[AVR单片机] 用AVRICC 写的程序,错在哪里?
1101|3
 楼主| nathanxgx 发表于 2014-7-8 09:59 | 显示全部楼层 |阅读模式
#include<iom8v.h>
#include<macros.h>
#define uchar unsigned char
#define uint unsigned int
void DelayMs(uint i);
uchar dis[] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
int main(void)
  uchar i;
  uchar* p;
  DDRB = 0XFF;
while(1)
   P = &dis[0];
   for(i = 0;i < 8;i++)
   PORTB = * p;
   p++;
   DelayMs(100);
   uint j;
   for(;i != 0;i--)
   for(j =1000;j!= 0;j--);
light5123 发表于 2014-7-8 14:12 | 显示全部楼层
while中的PORTB = * p;语句不对,你看一下,换成PORTB = * (p+i);
 楼主| nathanxgx 发表于 2014-7-9 10:00 | 显示全部楼层
是我自己弄错了,已经搞定了.谢谢
