调试MIG出现的错误:PLACE:886,烦请大家指点
1722|0
sz_ehome|  楼主 | 2014-6-4 17:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
调试MIG的时候,MAP过程出现如下错误:ERRORPlace:866 - Not enough valid sites to place the following IOBs:
   IO Standard: Name = LVCMOS25, VREF = NR, VCCO = 2.50, TERM = NONE, DIR = BIDIR, DRIVE_STR = 12
IO
IO_x
ERRORlace:382 - The placer was unable to find a feasible solution for the IOBs in your design. This is possibly due to
   SelectIO banking constraints.
ERRORlace:418 - Failed to execute IOB Placement
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
我的UCF文件如下:
##  File name :       main.ucf
##  Details :     Constraints file
##                    FPGA family:       spartan6
##                    FPGA:              xc6slx16-ftg256
##                    Speedgrade:        -2
##                    Design Entry:      VERILOG
##                    Design:            with Test bench
##                    DCM Used:          Enable
##                    No.Of Memory Controllers: 1
# VCC AUX VOLTAGE
CONFIG VCCAUX=2.5; # Valid values are 2.5 and 3.3
CONFIG MCB_PERFORMANCE= STANDARD;
## Clock constraints
NET "clk" TNM_NET = SYS_CLK;
TIMESPEC TS_SYS_CLK = PERIOD SYS_CLK3  50000 kHz;
NET  "clk"
   IOSTANDARD = "LVCMOS33" ;
NET  "rst"
   IOSTANDARD = "LVCMOS18" ;
NET  "clk"
   LOC = "T7" ;
NET  "rst"
   LOC = "F5" ;
## I/O TERMINATION
NET "mcb3_dram_dq
"                                 IN_TERM = NONE;
NET "mcb3_dram_dqs"                                   IN_TERM = NONE;
NET "mcb3_dram_dqs_n"                                 IN_TERM = NONE;
NET "mcb3_dram_udqs"                                  IN_TERM = NONE;
NET "mcb3_dram_udqs_n"                                IN_TERM = NONE;
# Status Signals
NET  "calib_done"
NET  "calib_done"
LOC = "A5" ;
# I/O STANDARDS
NET  "mcb3_dram_dq
"                               IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_a
NET  "mcb3_dram_ba
NET  "mcb3_dram_dqs"                                 IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_udqs"                                IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_dqs_n"                               IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_udqs_n"                              IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_ck"                                  IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_ck_n"                                IOSTANDARD = DIFF_SSTL18_II ;
NET  "mcb3_dram_cke"                                 IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_ras_n"                               IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_cas_n"                               IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_we_n"                                IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_odt"                                 IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_dm"                                  IOSTANDARD = SSTL18_II ;
NET  "mcb3_dram_udm"                                 IOSTANDARD = SSTL18_II ;
NET  "mcb3_rzq"                                      IOSTANDARD = SSTL18_II ;
NET  "mcb3_zio"                                      IOSTANDARD = SSTL18_II ;
# MCB 3
NET  "mcb3_dram_a[0]"                            LOC = "K5" ;
NET  "mcb3_dram_a[1]"                            LOC = "K6" ;
NET  "mcb3_dram_a[2]"                            LOC = "D1" ;
NET  "mcb3_dram_a[3]"                            LOC = "L4" ;
NET  "mcb3_dram_a[4]"                            LOC = "G5" ;
NET  "mcb3_dram_a[5]"                            LOC = "H4" ;
NET  "mcb3_dram_a[6]"                            LOC = "H3" ;
NET  "mcb3_dram_a[7]"                            LOC = "D3" ;
NET  "mcb3_dram_a[8]"                            LOC = "B2" ;
NET  "mcb3_dram_a[9]"                            LOC = "A2" ;
NET  "mcb3_dram_a[10]"                           LOC = "G6" ;
NET  "mcb3_dram_a[11]"                           LOC = "E3" ;
NET  "mcb3_dram_a[12]"                           LOC = "F3" ;
NET  "mcb3_dram_ba[0]"                           LOC = "C3" ;
NET  "mcb3_dram_ba[1]"                           LOC = "C2" ;
NET  "mcb3_dram_ba[2]"                           LOC = "B1" ;
NET  "mcb3_dram_cas_n"                           LOC = "H5" ;
NET  "mcb3_dram_ck"                              LOC = "E2" ;
NET  "mcb3_dram_ck_n"                            LOC = "E1" ;
NET  "mcb3_dram_cke"                             LOC = "F4" ;
NET  "mcb3_dram_dm"                              LOC = "J4" ;
NET  "mcb3_dram_dq[0]"                           LOC = "K2" ;
NET  "mcb3_dram_dq[1]"                           LOC = "K1" ;
NET  "mcb3_dram_dq[2]"                           LOC = "J3" ;
NET  "mcb3_dram_dq[3]"                           LOC = "J1" ;
NET  "mcb3_dram_dq[4]"                           LOC = "F2" ;
NET  "mcb3_dram_dq[5]"                           LOC = "F1" ;
NET  "mcb3_dram_dq[6]"                           LOC = "G3" ;
NET  "mcb3_dram_dq[7]"                           LOC = "G1" ;
NET  "mcb3_dram_dq[8]"                           LOC = "L3" ;
NET  "mcb3_dram_dq[9]"                           LOC = "L1" ;
NET  "mcb3_dram_dq[10]"                          LOC = "M2" ;
NET  "mcb3_dram_dq[11]"                          LOC = "M1" ;
NET  "mcb3_dram_dq[12]"                          LOC = "2" ;
NET  "mcb3_dram_dq[13]"                          LOC = "1" ;
NET  "mcb3_dram_dq[14]"                          LOC = "R2" ;
NET  "mcb3_dram_dq[15]"                          LOC = "R1" ;
NET  "mcb3_dram_dqs"                             LOC = "H2" ;
NET  "mcb3_dram_dqs_n"                           LOC = "H1" ;
NET  "mcb3_dram_odt"                             LOC = "L5" ;
NET  "mcb3_dram_ras_n"                           LOC = "J6" ;
NET  "mcb3_dram_udm"                             LOC = "K3" ;
NET  "mcb3_dram_udqs"                            LOC = "N3" ;
NET  "mcb3_dram_udqs_n"                          LOC = "N1" ;
NET  "mcb3_dram_we_n"                            LOC = "C1" ;
NET  "mcb3_rzq"                                       LOC ="M4";
NET  "mcb3_zio"                                       LOC = "M5" ;
这个错误是什么问题,应该如何解决?!
