[LED驱动] 一款高电压LED照明驱动器
1308|2
 楼主| 小浣熊 发表于 2014-6-17 17:33 | 显示全部楼层 |阅读模式
Circuit Description
  This circuit is intended for driving high
  power LEDs, such as the Cree XLAMP™ series, Lumileds Luxeon™ Rebel and K2 and
  OSRAM, Golden and Platinum Dragon™ as well as the OSTAR™. Typical application is
  for example street lighting. It is designed for wide input and output voltage range. An
  optional dimming PWM input is included. The circuit is based on NCP1034 operation at
  400 kHz in a non-isolated configuration.
  Key Features
  y Buck mode  y Wide input and output operation voltage  y Precise line and load regulation  y Dimming capability  y High operation frequency  y Minimal output current ripple  y Output short circuit protection  y Synchronization capability  y Ceramic capacitors only
周董 发表于 2014-6-17 17:34 | 显示全部楼层
 楼主| 小浣熊 发表于 2014-6-18 22:00 | 显示全部楼层
全英
该电路是用于驱动大功率LED的,仔细看看也不难理解吧
