/********************************************************** 串口初始化设置 **********************************************************/
void UART_init(void)
//UART2 RS485
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_UART2);
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOG);
GPIOPinConfigure(GPIO_PG4_U2RX);
GPIOPinConfigure(GPIO_PG5_U2TX);
ROM_GPIOPinTypeUART(GPIO_PORTG_BASE, GPIO_PIN_4 | GPIO_PIN_5);//设定PG4 PG5为串口
ROM_UARTConfigSetExpClk(UART2_BASE, ROM_SysCtlClockGet(), 1200, (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE | UART_CONFIG_PAR_NONE)); //设定 UART for 115200, 8-N-1 operation
ROM_IntEnable(INT_UART2); //使能UART2中断
ROM_UARTIntEnable(UART2_BASE, UART_INT_RX | UART_INT_RT);
串口2中断
void UART2_Handler(void)
uint32_t ui32Status;
ui32Status = ROM_UARTIntStatus(UART2_BASE, true);
//获取中断状态 屏蔽中断状态
ROM_UARTIntClear(UART2_BASE, ui32Status);
//清除UART中断源
while(ROM_UARTCharsAvail(UART2_BASE))
//接收数据
data_buffer=ROM_UARTCharGetNonBlocking(UART2_BASE);
data_buffer_cfg=1;
// 主 函 数
int main(void)
//uint32_t i;
sys_init(); //系统初始化
UART_init(); //串口初始化
Port_init(); //IO初始化
ROM_IntMasterEnable();// 使能总中断
GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_3,~GPIO_PIN_3); //RDE=0
GPIOPinWrite(GPIO_PORTA_BASE,GPIO_PIN_5,~GPIO_PIN_5);
GPIOPinWrite(GPIO_PORTA_BASE,GPIO_PIN_6,~GPIO_PIN_6); //LED亮
while(1)
if(data_buffer_cfg==1)
data_buffer_cfg=0;
ROM_IntDisable(INT_UART2);
GPIOPinWrite(GPIO_PORTF_BASE,GPIO_PIN_3,GPIO_PIN_3); //RDE=1
//data_buffer= 0xAA;
ROM_UARTCharPutNonBlocking(UART2_BASE, data_buffer);
//while(UARTBusy(UART2_BASE)); //等待发送完成
delay();
