我的程序怎么进到中断里出不来了,大家帮我看看
2384|6
 楼主| 冰冷的游客 发表于 2014-7-8 16:19 | 显示全部楼层 |阅读模式
//发送数据
void USCIA0_Send(char *p_data,unsigned int i_length,unsigned int i_time)
    unsigned  int i_ctr = 0;
    S_Assist.C_CircutBusyFlag = 1;
    USCIA0_TX_EN;
    Delayms(1);
    S_HartData.I_RxCtr = 0;
    S_HartData.I_RxTotalCtr = 0;
    S_HartData.C_RxOK = 0;
    S_HartData.I_TxCtr = 0;
    S_HartData.C_TxOK = 0;
    S_HartData.I_TxTotalCtr = i_length+4;
    memset(&S_HartData.C_TxBuf[0],0xFF,4);
    memcpy(&S_HartData.C_TxBuf[4],p_data,i_length);
    UCA0TXBUF =  S_HartData.C_TxBuf[0];
    do
        i_ctr++;
    }while(!S_HartData.C_RxOK && i_ctr<=i_time);
    S_Assist.C_CircutBusyFlag = 0;
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
      if(S_HartData.I_TxCtr >= S_HartData.I_TxTotalCtr)
          S_HartData.I_TxTotalCtr = 0;
          S_HartData.C_TxOK = 1;
      else
          S_HartData.I_TxCtr++;
          UCA0TXBUF = S_HartData.C_TxBuf[S_HartData.I_TxCtr];
     if(S_HartData.C_TxOK == 1)
          if(++S_HartData.C_ModbusTxCtr >= 6)
              USCIA0_RX_EN;
              S_HartData.C_ModbusTxCtr = 0;
unsigned char C_Rx_FF_Ctr = 0;
unsigned char C_Rx_Total_Ctr = 0;
//--接收中断函数----
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  unsigned char c_rx = 0;
  c_rx = UCA0RXBUF;
  if(c_rx == 0xFF)
      if(++C_Rx_FF_Ctr >= 3)
          C_Rx_Total_Ctr = 0xFF;
          S_HartData.C_RxHead = 1;
  else
      C_Rx_FF_Ctr = 0;
  if(S_HartData.C_RxHead == 1)
      if(c_rx == 0x02 || c_rx == 0x82)
          S_HartData.C_RxHead = 2;
          S_HartData.C_RxBuf[S_HartData.I_RxCtr++] = c_rx;
      else
          if(c_rx == 0xFF)
              C_Rx_FF_Ctr++;
          else
              C_Rx_FF_Ctr = 0;
              S_HartData.C_RxHead = 0;
  else if(S_HartData.C_RxHead == 0x02)
      if(S_HartData.C_RxBuf[0] == 0x02)
        if(S_HartData.I_RxCtr >= 4)
            if(C_Rx_Total_Ctr == 0xFF)
                C_Rx_Total_Ctr = S_HartData.C_RxBuf[3]+5;
      else
        if(S_HartData.I_RxCtr >= 8)
                C_Rx_Total_Ctr = S_HartData.C_RxBuf[7]+9;
      if(S_HartData.I_RxCtr >= C_Rx_Total_Ctr)
          C_Rx_FF_Ctr = 0;
          S_HartData.I_RxTotalCtr = S_HartData.I_RxCtr;
          S_HartData.C_RxOK = 1;
 楼主| 冰冷的游客 发表于 2014-7-8 16:21 | 显示全部楼层
发送完数据后就一直在接收中断里循环,我怎么才能让他跳出来,等有数据来的时候再进来。
dirtwillfly 发表于 2014-7-8 20:51 | 显示全部楼层
可以把中断里的部分代码移到主函数里,只留必要的代码。
循环可以放到main函数中
 楼主| 冰冷的游客 发表于 2014-7-9 08:39 | 显示全部楼层
循环可以放到main函数中 ...
我试试
 楼主| 冰冷的游客 发表于 2014-7-9 09:46 | 显示全部楼层
我试试
还有其他方法吗
 楼主| 冰冷的游客 发表于 2014-7-9 09:47 | 显示全部楼层
循环可以放到main函数中 ...
还有其他方法吗
dirtwillfly 发表于 2014-7-9 11:50 | 显示全部楼层
还有其他方法吗
优化你中断服务程序里的循环,没必要进行循环时就跳出循环。
主要是减少中断服务程序的执行时间
