[汽车MCU – KEA] KEA128 Flash Operation Sample Code(已解决)
3984|3
 楼主| ArmedAuto 发表于 2014-6-18 17:06 | 显示全部楼层 |阅读模式
Could you please share if you has KEA128 Flash Operation Sample Code?
FSL_FAE_STEVE 发表于 2014-6-19 10:58 | 显示全部楼层
KEXX_DRIVERS_V1.2.1_DEVD.zip (23.58 MB, 下载次数: 90)
由于KEA的FLASH模块跟KE相同,楼主可以参考附件中的驱动代码,其中NVM文件夹包含了FLASH操作所需的api函数。
* Global functions
uint16_t FLASH_Program1LongWord(uint32_t wNVMTargetAddress, uint32_t dwData);
uint16_t FLASH_Program2LongWords(uint32_t wNVMTargetAddress, uint32_t dwData0, uint32_t dwData1);
uint16_t FLASH_ProgramOnce(uint8_t bPhraseIndex, uint8_t *pData8Bytes);
uint16_t FLASH_ReadOnce(uint8_t bPhraseIndex, uint8_t *pData8Bytes);
uint16_t FLASH_EraseSector(uint32_t wNVMTargetAddress);
uint16_t FLASH_EraseVerifySection(uint32_t wNVMTargetAddress, uint16_t uiLongWordCount);
uint16_t FLASH_VerifyBackdoorKey(uint8_t *pbKey);
uint16_t FLASH_SetUserMarginLevel(uint32_t wNVMTargetAddress, uint16_t wMarginLevel, uint8_t bIsEEPROM);
uint16_t FLASH_Program(uint32_t wNVMTargetAddress, uint8_t *pData, uint16_t sizeBytes);
uint16_t FLASH_EraseBlock(uint32_t wNVMTargetAddress, uint8_t bIsEEPROM);
uint16_t FLASH_EraseVerifyBlock(uint32_t wNVMTargetAddress,uint8_t bIsEEPROM);
uint16_t FLASH_EraseAll(void);
uint16_t FLASH_EraseVerifyAll(void);
uint16_t FLASH_Unsecure(void);
uint16_t FLASH_EraseBlock_NoWait(uint32_t wNVMTargetAddress, uint8_t bIsEEPROM);
uint16_t FLASH_CheckErrStatus(void);
#if (defined(IAR))
__ramfunc void FLASH_LaunchCMD(uint8_t bWaitComplete);
#else
#endif
uint16_t EEPROM_Program1Byte(uint32_t wNVMTargetAddress, uint8_t bData);
uint16_t EEPROM_ProgramUpto4Bytes(uint32_t wNVMTargetAddress, uint8_t *pbData, uint8_t bByteCount);
uint16_t EEPROM_Program(uint32_t wNVMTargetAddress, uint8_t *pData, uint16_t sizeBytes);
uint16_t EEPROM_EraseVerifySection(uint32_t wNVMTargetAddress, uint16_t uiByteCount);
uint16_t EEPROM_Program1Byte_NoWait(uint32_t wNVMTargetAddress, uint8_t bData);
uint16_t EEPROM_ProgramUpto4Bytes_NoWait(uint32_t wNVMTargetAddress, uint8_t *pbData, uint8_t bByteCount);
uint16_t EEPROM_EraseSector_NoWait(uint32_t wNVMTargetAddress);
uint16_t EEPROM_EraseSector(uint32_t wNVMTargetAddress);
uint16_t FLASH_Init(uint32_t BusClock);
/*! @} End of nvm_api_list
gxliu08 发表于 2014-6-25 20:11 | 显示全部楼层
可以用该FLASH存一些配置参数,不过需要注意FLASH的擦写寿命,不知道能擦多少次?最好做写均衡算法。
lvyunhua 发表于 2014-7-3 21:52 | 显示全部楼层
:lol赞一个,老外在请教问题吗?
