          Config18b20();
        Init18b20 ();
        WriteByte(0x44);   //Temperature convert
        Init18b20 ();
        WriteByte(0xbe);   //read Temperature
        p = temp_buff;
        GemTemp(); //校检
void GetTemp()
     if(TIM==100) //每隔 1000ms 读取温度
        {  TIM=0;
           TemperatuerResult();
[ t1 (10ms)中断] 中断
void T1zd(void) interrupt 3
   TH1 = 0xD8;    //10
   TL1 = 0xF0;
   TIM++;
纠结这些问题纠结了好久了,希望懂的朋友们可以指点指点,谢谢!!!
ningling_21 发表于 2014-6-2 17:10 | 显示全部楼层
这个程序太麻烦了,我有个简单的...
 楼主| ygdmx 发表于 2014-6-2 17:28 | 显示全部楼层
这个程序太麻烦了,我有个简单的...
我自己也写了一部分不带CRC校验的程序,后来看了一下上面那个瞬间觉得头好晕:Q
 楼主| ygdmx 发表于 2014-6-2 17:31 | 显示全部楼层
这个程序太麻烦了,我有个简单的...
我也写了一部分不带CRC的18B20驱动程序,后来看了上面那个,瞬间觉得头好晕:Q
ningling_21 发表于 2014-6-3 14:40 | 显示全部楼层
  1. void ReadTemperature(void )
  4.         uchar uc_temp;
  5.         if(ds18b20_stat==0)
  6.         {
  7.                  DS18B20_Reset();                //设备复位
  8.             DS18B20_WriteByte(0xCC);        //跳过ROM命令
  9.             DS18B20_WriteByte(0x44);        //开始转换命令
  10.                 ds18b20_stat=1;
  11.         }
  12.         else if(ds18b20_stat==1)
  13.         {
  14.                  if(DQ==0)
  15.                 {
  16.                          ds18b20_dly++;
  17.                 }
  18.                 else
  19.                 {
  20.                          ds18b20_stat=2;
  21.                         ds18b20_dly=0;
  22.                 }
  23.         }
  24.         else if(ds18b20_stat==2)
  25.         {
  26.             DS18B20_Reset();                //设备复位
  27.             DS18B20_WriteByte(0xCC);        //跳过ROM命令
  28.             DS18B20_WriteByte(0xBE);        //读暂存存储器命令
  29.
  30.             LSB_back = DS18B20_ReadByte();       //读温度低字节
  31.             MSB_back = DS18B20_ReadByte();       //读温度高字节
  32.                 MSB = MSB_back;
  33.                 LSB = LSB_back;
  34.         }
  35. }
 楼主| ygdmx 发表于 2014-6-3 17:37 | 显示全部楼层
谢谢,ds18b20=2是什么意思啊
ningling_21 发表于 2014-6-3 17:46 | 显示全部楼层
谢谢,ds18b20=2是什么意思啊
代表一个状态,此状态可以读取温度值...
whw8099 发表于 2014-6-3 19:44 | 显示全部楼层
有经典的直接用就行了。
