[i.MX] imx6q mfgtool能用于下载自己做的bootrom(已解决)
3524|8
 楼主| fanxl617 发表于 2014-6-11 16:43 | 显示全部楼层 |阅读模式
mfgtool使用必须编写linux环境下的东西吗?
如果烧写商业os自己的bootrom怎么弄,比如vxworks他们好像就有自己独立的系统做boot
FSL_TICS_Rita 发表于 2014-6-11 17:25 | 显示全部楼层
mfgtool烧写的原理就是使用linux中的命令将images写到flash中的。
 楼主| fanxl617 发表于 2014-6-20 14:46 | 显示全部楼层
如果对于少些linux内核,在linux被少些进去之前,怎么用linux命令去烧image呢。
我现在是想烧vxworks,在workbench下不是可以生成bootrom和vxworks image吗?怎么用mfgtool少些进去。
还有ucl指导烧录,应该以怎么样的顺序知道烧录呢?
FSL_TICS_Rita 发表于 2014-6-20 15:14 | 显示全部楼层
我现在是想烧vxworks,在 ...
你可以查看一下ucl2.xml中的内容,另外你可以参考一下之前我发的帖子https://bbs.21ic.com/icview-702516-1-1.html。希望对你的理解有帮助。
sundhhy 发表于 2015-1-25 15:23 | 显示全部楼层
楼主你好,我也遇到类似的问题,能告诉你你是怎么解决的吗?谢谢
Leilayan 发表于 2015-12-3 10:58 | 显示全部楼层
同问,我是新手,之前是linux系统,想要烧录vxworks怎么弄
Leilayan 发表于 2015-12-3 10:59 | 显示全部楼层
MFGtool可以用于vxworks的烧录吗
mini1986 发表于 2015-12-4 16:14 | 显示全部楼层
vxworks在imx6上已经有人移植好了?......
huahua1122 发表于 2015-12-4 17:10 | 显示全部楼层
sdasdasd.maoyi365.com,fsdfsd.maoyi365.com,dsfwerwer.maoyi365.com,dasdwe.maoyi365.com,sdfwe.maoyi365.com,sfsdf.maoyi365.com,daewe.maoyi365.com,dsfdf.maoyi365.com,sfdf.maoyi365.com,dffds.maoyi365.com,dfsdf.maoyi365.com,sadsad.maoyi365.com,dasdsa.maoyi365.com,adasd.maoyi365.com,dsaas.maoyi365.com,dsada.maoyi365.com,sdfsdf.maoyi365.com,rwer.maoyi365.com,dsdf.maoyi365.com,asdas.maoyi365.com,sdad.maoyi365.com,sadas.maoyi365.com,dsad.maoyi365.com,rwer1.maoyi365.com,fsdfsd1.maoyi365.com,ddsadas.maoyi365.com,sadasd.maoyi365.com,fsdfs1d.maoyi365.com,sdfdsf.maoyi365.com
