波特率限制问题
997|1
 楼主| shibalihuandao 发表于 2014-6-22 23:38 | 显示全部楼层 |阅读模式
为啥我下载example里的msp430g2xx3_uscia0_uart_01_9600是正常的
msp430g2xx3_uscia0_uart_01_19200缺有部分收发错误
 楼主| shibalihuandao 发表于 2014-6-22 23:39 | 显示全部楼层
#include  "msp430g2553.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  BCSCTL1 = CALBC1_1MHZ;                    // Set DCO
  DCOCTL = CALDCO_1MHZ;
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                    // P1.1 = RXD, P1.2=TXD
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 52;                             // 1MHz 19200
  UCA0BR1 = 0;                              // 1MHz 19200
  UCA0MCTL = UCBRS0;                        // Modulation UCBRSx = 1
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  while (!(IFG2 & UCA0TXIFG));              // USCI_A0 TX buffer ready?
  UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character
