[AVR单片机] ATMEGA16,PWM波
1462|4
 楼主| qazplm3218 发表于 2014-7-2 11:28 | 显示全部楼层 |阅读模式
flash uchar SinParam[234]={
127, 130, 133, 136, 139, 142, 145, 148, 152, 155, 158, 160, 163, 166, 169, 172, 175, 178, 180, 183,
186, 188, 191, 194, 196, 199, 201, 203, 206, 208, 210, 212, 214, 216, 218, 220, 222, 223, 225, 227,
228, 230, 231, 232, 233, 235, 236, 237, 237, 238, 239, 240, 240, 241, 241, 241, 242, 242, 242, 242,
242, 242, 241, 241, 241, 240, 240, 239, 238, 237, 237, 236, 235, 233, 232, 231, 230, 228, 227, 225,
223, 222, 220, 218, 216, 214, 212, 210, 208, 206, 203, 201, 199, 196, 194, 191, 188, 186, 183, 180,
178, 175, 172, 169, 166, 163, 160, 158, 155, 152, 148, 145, 142, 139, 136, 133, 130, 127, 124, 121,
118, 115, 112, 109, 106, 102, 99, 96, 94, 91, 88, 85, 82, 79, 76, 74, 71, 68, 66, 63,
60, 58, 55, 53, 51, 48, 46, 44, 42, 40, 38, 36, 34, 32, 31, 29, 27, 26, 24, 23,
22, 21, 19, 18, 17, 17, 16, 15, 14, 14, 13, 13, 13, 12, 12, 12, 12, 12, 12, 13,
13, 13, 14, 14, 15, 16, 17, 17, 18, 19, 21, 22, 23, 24, 26, 27, 29, 31, 32, 34,
36, 38, 40, 42, 44, 46, 48, 51, 53, 55, 58, 60, 63, 66, 68, 71, 74, 76, 79, 82,
85, 88, 91, 94, 96, 99, 102, 106, 109, 112, 115, 118, 121, 124};
// 234点正弦波样本值
这个是通过什么软件得到的结果??
wangch_sh 发表于 2014-7-2 20:01 | 显示全部楼层
不知道。不过自己写个C程序也可以得到类似的结果吧
弥勒开怀笑 发表于 2014-7-2 20:21 | 显示全部楼层
这个应该可以用C语言写程序来实现
 楼主| qazplm3218 发表于 2014-7-3 09:35 | 显示全部楼层
没有专门的计算软件的吧???
Louie_Lu 发表于 2015-6-28 23:27 | 显示全部楼层
在execl中用SIN函数做即可。
