大家帮忙看下为什么STM32F030的USART1 DMA发不出数据
7085|13
 楼主| huiguang_1 发表于 2014-7-3 10:27 | 显示全部楼层 |阅读模式
void USART1_Configuration(void)
  USART_InitTypeDef USART_InitStructure;
  NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOB, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1, ENABLE);
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_0);//ÅäÖÃPA9³ÉµÚ¶þ¹¦ÄÜÒý½Å        TX
        GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_0);//ÅäÖÃPA10³ÉµÚ¶þ¹¦ÄÜÒý½Å  RX
//USART1_IO_CONFIG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;                                        //GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        RCC_USARTCLKConfig(RCC_USART1CLK_PCLK);//( RCC_USART1CLK_PCLK );
  USART_DeInit(USART1);
  USART_InitStructure.USART_BaudRate = 115200;//19200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode =USART_Mode_Rx|USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
  USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
  USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
        USART_ClearFlag(USART1,USART_FLAG_TXE);
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0x03;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);        */
* º¯ÊýÃû³Æ  : DMA_Configuration
* ÃèÊö      : ´®¿ÚµÄDMA·¢ËÍ
              Í¨Ñ¶¿Ú2ΪRS485¶Ë¿Ú¡£
* ÊäÈë      : None
* Êä³ö      : None
* ·µ»Ø      : None
void USART1_DMA(void)
    DMA_InitTypeDef DMA_InitStructure;
                RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel2);        //Page146
    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;          //Page33
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)UART_SEND;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
    DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;//DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel2, &DMA_InitStructure);
                NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_3_IRQn;    //ǶÌ×ͨµÀΪDMA1_Stream6_IRQn
                NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
                NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;               //ͨµÀÖжÏʹÄÜ
                USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
                DMA_Cmd(DMA1_Channel2, ENABLE);
                //DMA_ITConfig(DMA1_Channel2, DMA_IT_TC, ENABLE);
 楼主| huiguang_1 发表于 2014-7-3 10:29 | 显示全部楼层
假如不用DMA的话,发送倒是可以出波特。
USART_SendData(USART1,0x01);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
beicheng 发表于 2014-7-3 12:11 | 显示全部楼层
偏移地址你看下对不对,
njchenmin 发表于 2014-11-22 07:31 | 显示全部楼层
while(USART_GetFlagStatus(USART1, ...
你STM32F0使用DMA没有USART数据输出而不用DMA有数据输出的问题解决了吗?我也碰到同样的问题,而且我在STM32F051中使用USART2就正常,USART1不正常,而且如果同时使用两个串口,以前正常的串口2也不正常了。
 楼主| huiguang_1 发表于 2014-11-22 09:54 | 显示全部楼层
解决了
ak64 发表于 2014-12-10 23:51 | 显示全部楼层
怎么解决掉的
moon20704 发表于 2014-12-24 11:58 | 显示全部楼层
解决了
怎么解决的
moon20704 发表于 2014-12-24 11:59 | 显示全部楼层
解决了
我也碰到相同的问题,大神,请问怎么搞的?
 楼主| huiguang_1 发表于 2014-12-24 12:23 | 显示全部楼层
1803122924
SailorWzw 发表于 2015-4-2 18:36 | 显示全部楼层
一楼用的重映射端口为PB6PB7,查一下stm32f030的datasheet可知对应的是USART1_TX和USART1_RX,在查看DMA的请求映像是没有这个的,有的都是有上标的。 意思就是用DMA时不是所有复用的usart端口都可以,要看dma的请求源里有没有。
SailorWzw 发表于 2015-4-2 18:38 | 显示全部楼层
就楼主的程序端口换成PA2PA3,就可以了。
翻了个墙 发表于 2016-3-11 15:20 | 显示全部楼层
找到问题了不分享,差评。。。。。。。。。。。。
