28335CAN接收为什么进不了中断?
6574|6
 楼主| caowei0516 发表于 2014-6-10 10:39 | 显示全部楼层 |阅读模式
#include "DSP2833x_Device.h"     // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
  interrupt void ECAN0INTB_ISR(void);
  Uint32 Rec_l0;
  Uint32 Rec_h0;
void main(void)
   struct ECAN_REGS ECanbShadow;
   InitSysCtrl();
   InitECanGpio();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
    EALLOW;
    PieVectTable.ECAN0INTB = &ECAN0INTB_ISR;       // TIMER0断向重定位
    EDIS;
    EALLOW;
    ECanbShadow.CANTIOC.all = ECanbRegs.CANTIOC.all;
    ECanbShadow.CANTIOC.bit.TXFUNC = 1;
    ECanbRegs.CANTIOC.all = ECanbShadow.CANTIOC.all;
    ECanbShadow.CANRIOC.all = ECanbRegs.CANRIOC.all;
    ECanbShadow.CANRIOC.bit.RXFUNC = 1;
    ECanbRegs.CANRIOC.all = ECanbShadow.CANRIOC.all;
    EDIS;
    ECanbRegs.CANME.all = 0;
    ECanbMboxes.MBOX16.MSGID.all = 0x9555AAA0;
    ECanbRegs.CANMD.all = 0xFFFF0000;
    ECanbRegs.CANME.all = 0xFFFFFFFF;
    ECanbMboxes.MBOX16.MSGCTRL.bit.DLC = 8;
    ECanbMboxes.MBOX16.MSGCTRL.bit.RTR = 0;
    EALLOW;
    ECanbRegs.CANMIM.all = 0xFFFFFFFF;
    ECanbShadow.CANMC.all = ECanbRegs.CANMC.all;
    ECanbShadow.CANMC.bit.CCR = 1;
    ECanbRegs.CANMC.all = ECanbShadow.CANMC.all;
    EDIS;
    do
      ECanbShadow.CANES.all = ECanbRegs.CANES.all;
    } while(ECanbShadow.CANES.bit.CCE != 1 );
    EALLOW;
    ECanbShadow.CANBTC.all = ECanbRegs.CANBTC.all;
    ECanbShadow.CANBTC.bit.BRPREG = 9;    // (BRPREG + 1) = 10 feeds a 15 MHz CAN clock
    ECanbShadow.CANBTC.bit.TSEG2REG = 5 ; // to the CAN module. (150 / 10 = 15)
    ECanbShadow.CANBTC.bit.TSEG1REG = 7;  // Bit time = 15
    ECanbRegs.CANBTC.all = ECanbShadow.CANBTC.all;
    ECanbShadow.CANMC.bit.CCR = 0;
    EDIS;
    do
    } while(ECanbShadow.CANES.bit.CCE != 0 );
    EALLOW;
    ECanbShadow.CANMC.bit.STM = 0;    // Configure CAN for self-test mode
    ECanbShadow.CANMC.bit.SCB = 1;    // eCAN mode (reqd to access 32 mailboxes)
    EDIS;
    EALLOW;
    ECanaRegs.CANMIM.all = 0xFFFFFFFF;     //邮箱中断屏蔽位
    ECanaRegs.CANMIL.all = 0;            //邮箱中断将产生在ECAN0INT
    ECanaRegs.CANGIF0.all = 0xFFFFFFFF;  //全局中断标志寄存器
    ECanaRegs.CANGIM.bit.I0EN = 1;   //ECAN0INT中断请求线被使能
    EDIS;
    PieCtrlRegs.PIEIER9.bit.INTx7 = 1;   //使能PIE中断
    IER |= M_INT9;                       //使能CPU中断
    EINT;
    ERTM;
    for(;;)
// Begin receiving
interrupt void ECAN0INTB_ISR(void)  // eCAN-B
   while(ECanbRegs.CANRMP.all != 0x00010000 ) {}  // Wait for all TAn bits to be set..
       ECanbRegs.CANRMP.all = 0x00010000;   // Clear all TAn
       Rec_l0 =  ECanbMboxes.MBOX16.MDL.all;
       Rec_h0 =  ECanbMboxes.MBOX16.MDH.all;
       PieCtrlRegs.PIEACK.bit.ACK9 = 1;
       ECanbRegs.CANOPC.all = 0;
       EINT;
各位大神,能帮我看看这个接收为什么进入不了中断吗?
zhangmangui 发表于 2014-6-10 13:31 来自手机 | 显示全部楼层
tianli1980 发表于 2014-6-12 10:25 | 显示全部楼层
SCI必须是符合中断要求才会进入中断,SCI要接收满16个数据才会进入中断。
大秦正声 发表于 2014-6-12 14:08 | 显示全部楼层
f2812
PieCtrlRegs.PIEIER9.bit.INTx5 = 1;
52kfb 发表于 2014-6-13 10:00 | 显示全部楼层
CAN初始化少了一句,,  我去看看我的代码
 楼主| caowei0516 发表于 2014-6-19 16:46 | 显示全部楼层
在CANH和CANL之间并上一个电阻,问题已经解决。
huhulai 发表于 2016-9-4 16:22 | 显示全部楼层
楼主你好,我现在也出现了这个问题,请问你是怎么解决的。我的dsp开发板上,canh与canl已经并联了电阻了。
