[i.MX] ltib编译报错,请版主解决一下,谢谢!
1437|11
 楼主| ffbiao 发表于 2014-6-25 14:54 | 显示全部楼层 |阅读模式
+ make
make  all-recursive
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8'
Making all in tools
make[2]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools'
make[2]: *** No rule to make target `all'.  Stop.
make[2]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8/tools'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/texinfo-4.8'
make: *** [all] Error 2
error: Bad exit status from /opt/fsl/L3.0.35_4.0.0_130424_source/Linux/ltib/tmp/rpm-tmp.39741 (%build)
RPM build errors:
Build time for texinfo: 11 seconds
Failed building texinfo
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Tue Jun 24 23:53:08 2014
Ended:   Tue Jun 24 23:53:19 2014
Elapsed: 11 seconds
These packages failed to build:
texinfo
Build Failed
FSL_TICS_ZJJ 发表于 2014-7-1 14:25 | 显示全部楼层
楼主你好,你的问题我已经帮你转给我们的I.MX工程师,他会尽快帮您解答,请耐心等待下哦!
FSL_TICS_Rita 发表于 2014-7-1 16:27 | 显示全部楼层
楼主你好,我在我们的另外一个中文论坛上已经回复给你了,并且你也把问题解决了,这里麻烦你把该贴结了哈,非常感谢:)~~
FSL_TICS_Rita 发表于 2014-7-1 16:28 | 显示全部楼层
具体结贴方式参考本论坛中帖子:本论坛中结贴方式
y-h1226@163.com 发表于 2014-7-28 16:06 | 显示全部楼层
解决方法在哪?
FSL_TICS_Rita 发表于 2014-7-28 16:17 | 显示全部楼层
解决方法在哪?
你好,他在我们的另外的一个中文论坛上发的帖子:http://www.amobbs.com/thread-5585755-1-1.html。你可以查看一下,同时欢迎你有问题在本论坛中创帖提问哈,会有我们的工程师第一时间给你回复的~~
y-h1226@163.com 发表于 2014-7-28 18:00 | 显示全部楼层
还是没解决!
y-h1226@163.com 发表于 2014-7-29 09:14 | 显示全部楼层
把opt目录删了也试过,
补丁也打过
把patch*.sh 拷贝到y/ltib/目录下执行。
Defaults        env_reset
Defaults        secure_path="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
# Host alias specification
# User alias specification
# Cmnd alias specification
# User privilege specification
root    ALL=(ALL:ALL) ALL
#n1 ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
name2 ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
#%admin ALL = NOPASSWD: /usr/bin/rpm, /opt/freescale/ltib/usr/bin/rpm
# Members of the admin group may gain root privileges
%admin ALL=(ALL) ALL
# Allow members of group sudo to execute any command
%sudo   ALL=(ALL:ALL) ALL
# See sudoers(5) for more information on "#include" directives:
#includedir /etc/sudoers.d
FSL_TICS_Rita 发表于 2014-7-29 13:54 | 显示全部楼层
把opt目录删了也试过,
补丁也打过
你好,你建个新帖我们讨论一下吧。
y-h1226@163.com 发表于 2014-7-29 14:10 | 显示全部楼层
已经发了
但是不知道为什么这样
抱歉,指定的主题不存在或已被删除或正在被审核
